11-05-2010, 08:49 AM | #1 |
bolt in c notch any good?
hey guys i was wondering if bolt in notch is any good. or is it better to weld in?
i dont have a welder, and have never welded. so thats why im asking if its worth bolting one in or better to have it welded in. are there any pros vs cons ? thanks |
11-05-2010, 09:00 AM | #2 |
Re: bolt in c notch any good?
Think of it this way, have you ever seen a truck frame (the frame itself) that was bolted together? Not the attachments to the frame, but the actual frame itself?
Therefore, from a pure strength and mechanical engineering viewpoint it is better to weld it in... but: If you plan to use your truck, as a truck, hauling and towing, then you want a notch designed for towing and hauling and it should be welded to the frame.Some of the simple c-notch kits are scary! Go with a reputable kit from a reputable company: Bell Tech, CPP and Porterbuilt all build a quality notch kit. Here is a link to other posts that will no doubt provide you with hours of reading: http://67-72chevytrucks.com/vboard/s...=1957427&pp=25 Good luck and be sure to buy a good quality kit. This is one area that good engineering truly matters. Last edited by lakeroadster; 11-05-2010 at 09:11 AM. |
11-05-2010, 09:10 AM | #3 |
thanks for reply.
im looking at a kit from cpp. comes with a bolt in notch. i guess it can be welded in right? or do i buy a specific for welding notch? thanks for help and sorry for dumb questions. |
11-05-2010, 09:13 AM | #4 |
Happy to be here
Buy a good quality unit, bolt it in and enjoy. When you do the cut out for the notch be sure to drill holes where the cut lines intersect on the frame. This will help to prevent a sharp intersection that could promote stress cracking. Beyond that you should be fine.
11-05-2010, 09:13 AM | #5 |
Bolt-it in to get you going & then take it by a welding shop that can weld it properly.
11-05-2010, 09:13 AM | #6 |
If I were buying a kit I would bolt and weld, but that's me. I would suggest you call CPP and talk with them.
11-05-2010, 09:14 AM | #7 |
Happy to be here
Some kits are designed to be weld in only. There should be no difference other than the holes. If you really want to be sure, bolt it in and have it welded too. If strength is a concern, contact Jeff at CPP (CPPJeff) and ask about his super heavy duty unit.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-05-2010 at 09:15 AM. |
11-05-2010, 09:19 AM | #8 |
thats what i was thinking maybe as an option. didnt know if that could be done. i called a local shop for a price on installing spindles, flip kit, coils and a notch and dude told me 5oo. so 4 plus shipping for kit, then 500. seems alot to lower truck.
im not much of a mechanic, so i didnt think i would try this install myself. my luck ill mess something up, or as in past, end up with extra bolts.... but thinking i may try it after i finish up my bodywork that i am attempting to do now. not a body man either. so we will see. thanks for replies guys. much appreciated. |
11-05-2010, 09:41 AM | #9 |
Happy to be here
Don't be afraid to tackle the lowering yourself. Find a buddy that has some experience and take it one end at a time. Its fairly straightforward and you can gain all the knowledge you need on this forum to be successful at the job.
11-05-2010, 09:42 AM | #10 | |
Smoke Tires, not Drugs Last edited by MONTEZ; 11-05-2010 at 09:44 AM. |
11-05-2010, 09:46 AM | #11 |
im strongly considering giving it a go.
i dont have many friends for help. or mechanic friends.... now a days, its me and my kids. 2 kids a wife and a ton of bills, you know the drill anyway, ill keep looking for write ups on how to's. i found one for the flip kit, but all pics were red x'd. ill give it a try once holidays are over. xmas coming and my sons bday is on xmas...... so ill get there...just not tomorrow. thanks again guys |
11-05-2010, 09:53 AM | #12 |
weld in c notch looks better but as far as strength there really is no stress on the frame back there on a coil suspended truck unless you have a swaybar attached to the rear of the frame rail// so in most cases boltin is more than strong enough for the application
11-05-2010, 10:07 AM | #13 | |
11-05-2010, 10:11 AM | #14 |
dont have a boat to pull. and dont tow or load much, but its a truck i bought, to have truck abilities, so, i might just look to have it welded. maybe i can do the spindles, springs, and flip and just have notch welded in??
11-05-2010, 10:19 AM | #15 |
How much drop are you considering & what year truck?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-05-2010 at 10:19 AM. |
11-05-2010, 10:19 AM | #16 |
Out of the thousands of bolt-in C-notches out there, I would be willing to bet not one person reading this post has ever encountered first-hand a C-notch failing due to being bolted in rather than welded.
Bolt-in is fine, even pulling a trailer or hauling loads. The number and classification of fasteners used to attached the notch adequately equates to any welding process. |
11-05-2010, 10:25 AM | #17 |
truck is an 85 gmc
couple pics....truck, blue is 85 one shot of some sanding....grill, bumper, lights are off...little bodywork and then im priming the front, gonna pull off bed and do that seperate. the gray one is my old 82...that i shoulda never sold....after a guy put fenders and a little body work for me. plan on 4/6 or 5/7.....in that ballpark.. |
11-05-2010, 10:47 AM | #18 |
Happy to be here
Based on what you have said I would approach it like this. Buy a drop spindle for the front and cut one coil off the stock spring. For a good deal on spindles take a look at the stickies in this forum.
For the rear you can buy a lowering shackle and raise the spring perch, or go with the flip kit. If you can save the money by doing it yourself, maybe consider have a "competent" shop build a small rear notch. Please DO NOT consider AIM/Chassis Tech to cut costs
11-05-2010, 11:44 AM | #19 |
coils, drop spindles, flip kit and c-notch kit...<<<this is what jeff at cpp told me he could get me for my desired 4/6 drop.
im pretty sure thats with a 2.5 spindle....now after reading here and there i think i may want 3 inch spindles. mainly because, i, like many will prob want it lower. but figure 3 in spindles. cut one coil off front. >>>i was thinking about cutting coil off front spring....maybe i dont need cpp coils??? or maybe better off just getting them with kit?? flip kit for rear. ive read you need notch for this drop, and then ive read you dont need notch for this drop, but i will want a notch. the 82 had one and it drove great. maybe im better off, splitting up the kit... getting 3 in spindle. flip kit. no coils or notch.... use my springs for now, and buy a weld in notch instead of bolt in notch. im planning on pulling bed at some point. so if it aint too much of a pain to put on and off, i can, fingers crossed, install spindles and flip sucessfully, and then have notch welded in.? n2trux....you saying maybe i can save on notch buy having a shop that can, make me one for less than i would pay for a notch? |
11-05-2010, 11:45 AM | #20 |
4/6 drops likely won't need a c-notch; 5/7 drops will.
11-05-2010, 01:13 PM | #21 |
Epoxy Primer Friendly
AVS sells this one for 73-87 but it is most likely bigger than what you want/need for a static drop. Just another option.
10-14-2018, 05:04 PM | #22 |
food for thought.
http://www.67-72chevytrucks.com/vboa...d.php?t=457037 edit: oops sorry for the resurection Last edited by catch2otwo; 10-14-2018 at 05:23 PM. |
