Big block serpentine belt setup
I am trying to reinstall my serpentine belt system off a 1991 Suburban but have forgot how it all went together since I took it apart over 2 years ago. Anybody have some pictures of how this setup goes together? I have some of it mocked up on the motor all but do not know where the braces and such go. Thanks
Re: Big block serpentine belt setup
91 454 serpentine:
What I am looking for is a picture of where all the brackets go
bump...
What are the differences in serpentine set-ups through the years? I hear some are better then others. |
![]() Join Date: Jan 2009
I did but do not have any pictures and the truck is about 120 miles away
Ok, I will keep digging. Thank you.
Which bracket do you need help with
![]() Join Date: Jun 2011
As long as the already-installed components are where they should be, I would think your brackets should line up where the mounting bolts go ??
If your setup is close to my 5.7, the tensioner pully bracket straddles on the A/C compressor & an arm-brace to intake-thermostat bolt then a bracket accepts to bolts at alt-bracket / 3 bolts & below/behind A/C compressor. Boy,.... like 7 points to secure tensioner.... on a 5.7 I pulled a drawing from my '88 GMC service manual, showing a 7.4. Maybe this might help? ( I have no clue what that cylinder is, next to alternator)
'70 GTO Midnight Blue '88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany. '93 Cadillac STS Black '93 Mercedes SL 500 Teal '86 Yamaha FZ750 - 15,000 RPM '86 Yamaha FJ1200 - Criminally Fast 2016 Ferrari 488 GTB, I drive it - don't own it. '05 GMC Yukon XL , SLT 4wd ( just purchased 2018) Last edited by mountie; 03-20-2018 at 03:42 PM. |
