2007 duramax won't start/strange codes???
Hey all...My work truck has been in and out of the shop for this problem. It starts with a service 4wd and service trailer brakes code. Then out of the blue it shuts down and will not start. All the power accessories work but when the ignition is tried....nothing...doesn't turn over, just dead!? If anyone has had this issue, and knows what it could be...please let me know.
Thanks, A........
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
Re: 2007 duramax won't start/strange codes???
look and see if the wiring harness above the front drive shaft is rubbing the shaft.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
I'll check it out, thanks.
A.......
Well...all the wiring around the front drive shaft looks nice and neat like from the factory??
I tried disconnecting the batteries for a few minutes, but still wouldn't start when re-connected... thanks for the tip, but must be in the computer? A..........
