Old 07-16-2010, 03:52 PM   #1
Libertad
No Nonsense
Libertad's Avatar
1976 K5 on 39.5 Super Swampers
Well I went ahead and traded my C10 for this 1976 K5.
350 / 350
NP203
Dana 44 / GM14 full floating 3/4 ton axles
6" lift and 3" body lift
39.5 Super Swampers
She needs some cleaning up and personalizing......... I can't wait til this 103 degree heat dies down.
Here she is:
Libertad is offline   Reply With Quote
Old 07-16-2010, 03:58 PM   #2
Libertad
No Nonsense
Libertad's Avatar
Re: 1976 K5 on 39.5 Super Swampers
Interior pics:
and the motor:
Old 07-16-2010, 04:07 PM   #3
Davidmichael
Davidmichael's Avatar
Very nice!. I am glad to see you went threw with the trade.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 07-16-2010, 04:10 PM   #4
Libertad
No Nonsense
Libertad's Avatar
Yeah me too! Thanks!
Bi-Centennial Blazer
Old 07-16-2010, 09:04 PM   #5
Gemp
Gemp's Avatar
Nice truck, Whats the plans?
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 07-17-2010, 02:18 AM   #6
Libertad
No Nonsense
Libertad's Avatar
Well Gemp as for right now:
-replace a 24" brake line on the front passenger side
-go through every piece of the suspension and undercarriage to make sure their ain't any loose bolts
-get it registered in my name
-take her out in the local hills and try her out
But in the future I will be doing a 4x4 K5 version of a 70's type rat rod. I got some things in mind that will personalize her into a bare bones type of no nonsense all terrain vehicle.
Old 07-17-2010, 07:06 AM   #7
str8axle55
I think you did well.Solid rig, just needs your touches.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 07-17-2010, 01:45 PM   #8
Ghastlyone
Ghastlyone's Avatar
Eewww, no steering stabilizers. I can't imagine how that thing feels going down the road.
Other then that, cool truck. I have a soft spot for K5's, I've always loved them.
Ghastlyone is offline   Reply With Quote
Old 07-17-2010, 02:24 PM   #9
Libertad
No Nonsense
Libertad's Avatar
What type do you recommend and how tough is it to install?
Old 07-17-2010, 02:58 PM   #10
Ghastlyone
Ghastlyone's Avatar
I ran Pro Comp stabilizers on my 91. There's a ton of different brands out there. You can probably check 4 Wheels Parts. After installing them on my 91 it was 1000x's better. It nearly stopped the wandering and drifting it was doing without them.
They're pretty simple to install also, not hard at all.
It's amazing how many lifted K5's I see without them.
Old 07-17-2010, 03:14 PM   #11
Ghastlyone
Ghastlyone's Avatar
Here an old picture of my 91, I ran the over under style stablizers....
I've heard people say the end to end style are better, but I don't know.
Old 07-17-2010, 03:36 PM   #12
Libertad
No Nonsense
Libertad's Avatar
I will definitely look into some different type of stabilizer setups.
Old 07-17-2010, 07:01 PM   #13
blakeduren
Make sure crossover steering is on your list, that will help you out way more then a steering stabilizer will.
That draglink is at a steep angle right now.
Also, get a ORD style steering box brace and find a XJ steering shaft to swap in, all of these things make a world of difference.
Blake
blakeduren is offline   Reply With Quote
Old 07-17-2010, 08:17 PM   #14
68Timber
I know the pieces fit
68Timber's Avatar
That's a good looking K5, nice score.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-18-2010, 03:27 AM   #15
blu-by-u-2
blu-by-u-2's Avatar
Sweet!
77 k5 2wd
76 k5 jimmy 4x4
97 c1500 2wd
06 chrysler 300 on 22"s
blu-by-u-2 is offline   Reply With Quote
Old 07-18-2010, 08:59 AM   #16
russgt
russgt's Avatar
With that big of a tire the dana 44 can and will be a weak link in the drivetrain. Not trying to scare you, but keeping that in mind and taking it easy when you are a ways from pavement will help you make it back.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 07-18-2010, 11:37 AM   #17
nlped
nlped's Avatar
^^^Russ is right about the Dana 44, I destroyed the one in my Jeep and it only had a 35" tall tire. They are not very friendly with the heavy wheels and tires .
Thing looks like a ton of fun though! I'd fix the air, straighten out the steering and drive the snot out of it
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-18-2010, 11:52 AM   #18
Ghastlyone
Ghastlyone's Avatar
Blake
I ran a steering box brace on my 91 also. These trucks are notorious with the frame cracking right at the steering box.
Installing one though is no small task. I remember the that took longer then doing the whole lift kit on mine.
Old 07-18-2010, 12:09 PM   #19
Libertad
No Nonsense
Libertad's Avatar
Thanks for the note of caution. Even though it is a 3/4 instead of a 1/2 ton Dana 44? I do plan on putting some 38" Ground Hawgs on her but I only have three so I need to find someone that wants to trade these 4 SS for 1 or 2 Ground Hawgs.
I will mostly be doing the local hills around here and nothing crazy fast or hard.
Old 07-18-2010, 12:19 PM   #20
Libertad
No Nonsense
Libertad's Avatar
Adding steering box brace.......thanks
Old 07-18-2010, 02:32 PM   #21
russgt
russgt's Avatar
The 1/2 at 3/4 are internally the same, basically the only difference is the lug pattern. Some people have had good luck with them and a lot of upgrade parts are available, such as chrome molly shafts. Its not a bad unit, just not as strong as a 60, but it is suppose to be stronger than the 10 bolt. I do want to add that it is a very sharp truck and I am curious how the handles between the top and door get attached, I would like to add them to my 76.
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 07-18-2010, 02:50 PM   #22
Libertad
No Nonsense
Libertad's Avatar
I will run the 44 until she dies and then find a 60 to throw under her. As far as the handles they are attached with 4 screws each, not sure how but could be similar to how the mirrors mount to the body.
BTW Russ I checked out your 76 build and man you put a lot of work into it. Looking great! I can't believe how much rust kills in the North.
Old 07-27-2010, 03:29 AM   #23
Libertad
No Nonsense
Libertad's Avatar
Well painted the K5 more to my liking. Marine Corps Olive Drab and Black. OOOORAH!
Old 07-27-2010, 10:22 PM   #24
russgt
russgt's Avatar
looking good
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 07-27-2010, 10:55 PM   #25
blu-by-u-2
blu-by-u-2's Avatar
What happened with the satin black? Looks good.Was the dolphins plate really worth keeping though LOL ? My Jimmy is sport'n A Seahawks frame.
77 k5 2wd
76 k5 jimmy 4x4
97 c1500 2wd
