Old 11-26-2010, 11:37 PM   #1
joe231
joe231's Avatar
Lowered truck measurements.
I'm trying to figure out how much drop I ended up with on my crew (I didn't measure before). If someone with a 5/5 or 5/7 drop could measure from the center of the wheels, front and rear, to the top of the wheel opening I would appreciate it.
Thanks!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-27-2010, 11:16 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Lowered truck measurements.
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-27-2010, 08:51 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Joe, do you have or need the stock measurements? Neither of my crews are dropped yet. One is an 87 the other an 89.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-27-2010, 10:26 PM   #4
joe231
joe231's Avatar
Thanks for the reply Jason!
Yeah I'll take some stock measurements....
That would be a start.
CHEVY ONLY
Old 11-28-2010, 06:20 AM   #5
babyJay
babyJay's Avatar
I'll get them as soon as the sun comes up.
Jason
89 R3500 CC SRW
Old 11-28-2010, 11:02 AM   #6
babyJay
babyJay's Avatar
I guess if you subtract your measurements from mine it should be a close guesstimate.???
Both years I have are about the same. 21.25-21.5 in the rear and 20.25-20.5 in the front. Theyre both parked in gravel tho, hence the .25 variances. My garage is clogged up with the Elky right now, so I don't have a good level surface to go by.
Jason
89 R3500 CC SRW
Old 11-28-2010, 12:16 PM   #7
joe231
joe231's Avatar
Cool thanks!
I'm @ 5/7 lower than your stock measurements.
Any one with a 1/2 ton lowered 5/7 care to take some measurements?
Thanks!
CHEVY ONLY
Old 11-28-2010, 04:17 PM   #8
baclay9
Hey Joe, now that it looks like you have a confirmed 5/7 drop, how tall are your front tires and what kind of clearance with the inner fender do you have?
baclay9 is offline   Reply With Quote
Old 11-28-2010, 04:24 PM   #9
joe231
joe231's Avatar
Brandon,
I'm 5 and 7 lower then a 1 ton crew
might not be the same as a 5/7 on a 1/2 ton truck
I have a 27" tall tire on the front currently, and I have a ton of room between the tire and inner, I even have room between the tire and the wheel opening. I can go measure if you like.....
CHEVY ONLY
Old 11-28-2010, 04:43 PM   #10
baclay9
No biggie, I didn't realize those measurements were from a 1 ton crew. I thought they were from a 1/2 ton. I knew it seemed like you had plenty of clearance, but your truck seems really low to me. I guess I am just not use to lowered trucks yet. My buddy has a 1/2 ton that is lowered like 1/3 and I feel like I am sitting right on the ground when I am in it. I can't imagine what mine is going to be like @ 5/7. Anyway, I will get off your thread now...
Old 11-28-2010, 04:54 PM   #11
875.3CHEVY
14 and 1/8 front 13 1/2 rear.thats with 5/7 drop
875.3CHEVY is offline   Reply With Quote
Old 11-28-2010, 04:59 PM   #12
joe231
joe231's Avatar
No problem Brandon!
Cool!
Thanks for the info.
Is that 3" spindles and 2" springs in the front and a flip and shackles out back?
CHEVY ONLY
Old 11-28-2010, 05:15 PM   #13
875.3CHEVY
yes 3" spindle 2" springs flipkit and rear shackles.
Old 11-28-2010, 05:19 PM   #14
joe231
joe231's Avatar
Cool
Thanks!
CHEVY ONLY
Old 12-04-2010, 07:58 PM   #15
joe231
joe231's Avatar
So I gather from these measurements that to get a one ton to the same height as a 5/7" 1/2 ton you need to go 6/8"
CHEVY ONLY
