![]() Join Date: Sep 2008
wtb 4x4 shifter handle and box assembly.
i have a 70 jimmy with a 4x4 shifter the shifts kinda like a J. the handle goes into a box that has a trac to control were the rod goes. mine is shot. trac rotted and is extremely hard to find gears. i need a handle box and trac?? i will ad pics tommorow.
![]() Join Date: Apr 2007
Re: wtb 4x4 shifter handle and box assembly.
Pictures would be very helpful. Do you know if you have a Rockwell or New Process 205 transfer case? I have shifters for both. Glad to help if I can, Sharpie
6>8 Plugless........
![]() Join Date: Sep 2007
I'm guessing he has a rockwell by what he is describing and what parts are left in my 69 with the rockwell.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
I agree, I guess we'll wait for pics to confirm! Sharpie
![]() Join Date: May 2007
it sounds like it is a rockwell but didn't gm switch from a rockwell (69) to np205 in 1970 also rockwell were all manual trans.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
SWB 4x4 Collector
![]() Join Date: Jun 2001
1970 np205 shifters are different from 71-72 np205 shifters. There is also 2 different styles of 70' np205 shifters. The one that points off to the left is more setup for a stick so they don't hit, and the automatic 70' is the one attached to the transfer case. ***Note, I have the wrong manual shifter in the pic, and is misleading on how they would hit each other. Here ya go:
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
SWB 4x4 Collector
I also forgot to mention that if wanting to be correct on a 70' np205, you will need the correct high humps, the holes are cut differently for the np205 shifter in 70' as the shifters are bent more at the base to allow the transfer case shifter to line up centered with (if manual) the manual shifter hole. The 71-72 np205's are more offset to the passenger side of the hump. Trevor
SWB 4x4 Collector
Here is a couple of pics of a Dana 20 setup, typically found in blazer's in 69, and not sure if they came a in a select number of 70's. Trevor
Active Member
![]() Join Date: Dec 2004
Have this one, out of '69 blazer w/rockwell, $45 shipped
