Old 05-24-2010, 05:44 PM   #1
Heinz55
Heinz55's Avatar
Need new radiator for 55 2nd series
Started truck today after a long time off. Timing still needs some work, but discovered a huge hole in the (brand new) radiator that I must have put there myself sometime in the last year of fabrication.
Where would be a good place to get a replacement radiator that would mount in original place? not original engine, now running an Olds 455 (until I find a SB chevy to put in)
During first and only engine rebuild " That O-ring? It's a spare I think, but lets keep it just in case we discover we need it"
1955 Chevy 2nd series, "Mabel"
Heinz55 is offline   Reply With Quote
Old 05-24-2010, 08:29 PM   #2
OrrieG
OrrieG's Avatar
Re: Need new radiator for 55 2nd series
I got one for my 59 out of a 57 big truck (6400??). It has the same mounting pattern to the radiator support but is 1" thicker and about 3" taller. I never had any problems with the old 6 cylinder one I had in there but figured since I was upgrading may as well get some more cooling for the a/c.
Old 05-25-2010, 04:38 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
When I needed a radiator for my 52 last summer I talked to a radiator shop. His advice was to go to ebay motors and search. I paid about $250 shipped for one that dropped right in and works great. The vendor I used is currently out of ones for the 55, but there are others. Get the 3 row core, it should keep that 455 cool.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-25-2010, 07:03 AM   #4
Heinz55
Heinz55's Avatar
Thanks for the info. Found a couple on Ebay I will look at.
How hard is it to fix these radiators?
I have the old one that came out of the truck that may be a quick fix until I can afford a brand new on. I am very handy at brazing and welding, and it seems the leaks are only where to top and bottoms join the rest of the piece.
Old 05-25-2010, 12:22 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
The area has to be clean inside and out to solder. Then submerge the radiator until the seam is above the water. It's been years since I soldered one usually had a shop do it, they can do it a lot better. I also learned that shops are hard to find. They were forced to close when the price of copper skyrocketed. These aluminum radiators have dealt the shops another blow.
Fred
Old 05-25-2010, 07:36 PM   #6
mr48chev
mr48chev's Avatar
If the hole didn't take out a lot of tubes I'd pack the "new one with the hole" down to a radiator shop and see if they can repair it. If the rest of the radiator is in good shape they should be able to solder it and send you on your way.
Old 05-29-2010, 01:37 PM   #7
bajaracing
bajaracing's Avatar
try http://championcooling.com/
I have a 72 c10, and bought a 2row aluminum, fit perfect, and working great! Only $169.00
bajaracing is offline   Reply With Quote
