Old 10-24-2010, 05:32 PM   #51
steinepstein
Re: Project Burro Viejo
Here I raised the front end 2", so is a simulated 28" front tire, then I put a 1.5" board under the rear tires, so it will simulate a 29" tire in the rear. Not sure this is going to work, about 1.5" of travel over there.
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216
steinepstein is offline   Reply With Quote
Old 10-24-2010, 05:55 PM   #52
kvn1011
Kvn1011
kvn1011's Avatar
nice!!! i want to get the same motor, but the pricing has not been in my neiborhood!! love the build!!
kvn1011 is offline   Reply With Quote
Old 02-20-2011, 12:05 AM   #53
steinepstein
In with the Rick's tank, out with the hitch.
If anyone wants to weld in this hitch and have a hidden hitch, I will send it to you free if you just pay for shipping.
I am looking for the original rear crossmember for a 68 GMC leaf spring setup....this one doesn't appear to fit correctly, probably from another style.
Old 02-20-2011, 12:12 AM   #54
steinepstein
I had these lowering spacers fabbed up from 2x3 rectangular tubing. On the passenger side, I extended it and cut it at an angle and threaded the inside (simple explanation). My panhard bar will bolt into this and run parallel to the rear axle. On the other side, I will install a dropped bracket which will keep the panhard low and parallel....should improve handling.
Old 02-20-2011, 12:18 AM   #55
mcbassin
Still Learning
mcbassin's Avatar
Man that looks great, I will take the hitch if it doesn't cost too much to ship thanks!
Old 02-21-2011, 07:21 PM   #56
steinepstein
McBassin,
It is a pretty heavy piece, I'm guessing $25-30 to ship. If this is ok, I will move forward.
Thanks,
Jon
Old 02-27-2011, 08:48 PM   #57
RCbowtie69
RCbowtie69's Avatar
Nice build!!!!
RCbowtie69 is offline   Reply With Quote
Old 02-27-2011, 11:45 PM   #58
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by steinepstein View Post
McBassin,
Thanks,
Jon
Thanks Jon, I'm gonna pass for now. I forgot how heavy that thing is.
Old 03-12-2011, 12:05 PM   #59
steinepstein
Got some goodies this week.
Old 03-12-2011, 12:09 PM   #60
steinepstein
Thanks to Greg (lynnfield) for getting me the proper rear crossmember.
Now I can finish off the rest of the frame. The Rick's tank is pretty sweet.
Old 03-12-2011, 12:17 PM   #61
VA72C10
VA72C10
VA72C10's Avatar
looking good!!!
Old 03-12-2011, 01:49 PM   #62
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice new goodies..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-04-2011, 10:40 PM   #63
steinepstein
Started to "shave" the firewall. All of the electrical components will be mount up under the dash. I had some female threaded blinds made out of 3/4" solid round. You can see two of them attached to the MSD coil. They are being welded under the dash to mount the components, so no screws or bolts are coming out of the firewall.
Old 06-04-2011, 10:42 PM   #64
steinepstein
Panhard bar mocked up.
Old 06-19-2011, 10:03 PM   #65
steinepstein
Continuing to mount all the electrical components on the underside of the dash. My ECU (Motec) is going to mount above the radio, so I cut out the old speaker pass-through and will be tacking in a solid piece.
Credit to "bad bagged 68.5" on the inserts he made on page 15 of his build, great idea. I will also be shaving my dash and not running a dash pad, thanks! Awesome build by the way...
Old 08-28-2011, 10:11 PM   #66
steinepstein
Continuing to work on the firewall......
Old 08-29-2011, 08:31 AM   #67
mcbassin
Still Learning
mcbassin's Avatar
Looking good Stein! Where did you get the ac/heater hose pass through?
Old 08-30-2011, 10:36 AM   #68
steinepstein
Thanks McB.
A/C passthrough is from Vintage Air.
Old 08-30-2011, 03:47 PM   #69
67cheby
67cheby
67cheby's Avatar
Nice work !!
67cheby is offline   Reply With Quote
Old 10-18-2011, 02:15 PM   #70
steinepstein
Adding a 3/16" plate to the mild notch area...just a little more structure at the weak link point.
Old 10-18-2011, 02:16 PM   #71
steinepstein
Pick up ls1 parts here and there...future secret weapon.
Old 11-08-2011, 01:18 PM   #72
steinepstein
The plate is now fitted to the inside of the frame rail. Now I can begin reassembly for the final time, hopefully...and open up some space in the shop. Got a lot more to go.... 12 bolt getting shipped off for a full build.
Old 11-08-2011, 01:25 PM   #73
67cheby
67cheby
67cheby's Avatar
sweet...motor looks great !
Old 11-08-2011, 02:29 PM   #74
mcbassin
Still Learning
mcbassin's Avatar
Oh yeah! diggin the new motor!
Old 05-16-2013, 10:17 PM   #75
jr71
do u still the lower control arms?
jr71 is offline   Reply With Quote
