Old 12-05-2010, 10:07 PM   #226
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Grinding all the welds down still. Going back and welding again when I find a hole. First I have been grinding them pretty close with the cut off wheel, then finishing with the flap disk. The whole weld area will end up being lower than the adjacent areas slightly which will make it easy to have a thin layer of filler/ thick primer for blocking out before paint.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 12-06-2010, 10:44 AM   #227
67cheby
67cheby
67cheby's Avatar
looking great
67cheby is offline   Reply With Quote
Old 12-11-2010, 01:05 AM   #228
drewskiren
drewskiren's Avatar
Now we go into uncharted territory.
I really want this truck to be one I WANT to drive, all the time. So I need to make it as functional, smooth, fast, efficient, good driving, and quiet as a new truck. I figured the easiest and best way to go about it was to have as much modern equipment as possible, including the frame and modern suspension geometry. (4 wheel disc with ABS, factory rack & pinion, etc.) So here we are with a 2001 2wd Silverado frame. Problem is, nobody has done any write-ups on something like this. I will be engineering this as I go and could probably use some ideas from you guys here on the forum. Let the comments fly!
First thing I see tonight is the carrier bearing mount is way too tall. (The hoop looking thing.)
Body mounts on the frame aren't needed because the 72 body mounts line up perfectly with the wider new frame rails.
Overall frame length will need to grow by approximately 4 inches.
Too much frame kick up in the rear.
Drew
Old 12-11-2010, 01:12 AM   #229
67chevy1series
67chevy1series's Avatar
best of luck frame work is a lways kinda the most important but not really as fun as body work or putting an engine in, good luck
67chevy1series is offline   Reply With Quote
Old 12-11-2010, 01:25 AM   #230
classicchev
classicchev's Avatar
I personally like the frame portion. Taking the dirtiest part, and reworking with new clean parts and then there a re the details that not very many people will see.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 12-11-2010, 01:34 AM   #231
67chevy1series
true classic chev very true
Old 12-11-2010, 01:57 AM   #232
VA72C10
VA72C10
VA72C10's Avatar
cool! Looking forward to this part!
Old 12-11-2010, 02:40 AM   #233
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You can more than likely ditch the carrier bearing cross member and relocate it how you want and where you need it once you get the rear axle and power train set in the chassis. As for the frame kick up being too high, you could do some figuring and this might be an idea. Right where it kicks up starting before the last cab mount, and before the spring mount, try to find how much kick up you need. Cut the frame at maybe a 45* cut somewhere in that area. Remove some material needed to get the kick up you desire. Cut the other at 45*, bevel each side, weld up, then plate the inside and either bolt this in or weld it in. Then place your rear axle and figure out where you can add your 4" of frame to achieve your desired wheel base. Good luck with this portion of the project. It is coming along nicely!
Ryan
1969 Chevy milk truck
Old 12-11-2010, 10:04 AM   #234
hgs_notes
GEARHEAD
hgs_notes's Avatar
I wonder if the rear section of the frame from a 2001 suburban or tahoe is the same profile. I have a 2003 yukon denali, but haven't looked underneath it much.
hgs_notes is offline   Reply With Quote
Old 12-11-2010, 10:13 AM   #235
67cheby
67cheby
67cheby's Avatar
cant wait to see more of this
Old 12-11-2010, 12:04 PM   #236
drewskiren
drewskiren's Avatar
It will be very different from the truck frame.
Drew
Old 12-12-2010, 11:11 PM   #237
thelonerife
thelonerife's Avatar
Good job on it Drew. Wish I lived closer so I could give you a hand.
thelonerife is offline   Reply With Quote
Old 12-13-2010, 12:14 AM   #238
drewskiren
drewskiren's Avatar
That would be great, if only.
On another note, I will be unable to do much until after Christmas.
Drew
Old 12-13-2010, 05:05 PM   #239
68 TT
Still plays with trucks
68 TT's Avatar
If it is just the location of the kick up being too far forward to work you could section the frame and move the kick up rearward where it will work. Then all you have to do it add some extra material up front to create the wheel base you need.
I did this on my 67 K10 conversion to make a square body chassis fit the body better without need for a body lift.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-14-2010, 08:12 PM   #240
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Jusr read your entire Build & am Quite impressed by Your Build, Excellent Documentation for all who may wish to copy your Design. Also quite Impressed by the Fact that your Family is Involved.......
I Really enjoy my Current 86 Crew Stepper & One of my long term goals is to Have a 67-68 Style Crew Stepper some day, I have been collecting parts for a couple yrs now & Hope to Start sometime in next yr or so........
Here is a Pic of my 86 Crew Cab & a Photo Shop of what i hope my 67-68 Crew will come out Like......
Thanks & Merry Christmas.
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 12-14-2010, 10:49 PM   #241
drewskiren
drewskiren's Avatar
I have been studying this a lot and it would be cake if I was building a 4wd. Building a lowered truck makes it very hard. I think now I will have to employ an old hot rodders trick and "channel" the body down over the frame. I will need to do this on the bed section only and will only channel the bed cross braces on the bottom of the bed for 2 inches, not the entire bed floor. Also will need to take out 3 inches off of the frame rise.
What I think I know so far:
99-2006 frames have a 9.5 inch rise or kick up for the bed.
The bodies on these trucks really hang down over the frame.
The new truck frame is 2 inches taller than my old frame, 4 inches wider.
67-72 truck bodies only hang down over the frame about 4.5 inches, so I need to keep the cab as close to the frame as possible to help hide the taller frame.
Old truck frames only kick up about 4.5 inches, So I need to come up with 5 inches of bed drop some how. (if I mounted the body and bed how they are now, the bodyline would be off by 5 inches)
All of these numbers are preliminary and will probably be adjusted somewhat.
Drew
Old 12-14-2010, 11:15 PM   #242
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Rick
Or maybe an 8 footer??
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-14-2010, 11:34 PM   #243
67chevy1series
wow that is too long
Old 12-15-2010, 01:40 AM   #244
trukzguy
trukzguy's Avatar
Build looks awesome,keep up the great work. Its getting me motivated.just subscribed.
Jay
Barrhead,Alberta,Canada
1967 GMC 400sb
Porterbuilt stage 2 front and rear suspension
http://67-72chevytrucks.com/vboard/s...d.php?t=419519
trukzguy is offline   Reply With Quote
Old 12-15-2010, 09:54 AM   #245
ERASER5
ERASER5's Avatar
That always cracks me up! Trucks, the only time a guy will say "Mine's shorter than your's!"
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-15-2010, 10:23 AM   #246
JohnC
JohnC's Avatar
JohnC is offline   Reply With Quote
Old 12-15-2010, 10:42 AM   #247
Splash4195
Very cool!
Splash4195 is offline   Reply With Quote
Old 12-15-2010, 05:12 PM   #248
Dieselwrencher
That looks perfect.
Ryan
Old 12-15-2010, 06:09 PM   #249
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Doesnt the red one look like it had a dodge pu grafted on the back of the cab ......?
ksbrktracer is offline   Reply With Quote
Old 12-15-2010, 07:38 PM   #250
Dieselwrencher
That's just how they look when a surburban is cut down to a crew cab and the high roof is left.
Ryan
