12-03-2010, 09:41 PM | #26 |
But Found Her 25yrs Later!
Re: My 66 Service Truck Build Thread
350 is in:
. . I originally intended to go with the newer mounts and the 79 exhaust, but then decided to go with RamHorns and the traditional mounts. I didn't want to go into modding so much at this time - My primary goal this winter is to get back up and running. Maybe this summer, when I pull the cab, I may do the mods needed to use the newer mounts. Here is the thread where I was helped by CaptainFab regarding the newer mounts: http://67-72chevytrucks.com/vboard/s...d.php?t=432176
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-03-2010 at 09:45 PM. |
12-03-2010, 10:10 PM | #27 |
Senior Enthusiast
Very cool truck, I’m glad you saved it and have a fun project for such an affordable price. I know about the difficulties making progress in the cold. When I did my front suspension swap years ago, it took me almost a month because the temps ranged from 10 below zero to a high of 18 above. I dressed like the kid from “Christmas Story”, and even then could only last about 20-30 minutes at a time.
I like the idea of the service bed, it’s certainly practical if you have an interest in something like that, and they are rarely seen any more. Are you intending to keep it this configuration, or switch to a conventional step or fleetside model? Looking forward to more progress updates. |
12-03-2010, 10:26 PM | #28 |
The Service Box is original - yep!
It was a County truck. The Original Paintjob is County Orange. You can see it there on the firewall in the pic above. The service box is also county orange under the black. I used to be a carpenter, I had an 81 chevy with a Service Box, and I loved it - everything where you need it. Even years after I moved on to Architectural Design, I still had the 81, with all my tools in it. I'm keeping this thing with the Service Box. Then when I find my 65, I'll have this truck for running for parts and to the wrecking yard. Atleast, that's my long term goal. Either way, I can see this thing looking really cool, and particularly unique with the Service Box. Can you visualize deep wide wheels under that box?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-03-2010 at 10:31 PM. |
12-03-2010, 10:35 PM | #29 |
what is architectural design?
ron |
12-03-2010, 11:02 PM | #30 |
I'm sorry,
I now do Architectural Home Design / House Plans / AutoCad.
12-04-2010, 04:27 PM | #31 |
I miss Autocad. I did mech engineering.
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. |
12-07-2010, 05:43 PM | #32 |
Maybe someone can help me with this latest issue;
While working on my 66, I seem to get really sore and tire much quicker than when I worked on my 65 back in 84. Did something change on these trucks from 65 to 66?
12-07-2010, 07:27 PM | #33 |
The 60-66 GMC/Pontiac guy....
Welcome to my freaking world
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
12-08-2010, 11:50 PM | #34 |
Hooking things back up.....
Got help regarding all the hose clutter here: http://67-72chevytrucks.com/vboard/s...d.php?t=434796
12-14-2010, 12:27 AM | #35 |
Just bought this today:
8-Lug Discs . Thanks to those who posted in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344516
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-14-2010 at 03:20 AM. |
12-17-2010, 11:17 PM | #36 |
Still hooking things back up.
Moving onto the wiring this weekend. It's amazing how hacked up the wiring gets on these old trucks over the years. Again, my goal is to get back up and running. So, on my down the road todo list will be to clean up the wiring.
12-17-2010, 11:41 PM | #37 |
My links for future reference:
http://rmcavoy.freeshell.org/Truck_gauges.html http://www.64moneypit.pages.qpg.com/...cks/index.html
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-20-2010 at 09:34 PM. |
12-18-2010, 10:40 AM | #38 | |
12-22-2010, 04:33 PM | #39 |
Momma Tried.
Looks great man. I really hope you find your 65.
Ross 1980 c10 4x4 project (Sold):http://67-72chevytrucks.com/vboard/s...d.php?t=377155 1999 F-150 4x4 (DD) Saving up for a 64 17 and loving it. |
12-22-2010, 04:56 PM | #40 |
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
12-25-2010, 09:51 PM | #41 |
Well...
I'm pretty stoked! Fired the 350 up today - just a couple cranks, and it fired right up. I am having an idling problem; fluctuating quickly up and down. I'm guessing it's starving for fuel. I'm thinking this because as I close the butterfly the engine smooths out and idles good. . . I'm off to search the forums to see if I can find a solution.
12-25-2010, 10:21 PM | #42 | |
Searching the forums gets me thinking I have a vacuum leak somewhere:
I removed a lot of emission hose garbage, and the engine idles out smoothly when I close the butterfly as in the pic I posted above.
12-25-2010, 10:52 PM | #43 |
that "butterfly" your fooling with in the pic is your choke... check your vacuum lines, sounds like you may have a slight leak if nothing else has changed it sounds like the culprit...
12-26-2010, 01:45 AM | #44 |
60-66 Nut
Yep, sounds like a vacuum leak to me. Check all the ports on the carb, including on the back.
12-26-2010, 02:16 AM | #45 |
^thanks guys.
First thing tomorrow, I'm going to check all the ports - including the back. Searching the forums I found a couple ways to test and find vacuum leaks. If I can put a rag over the top of the carb, and the engine keeps running, then it's surely a vacuum leak. But even so, I'm still going to do the suggestion posted in the forums on how to find the leak. That is to spray carb cleaner at one location at a time, if the engine races, then that's where the leak is. I actually knew about spraying carb cleaner to find leaks, I had just forgot about it. I'm getting old.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-26-2010 at 02:22 AM. |
12-26-2010, 01:25 PM | #46 | |
I would suggest using what you have for now and saving your $ getting a period correct carb, a 67 Rochester 4bbl.
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac Last edited by 66-PMD-GMC; 12-26-2010 at 01:26 PM. |
12-27-2010, 01:21 AM | #47 |
Ok, I found the issue.
After re-checking all hoses, and spraying carb cleaner to check for leaks, all was good - no leaks. So back to the forums I searched. After more searching, I read it could be a bad EGR Valve. The solution was to either buy a new EGR Valve, or create a block plate - I created a block plate out some sheet metal. . All is good now. It idles so smooth I took it for a short run up the road and back - runs great - drives like a Tank. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-27-2010 at 03:45 PM. |
12-27-2010, 01:29 AM | #48 |
Momma Tried.
Glad you got it running man.
12-27-2010, 11:34 PM | #49 |
I have a lot of play in the steering.
After some checking, I found the issue is related to the Pitman Arm. I'm now leaning toward just doing the conversion to power steering. (the 63-66 arm is pretty pricey) . (When I go to do the power steering upgrade, I'll most likely get the adapter bracket from Captainfab)
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-28-2010 at 02:33 PM. |
12-28-2010, 09:14 PM | #50 | |
So yes, I surely have an interest in service bodies. Good thing about the 81; I sold it to a friend over in Bend, Oregon. My wife thinks the service body is ugly on this 66, but I just like the practicality of it so much, I'm keeping it. Especially because it came from the factory with it, built special, and painted counted orange.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-28-2010 at 09:15 PM. |
