Old 12-23-2010, 11:08 AM   #101
Dirty Doug
Dirty Doug's Avatar
Re: Extreme Powder Coating '65 C-10 Shop Truck
Hmmmm , big window. Didn't we talk about this before..... LMAO.
Dirty Doug is offline   Reply With Quote
Old 12-23-2010, 03:22 PM   #102
kart34
New Carter Hickman Design! All new pics of the interior done by Lakeside Rods and Rides!
kart34 is offline   Reply With Quote
Old 12-23-2010, 03:26 PM   #103
Dirty Doug
Dirty Doug's Avatar
Cool Homie !
Old 12-23-2010, 03:40 PM   #104
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Nice build! Lovin the modern touches with the old patina!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-23-2010, 03:40 PM   #105
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Nice!!!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-25-2010, 01:21 AM   #106
Dinos63
chevy only
Dinos63's Avatar
i love this build soooooo cool duudes !!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-25-2010, 01:32 AM   #107
kart34
Thanks Dino
Old 12-25-2010, 04:09 AM   #108
67chevy1series
67chevy1series's Avatar
love the patina . take some CLR and a green brilo pad adn scrub the whole truck down and then wash it it will look beautiful just a thought
67chevy1series is offline   Reply With Quote
Old 12-28-2010, 02:02 PM   #109
kart34
Talking Re: Extreme Powder Coating '65 C-10 Shop Truck
Final Composite Sketch from Carter Hickman - Very cool!
Old 12-28-2010, 09:55 PM   #110
Blue Heeler
Blue Heeler's Avatar
Kart34, my welding company is called Extreme Steel. welding, fabricating and
repairs. I'm doing the same as you kinda, 4inch drop 450hp motor and also it's
blue. i'll be sticking my welding machine on there too. keep up the good work!!
Blue Heeler is offline   Reply With Quote
Old 12-29-2010, 12:41 PM   #111
kart34
Kool Good Luck with your project.
Old 12-29-2010, 12:48 PM   #112
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
This is a awesome build man
Sweet work, keep the pics coming
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 12-29-2010, 12:49 PM   #113
kart34
Boxing the frame. Check out the Alum. Howe racing caliper duel piston
Old 12-29-2010, 01:19 PM   #114
Apache63
1# Drobmember in Germany
Apache63's Avatar
I like the way you build it!!!!!!
Can´t wait to see more!
Pat
Pat
Apache63 is offline   Reply With Quote
Old 12-29-2010, 01:26 PM   #115
1963chevyshort
New Member
1963chevyshort's Avatar
Awesome build. Wow will be a bad ride when you get it all done
Anthony
63 chevy stepside SWB
57 chevy 2dr hrdtop belair
1963chevyshort is offline   Reply With Quote
Old 12-29-2010, 01:40 PM   #116
kart34
Doing a little grindage, getting the frame all smoothed out
Old 12-29-2010, 02:42 PM   #117
kart34
Final Draft from Carter Hickman - Finished trim and hub caps
Old 12-30-2010, 08:04 AM   #118
Coming along real nice!
Old 12-30-2010, 05:25 PM   #119
kart34
Cool Re: Extreme Powder Coating '65 C-10 Shop Truck
Custom Fab Work Lakeside Rod and Rides
Frame Almost ready for Epoxy PowderCoat Prime
Old 12-30-2010, 05:28 PM   #120
jimmydean
jimmydean's Avatar
So what color is the frame getting shot?
<edit> While I'm partial to traditional chassis black, we shot a friends '67 Bronco frame in Cardinal's Safety Yellow and it was a bomb proof finish.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-30-2010, 06:59 PM   #121
blackmopar
alot of very impressive mods there! love the grill and gate treatment!
blackmopar is offline   Reply With Quote
Old 12-31-2010, 10:19 PM   #122
kart34
we are undecided yet on the powdercoat color ??? We will do some sample panels next week. Stay tuned ???
Old 01-02-2011, 02:02 PM   #123
kart34
We are cruising down to Lakeside Rods and picking up the cab Monday. Will post new photos Tuesday.
Old 01-02-2011, 07:19 PM   #124
Fat Mike
Fat Mike's Avatar
Custom Speed Holes ( dimple dies) by metal ace Dan Pate RTE.56 Rod & Custom
That is a very nice frame. I have a couple questions for you thou. What does the dimple die look like that you are using. Is it a hydralic or a mechanical press? Also does your frame have any drain holes incase you get water in those holes or do you plan on enclosing them with tubing? With such an entensive dimple die job could you still have some kind of cage on your frame. I'm sorry for all the questions but like to know everything before trying my ideas. I just started a build under a different category and look to this one for major fabs but I am still at a novice level. Thanks for any info in advance.
Fat Mike is offline   Reply With Quote
Old 01-02-2011, 08:21 PM   #125
kart34
Mike, Dan Pressed the dies in a hydaulic press. We also did a few small parts at my shop with a small shop press. I purchased this die on e-bay 2 inch . Also the frame has drain holes .
'65, c-10, carter hickman designs, extreme powder coating
