Drive shaft lengths
Are the 2 piece drive shafts the same lengths in small block and big block 2wd, LWB's?
Fabricate till you "puke"
Re: Drive shaft lengths
No, due to differences in engine positioning, the shafts are not the same lenght. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Thanks. So the engine sits farther back with the 72 BB mounts?
This was the only thing I didn't mock up since I was using stock parts and it seems to have bitten me. |
will probally b different yokes too as BB mostly used th400 and SB mostly th350 for auto trannys
