10-26-2010, 05:11 PM | #1 |
NV4500 in a Big Block
I am figuring out what kind of core I wish to use for a project. At this time I have decided that I think I want a big block 396/402 and a 5 speed NV4500 if possible.
I have searched the forum and net and not really found any adapters for this situation. My end goal is a daily driver for Atlantas 70-80mph normal speeds but able to run in down town traffic with a load if need be. Based on this what drivetrain solution do you all feel is best for the range of options listed. Decent gas mileage is a concern as well. Not that I expect to get 20 but I dont expect to get 9 either. Any suggestions? Once I have this drive line figured out its time to shop for a restoreable victim. Robert in Atlanta. Last edited by robreil; 10-26-2010 at 05:11 PM. |
10-26-2010, 05:17 PM | #2 |
Re: NV4500 in a Big Block
I found this.. Would it work? Dodge NV4500 to GM 5.125 Bellhousing Adapter Plate
I am new to this motor and trans and this will be my first automotive restoration. Have done a handful of motorcycles. |
10-26-2010, 05:25 PM | #3 |
Just called NV4500.com and they have NO solution for a bigblock chevy and an NV. Open to all ideas...
10-26-2010, 07:43 PM | #4 |
is this going into a 2 or 4 wheel drive? either way this shouldnt be an issue. call Advance Adapters. you need to decide if you want to run a mechanical clutch or convert to hydraulic. they have both bellhousings that will bolt right up and allow you to run any clutch you prefer. -steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
10-26-2010, 07:49 PM | #5 | |
If I have to do a hyd clutch then so be it. I only wish it to be as economical as possible. I will choose a vehicle based on its ease of conversion. Can you provide a link to the exact product that will work and what will be needed or what it will fit? Last edited by robreil; 10-26-2010 at 07:51 PM. |
10-26-2010, 07:55 PM | #6 |
I have used that plate and it works as advertised. It fits between the bellhousing and the transmission, so what you have on the front side of the bellhousing shouldn't make any difference (unless you have an LSx).
My swap did not involve a BB, but the BB does not use a special bellhousing. It is exactly the same as a SB. If you have a 68-up bellhousing on the truck now, it will work. If not, that's what you will need. If Advance says it won't work, will they tell you WHY it won't work? Ray |
10-26-2010, 08:02 PM | #7 |
well, i'm no expert, but i thought the sbc and bbc bellhousings were the same. so the adapter plate for dodge nv4500 to sbc bellhousing *should* work
(please don't make any purchases based on MY recommendation)
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
10-26-2010, 08:03 PM | #8 |
raycow, you answered while i was trying to formulate a response. glad to know you've done the swap. sending you a PM
10-26-2010, 08:34 PM | #9 |
HTML Code:
I have used that plate and it works as advertised. It fits between the bellhousing and the transmission, The same goes for the transfer case adapter. robreil was unsure if he wanted a 4x4 but if chosen, rather than paying the high cost for a tc adapter, a guy could eliminate the adapter and female coupler (which is a weak link) and bolt a round pattern 205 directly to the tailshaft. The only thing necessary here would be a 32 spline input gear for the tc to match the trans output shaft.
10-26-2010, 09:11 PM | #10 | |
This was a 2WD truck, so I don't know what would have been involved in adapting a T/C to the Dodge transmission. Ray |
10-26-2010, 09:23 PM | #11 |
how thick is the adapter? did it move the trans back far enough to have to trim the shifter hole?
10-26-2010, 09:31 PM | #12 |
The adapter is about an inch thick, but the shifter on the NV4500 is farther back than on the SM420 I was replacing. The total difference was about 3" so I just cut a new hole for the shifter.
Ray |
10-27-2010, 11:20 AM | #13 |
10-27-2010, 11:45 AM | #14 |
10-27-2010, 12:01 PM | #15 |
I didnt know they made them. What years/size are these engines? I assume that they are something I should stay away from so I need to know what to look for.
Saving for a 69-72, 1/2 or 3/4 ton, BBC, TH400 or 4spd, Posi, Full Trim, AC, PS, PB, LWB, Bucket/Console, 4x4 a plus, in driveable restoreable condition for less than $4k with minimal rust. Willing to travel to SW Desert for no/light rust, and for the right price/condition I will forego some of these options and install them later. ---------- My avatar is my old truck in 1980-82. I miss her dearly. She died from a dead water pump and florida rust after a colorado flood saturated the cab with clay. What a loss. |
10-27-2010, 12:45 PM | #16 | |
Ray |
10-27-2010, 12:47 PM | #17 |
Oh so as long as my core has an original engine its all good. Nice to know. Thanks.
10-27-2010, 01:41 PM | #18 |
how about a 383(350 block/400 crank) sbc
10-27-2010, 01:43 PM | #19 |
Well that would be nice. Its just a 350 that has been loved... However I do not want something that I have to go into the motor for a while.
My main goal is to make it happy at 70-80mph w/o straining. Thats why I was thinking of the BBC.
