Old 10-05-2010, 01:49 PM   #26
FL71C10
Re: 69 Camaro Gas Tank Install
Nice build and info, guys. Any reason this wouldn't work on a stepside?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is online now   Reply With Quote
Old 10-05-2010, 05:28 PM   #27
67Slider
67Slider's Avatar
Mine is a stepside. Works fine.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 10-05-2010, 05:31 PM   #28
madmopar
This guy has got to be stopped
madmopar's Avatar
Cool idea - i like the license plate fill a lot better too...
I'm currently doing a similar install of a 68 roadrunner tank. Its a longer narrow tank (would fit between the rails), wheras the camaro tank is wider. It might not work for shortbeds though, as it is longer. I'm curious to see yours (and mine!) with the bed back on.
I'm going to run into a problem with my sending unit being wrong though (73-10 ohms) dodge versus chevy (0-90)... I'll have to deal with that later - modify the sending unit or aftermarket gauge...
J P Evers
1970 4x4 LWB project: http://67-72chevytrucks.com/vboard/s...d.php?t=415134
madmopar is offline   Reply With Quote
Old 10-29-2010, 10:25 AM   #29
GMCBubba
GMCBubba's Avatar
i'm assuming that this type of gas tank relocation would not allow the use of a trailer hitch like this (http://sitepro12.sitepro.com/masterl..._13028_INS.pdf). what do you think?
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 10-29-2010, 07:27 PM   #30
swamp rat
swamp rat's Avatar
Any tank would have to fit between the rails for it to work with a hitch.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-02-2011, 07:18 PM   #31
67Slider
67Slider's Avatar
Here are a couple of pics with the bed bolted in. No clearance issues.
[IMG][/IMG]
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-02-2011, 07:28 PM   #32
sjarrett71
sjarrett71's Avatar
What is the capacity of the camaro tank?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-02-2011, 07:30 PM   #33
67Slider
67Slider's Avatar
18 Gallons
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-02-2011, 07:31 PM   #34
sjarrett71
sjarrett71's Avatar
Originally Posted by 67Slider View Post
18 Gallons
Thanks. I tried to get back to my post and edit it but you answered too quickly. I went back and read the first post and said "DOH!!"
-Scott-
Old 01-05-2011, 01:55 AM   #35
stepstep67
whats up 67slider i actually have an el camino bumper do u think the camaro gas tank wud still wrk?
stepstep67 is offline   Reply With Quote
Old 01-05-2011, 11:19 AM   #36
67Slider
67Slider's Avatar
I would think so. You would just need to do a good mock up to figure out how much of a spacer you need. That is the key to making it work.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-05-2011, 12:09 PM   #37
Critter
Future TOTM Winner
Critter's Avatar
The only thing I might do different is the license plate door. It looks like you have the spring loaded one that when you let go would pop back up. Some models have a break-over point so that once opened they stay in that position until you nudge them back closed. I forget the exact model of car but I pulled a couple on my last junk yard trip. Might make filling up a little easier for you.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-05-2011, 12:46 PM   #38
67Slider
67Slider's Avatar
I totally agree. If you remember the model/year where you picked up the license plate holder that stays open pass it on. I would change mine out too. Looks like I may be spending an afternoon at the wrecking yard!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-05-2011, 06:02 PM   #39
Critter
Future TOTM Winner
Critter's Avatar
If I remember right they were from a mid to late 80s Caprice, Pontiac Parisienne, Olds Delta 88, etc. I am positive they were from GM sedans at very least. Here are some pics. Notice how the hinge breaks over and stays in place. They could be mounted up or down. I plan to use mine for hidden hitch purposes. Incidentally, these pics are of the backside, the license plate side is face down.
Old 01-05-2011, 06:45 PM   #40
67Slider
67Slider's Avatar
I'm down for one of these. I am going to see if I can find one. I mentioned to one of the other guys that the hinged door flips up and kind of gets in the way. This would certainly fix that issue.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-05-2011, 07:25 PM   #41
Critter
Future TOTM Winner
Critter's Avatar
Glad I could help. If you do find one report back and confirm what model it came from. That way the rest of the world can know from now on.
Old 01-06-2011, 01:16 PM   #42
tolly4503
I had a '90 Cadillac Fleetwood brougham, the fullsize caddy. it had the flip down plate holder that held itself down. They made those cars til '92.
tolly4503 is offline   Reply With Quote
Old 01-06-2011, 01:52 PM   #43
c10/72
c10/72's Avatar
That is pretty slick...I wish I had seen this thread before I did the conversion on my 72 short wide...looks great.
c10/72 is offline   Reply With Quote
Old 01-06-2011, 06:28 PM   #44
Hubscrub
Cruzin
Hubscrub's Avatar
this really has me thinking about relocating my tank i'm happy with it in the cab just wish i had the behind the seat room for storage. I'm not a big fan of the other ways
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 01-06-2011, 06:57 PM   #45
Valhalla
Valhalla's Avatar
Great thread I am thinking about this over the $500 aluminum ones that mount in the bed.
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh
Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own.
SqueegeeMan
Valhalla is offline   Reply With Quote
Old 01-07-2011, 01:27 AM   #46
stepstep67
thanx so it wud probably be slightjly difrent because of the diferent bumper. you use the 2by3 metal tubing right?
Old 01-07-2011, 08:07 AM   #47
67Slider
67Slider's Avatar
Yes. I used wood blocks to mock it up in 1 inch increments until I found the right height for my application.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-07-2011, 09:09 PM   #48
67Slider
67Slider's Avatar
Ok Guys. I went to the yard today and picked up a new license plate holder. It came off a 92 Caprice (old cop car). Works awesome. Thanks for the heads up on this one. Here are some pics and a shot of the tank from up my driveway and from the side.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-07-2011, 11:09 PM   #49
Critter
Future TOTM Winner
Critter's Avatar
...It came off a 92 Caprice (old cop car). Works awesome. Thanks for the heads up on this one.
Well I was right about the model of car but wrong on the year model. Glad it worked out for you. Looks like the tank swap in general turned our very nice!
Old 01-07-2011, 11:39 PM   #50
Kidd-7
Kidd-7's Avatar
Any idea on using this setup on a chrome bumper? I'd hate to fork over the $$ for chrome and then cut a hole in it.
Kidd-7 is offline   Reply With Quote
