Old 01-18-2010, 10:53 AM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
To the current and future 700R4/4L60/4L60E swappers, a must have part to install.....
For anyone doing this swap.... a Vette servo for the trans is a definite must-have! I finally got around to installing mine this weekend, and I can't believe what a difference it makes! 1-2 shifts at WOT will bark the tires, and 3-4 is very snappy. Although this mod mostly affects the 1-2 and 3-4 shifts, I can definitely tell that the 2-3 shift are much firmer also.
These literally take 15 minutes to R&R, and take no special tools. A pry bar, a couple small screwdrivers, a c-clamp, and a pair of pliers or channel locks. It really helps if you have a helper around when putting it back together to help get the cover back on, but it can be done alone.
The servos can be bought off eBay for around $20. I got mine from Oregon Performance Transmissions off of eBay, and have bought many other trans parts from them, including a stall converter several years ago. They have good quality parts. In fact, I think the Vette servos are TransGo parts.
These can be installed easily enough while in the vehicle, but save yourself a little time and effort and do it while the trans is still on the shop floor. You won't be sorry!!
Here is a great how-to:
http://www.gmfullsize.com/forum/showthread.php?t=98029
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-18-2010, 12:20 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: To all the current and future LS/4L60E swappers, a must have part to install.....
Thanks for the info Bob.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-18-2010, 01:13 PM   #3
Jim85IROC
Jim85IROC's Avatar
Same deal for anybody running a 700R4. The Corvette servo makes a very noticeable improvement in shifts.
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 01-18-2010, 01:26 PM   #4
glock35ipsc
Doh, I didn't even think of the 700R4 and the 4L60! I changed the title. Thanks!!
Bob
Old 01-18-2010, 02:18 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: To the current and future 700R4/4L60/4L60E swappers, a must have part to install.
I have done this before and it is WELL WORTH EVERY PENNY. Definate improvement over stock. Cheap too.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-18-2010, 02:55 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Yup I had one before blowing up the last 700R4. Loved it. The current tranny has a super servo! Now that one is a neck snapper!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-18-2010, 08:35 PM   #7
qu1cks1lver56
qu1cks1lver56's Avatar
anything simple like this for a TH350?
I plan on buying a shift kit before too long, but they're not cheap.
qu1cks1lver56 is offline   Reply With Quote
Old 01-18-2010, 09:04 PM   #8
gchemist
gchemist's Avatar
You can install a governor on the transmissions too. WOT will shifts will be higher. Corvettes and police cars had the option.
You can find parts at www.bulkpart.com
My 700R4 is modified to shift into OD at WOT!! I have not tried it yet. I've made it up to 110+ MPH in third gear before letting off. I'm curious at what speed it should shift into OD.
Old 01-18-2010, 09:59 PM   #9
truckincurt
are you talking about torque converter lockup ? you cant wire od it just shifts in to od after 3ed gear but you should wire up tc lock up in 4 gear thats how i have mine and its fine cuz most of the time you arnt on throttle in 4th just cruzin but you can allway put a toggle switch inline to turn it off for those high speed runs and toggle it back on
diy or die
truckincurt is offline   Reply With Quote
Old 01-18-2010, 10:12 PM   #10
3r!c84
Badass
3r!c84's Avatar
just a shift kit ): but you can mess with the governor screw a little for a harder shift
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-19-2010, 12:34 AM   #11
LEEVON
LEEVON's Avatar
yep, I prefer the servo over a shift kit. All of our vehicles have one. They just feel so right. My '08 silverado will bark the tires on a cold morning with the vette servo.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-19-2010, 12:37 AM   #12
chevymotocross
chevymotocross's Avatar
Corvette Serve was easy to install and did wonders for my shifts..... until I later decided to do a filter/fluid change and then the shifts went all downhill from there. A rebuild is in the works soon.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 12-27-2010, 11:41 PM   #13
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Will this work on a 4L80E ??
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-28-2010, 12:19 AM   #14
spudz
spudz's Avatar
700s have governors, you can shave some weight off them to hold shifts a little longer. or you can buy aftermarket but you can grind some weight off the stock and do the same thing. IF you REALLY want it to snap into gear... put a billet super survo in it. It will knock your head threw the back glass.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 03-27-2011, 12:03 PM   #15
Rokcrln
Rokcrln's Avatar
I have a question about this mod on a 4L60E. I just finished my 05 5.3L install in LowBuk and it all works great. The shifts are very smooth from gear to gear but I can feel the smallest about of slip during the transition from gear to gear. I would like it a bit tighter but I really do not want to feel any shift bang from gear to gear like I had with my built 700R4. Will this mod keep the very smooth shifts or will it have the affects of a shift kit?
Thanks for the info!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-27-2011, 04:47 PM   #16
Brian76GMC
Brian76GMC's Avatar
Is there a how-to on T350 - 700R4 swap somewhere?? My 79 Chevy has 3:73 gears and Im considering doin the 700R4 deal.
79 Chevy Big 10
350/T350
My GMC's that I sold
Brian76GMC is offline   Reply With Quote
Old 03-27-2011, 05:39 PM   #17
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
my 700 has a corvette servo as well as an actual corvette shift kit, its barked the tires going into 4th gear like twice since modding it. itll almost ALWAYS put the truck sideways shifting into 2nd and majority of the time i can bark into 3rd
Heres a video of it on a VERY WELL prepped track that nearly pulled my shoes off when walking on it
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 03-27-2011, 10:49 PM   #18
gchemist
gchemist's Avatar
Did you remove the grill turn signal lights? Nice video.
Old 03-27-2011, 11:24 PM   #19
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Does the vette servo effect part throttle shifts? After 15 years of my B&M shift kit shifting hard at anything over half throttle, i'm looking for a smoother shift.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 03-28-2011, 12:59 AM   #20
ProStreet83C10
Drag Racer
never had grille lights
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 03-28-2011, 03:20 AM   #21
Vernski
Hey thanks gchemist for the link to www.bulkpart.com I couldn't find oregon performance trans anywhere on ebay, I did find some servo's but don't think they were the right ones....Vernski
Vernski is offline   Reply With Quote
Old 03-28-2011, 05:53 AM   #22
S10Fan
Old Heap Driver
I agree. My transmission guy includes the Vette servo and converter in all his 700 builds. 99% of his builds are for street rods etc.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod.
S10Fan is offline   Reply With Quote
Old 03-29-2011, 04:13 AM   #23
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
So this can be done for the 4L60/4L60E Trans??
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 03-29-2011, 04:57 AM   #24
jitteryguy
GoatLube Experss
jitteryguy's Avatar
o the subject of 700R4's , has any heard of this company ?
http://monstertrans.com/store/catego...-Rebuild-Kits/
any thoughts or comments bout them or there product's ? I wanna rebuild the 700R4 in my S10, also put one in the dually and a '78 Cutlass I'm gonna restore for my girlfreind.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-29-2011, 11:56 AM   #25
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Monster Transmissions`
I bought a 2000 stall torque converter from them a few years ago, and I was really happy with their service. Nice, friendly folks.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
