Old 09-02-2010, 02:25 PM   #76
68 short step
Re: project " Blue-Ray"
Originally Posted by 71'tahoe View Post
whats the Manifolds off of? It looks like one would have to add the a/c after the engine is set in place or can you have it on the engine when it goes in? I cant tell from the pics..
Thanks,
Greg
the manifolds are stock truck style...the A/C compressor 'could' be installed with the engine, but the a/c manifolds cant be connect while it goes in...also there is a motor mount bolt that needs to be installed, and the A/C compressor would interfer with doing that...so it would be best to install after the engine is in place and bolted down IMO..
Originally Posted by signgod2 View Post
Can you put that 1/4" npt anywhere on the head or just in that location?
just in that location, its the only spot that has a water port in the head..
Is that the a/c that you will use or is that just for mock-up ? I'm gonna ask but did you use the 87' fuel set-up because thats the first year they put feul injected on those style trucks that would fit that style tank ? And you needed that for this set-up of motor? Where does the gas pedal wiring hook up at? sorry so many questions, thats why your the man.
that a/c compressor and manifolds are just my mock-up ones....i used the 87 sending unit because, it was the first year for the intank pump, so it has provisions for a fuel pump....also it is a direct fit in place of the other sending unit.....the gas pedel wiring has two connections, one goes to the pedal itself, and the other goes to the PCM...
68 short step is offline   Reply With Quote
Old 09-02-2010, 02:31 PM   #77
killer71
killer71's Avatar
What's the plan for cruise control?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 09-02-2010, 04:39 PM   #78
LEEVON
LEEVON's Avatar
You have a NAPA in front of your shop! Tits!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-02-2010, 05:12 PM   #79
my67chevytruck
Under Construction
my67chevytruck's Avatar
Awesome work Don!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-02-2010, 09:17 PM   #80
signgod2
signgod2's Avatar
thanks for the info. Just a quick question will that a/c compressor be hard to remove in future if needed to change it?
signgod2 is offline   Reply With Quote
Old 09-02-2010, 11:37 PM   #81
68 short step
no, the A/C compressor wont be bad at all...probley 30 mins. to R&R it if needed..take a look at kalebs black truck, it is alot less cramped then that...and also with your lift, it'll be super easy
Old 09-12-2010, 08:24 PM   #82
68 short step
bit more progress to report on blue ray....
got the wiring ran for the fuel pump, adding a factory style weather-pack connector. also installed the gas tank, fuel filter/regulator, and made/installed the braided SS fuel lines with the AN fittings....mounted the transmission cooler, fabbed the lines, and connected it all up..then i fabbed/installed the P/S lines...and finally, measured, bent, and installed the shift linkage....
Old 09-12-2010, 09:04 PM   #83
jasonhall
jasonhall's Avatar
Bixby oklahoma,used to work at oreillys there and professional body works for a few months.. Bixby sure has grown the last few years..Truck looks great!
jasonhall is offline   Reply With Quote
Old 09-12-2010, 09:34 PM   #84
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress! those stainless hoses look super clean! You may have already said, but where do you buy your hardware for the hoses and connectors? Summit racing? You have a parts list put together for a swap like this? thanks
Old 09-12-2010, 09:50 PM   #85
signgod2
signgod2's Avatar
With the transmission mounted at an angle like that ,is that the manufactures suggested mount or does it matter? Or does the transmission pump push it thru. on its on anyway? Will the shift indicator be able to show Overdrive for this style motor or will we have to change the shift viewing block out? Or would you just use the 1-2 3 low gear options for the O/D? Looking good though. Can"t wait.
Old 09-12-2010, 09:56 PM   #86
signgod2
signgod2's Avatar
Just a note: So someone like me will know for future use, What Temp does that transmission cooler keep the temp. at compared to a radiator type style?
Old 09-12-2010, 10:38 PM   #87
68 short step
i mainly get them from summit, i have a cheat sheet that ive put together for these swaps, yes
the pump will push the fluid through there no problem, i mounted it angled like that so it would have, increased area for air flow (better heat disapation)
the shift indicator will have a OD on it, im going to re-do the factory one so it'll read accurately..
specific temp, im not sure, ill have to see once its all up and running....but i can tell you that these heat sink designed coolers were desiged to work better then the traditianal tube/finned type...
Old 09-13-2010, 01:13 AM   #88
y5mgisi
Second Chance Program
y5mgisi's Avatar
So awesome! Hard to tell, is that a metallic blue?
y5mgisi is offline   Reply With Quote
Old 09-13-2010, 07:34 AM   #89
menace121978
menace121978's Avatar
nice progress man. i love the bend you put in the shifter rod. looks good!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-13-2010, 11:20 AM   #90
my67chevytruck
Under Construction
nice work Don!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-19-2010, 07:44 PM   #91
68 short step
few more progress pics to post...
got a adaptor harness (first pic) made for the brake sw./ TCC control.. so its a factory (for 84) brake switch controlling everything, and its a simple plug in deal..
i also mounted, and wired in the OBD2 port, its on the driver side, and is easy to get to, yet inconspicuious..also blasted/painted the stock exhaust manifolds, and installed them...i then had a few friends over to help hang the front clip... it went well, and had it installed/bolted down in about 15 mins...once the clip was installed i put in a new battery perch (hard to see in the dark pic), but looks better then the rusty one it replaced...then determind the best place to mount the fuses/relays for the engine/trans, after going back and forth on either mounting them on the backside of the core support, or on the dr. side fender, i thought that they looked good on the fender and the fact that they are easy to get to made my decision...so i mounted them there....now came to the air intake, its a 4" chrome one that i had to 'tweak' the mount on it so it would mount to the head, rather then the battery box of a newer style truck (like it was designed to do) worked out nicely (only thing i have to do now is paint the bolt that holds it to the head)...
Old 09-19-2010, 07:56 PM   #92
menace121978
looking great Don! i was wondering if you had some more info and pics of how that brake harness you built works?
"Dennis the Menace"
Old 09-19-2010, 08:49 PM   #93
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Hey man, what are your plans for the rest of the air intake? I need to build one myself so I was just curious.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-19-2010, 08:54 PM   #94
VA72C10
VA72C10
VA72C10's Avatar
looking good. nice work
Old 09-19-2010, 09:51 PM   #95
signgod2
signgod2's Avatar
looking good as always. I noticed radiator and condesner missing, Is that next? Will it have a K&N on end of intake? also how is that connection for brake assembly work, I guess I trying to figure that one myself. Keep it up though good job.
Old 09-19-2010, 10:36 PM   #96
68 short step
the brake switch, when the brakes are applied, supply power to the brake lights, the torque converter lock up (TCC) is opposite, it always gets power except when the brakes are applied...the stock 84 brake switch, with cruise control, is a duel purpose sw. it has 2 sets of spades.. one set is normally closed, while the other set is normally open, and when the brakes are applied they are switch....so what i did was kept the brake switch plug the same, and made a adaptor harness to supply power to the other spade connectors on the brake switch....there is 2 wires on the adaptor harness one is power, and the other goes to the TCM, which controls the TCC...clear as mud?
it'll just have a coned air filter on the end, no fancey duct work
yes the radiator will be next, the condenser will be the same, just rotated so the fittings come out on the lower pass side, instead of the uppr driver side...
Old 09-20-2010, 03:31 PM   #97
rodstored-72
chevy truck fan
rodstored-72's Avatar
68 short step,
would you mind telling me where you purchased the wire connectors for your gauges, i am looking to do the same for my '72 & i have no idea where to get the wire connectors???
thanks!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 09-20-2010, 07:11 PM   #98
68 short step
are you talking about the plugins?
Old 09-20-2010, 09:13 PM   #99
killer71
killer71's Avatar
make the fenders look like the firewall!
R.I.P.
Killer 71
10/26/07
Old 09-21-2010, 11:20 AM   #100
rodstored-72
chevy truck fan
yea i guess??? i think they are called "molex connectors"?? i am looking for a wire plug or plugs to run all the gauge wires to so that i have "plugs" between the dash harness & the new gauges.
thanks!!
p.s. you are a very talented "garage tinkerer" LOL!!
