Old 08-24-2010, 08:57 PM   #1
gkesseru
gkesseru's Avatar
What order to put a door together?
Which order do these items go together:
Vent Window
Window felts/rubber strip
Door lock
Door lock button bar
Interior door handle mechanism
Door handle remote control bar
Window regulator
Window glass
Window rear run channel
Channel rubber strip
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 08-24-2010, 09:04 PM   #2
Mt Man Chad
Mt Man Chad's Avatar
Re: What order to put a door together?
Vent window first & rebuilt with new rubber before put in door.
Window Glass
Window regulator
Window rubber strip with window still down
Window rear channel
The rest can be place in any order, worked for me two weeks ago.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 08-24-2010, 09:33 PM   #3
gkesseru
gkesseru's Avatar
Thanks,
Sounds good except for one item. I just found out (another oops) after I got one vent window in, the regulator needs to go in before the vent window. The lower part of vent channel blocks the window crank shaft from fitting in the hole.
72 Fleet (died)
78 Step (sold)
00 F150
Old 08-24-2010, 10:18 PM   #4
Sammy
It may not help you what so ever. But with the door installed, installing the window becomes so difficult for me. I have found that gravity, limited visual inside the door and lack of patience makes this a time consuming process. But if I remove the door lay it flat I can do the job in very short order.15 min versus two hours.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-25-2010, 01:04 PM   #5
gkesseru
gkesseru's Avatar
I just found a GREAT photo how to assemble a complete door!
http://www.sporttruck.com/techarticl...oor_parts.html
To the " Move a Message" administrator: this could be moved to the body secvtion.
72 Fleet (died)
78 Step (sold)
00 F150
