Old 04-06-2011, 12:39 PM   #1
Joe Chasse
Joe Chasse's Avatar
Post HYDRO-VAC brakes. Who knows about these?
I need some help. I am installing the hydro-vac brake system (mc, pump, etc) from the 76 Chev 1 ton donor truck into my 65 1 ton Chev. Does anyone know where I can get info on the Hydro-Vac systems?
Thanks in advance,
joetruckATgmail.com
Joe
Joe Chasse is offline   Reply With Quote
Old 04-06-2011, 12:41 PM   #2
71swb4x4
71swb4x4's Avatar
Re: HYDRO-VAC brakes. Who knows about these?
Check out the last page: http://67-72chevytrucks.com/vboard/s...d.php?t=327476
We are doing this swap right now on my 67. What questions do you have? I am not very smart, but I may be able to help a little. My friend Todd (68c15) was the brains behind the swap so he may need to answer technical questions, but I will help where I can.
Are you swapping the discs too?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-06-2011, 01:24 PM   #3
duallyjams
duallyjams's Avatar
Some where in the middle of the thread http://67-72chevytrucks.com/vboard/s...d.php?t=431033 is a hydro boost install with a diagram.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-06-2011, 01:27 PM   #4
Joe Chasse
Joe Chasse's Avatar
Looks like a great old work truck 71swb4x4, and probably just what you need for your job.
About the hydro boost brakes, I just never worked with them before and don't even know to where from where the hoses should go. Mine came from a 76 C-30 van (motor home), and did not get to see the actual hose runs.
I just took out a pretty new booster and dual hole master cylinder (MP Brakes Co.) that I put in when I put in the 78 disk brake parts (with all new seals and bearings) because I never COULD get it to work right (it will end up on Ebay one of these days).
If you are pulling off the front sheet metal from the truck, would it be possible for you to email me a picture of the rubber hose runs for the brake system?
I am also going to put the rear end from the 76 in as the brakes are MUCH wider and will match up to the 350/350 from the same donor truck.
HERE'S A LINK to pic of my rig.
Thanks,
Joe
Old 04-06-2011, 01:42 PM   #5
Joe Chasse
Joe Chasse's Avatar
THANKS duallyjams! I will snoop through the thread to see what I can find.
This is turning out to be a great messageboard! Along with the one over at Chevytalk, we have just about got it covered!
Thanks again,
Joe
Old 04-06-2011, 02:32 PM   #6
71swb4x4
71swb4x4's Avatar
My truck is about an hour away, we are going to get it Saturday. I can get you whatever pictures you need after that.
Old 04-06-2011, 03:08 PM   #7
Clyde65
Clyde65's Avatar
Joe,
I love your camper/C30, that is way cool.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-06-2011, 03:26 PM   #8
Joe Chasse
Joe Chasse's Avatar
Thanks Clyde. I have updated some things, but mostly 80,000 mile original as it was built. I have added solar panels to the roof, replaced interior 'tail light bulb' lights with fleuros, swapped out the truck seat for '02 tahoe seats with built-in shoulder belts, front disk brakes, etc. etc. Kept the split rims, as they don't scare me a bit, and most tire shops have a cage. Presently installing a 76 4 bolt main 350/350 and rear end from donor truck. Hoping to run across a tilt tele steering column before I get to installing steering...
Old 04-06-2011, 03:38 PM   #9
Clyde65
Clyde65's Avatar
Man, you rock! I wish we were closer to ya, would love to experience your camper 1st hand.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-06-2011, 03:50 PM   #10
bubba327
HOW long until spring??
bubba327's Avatar
Subscribed and watching.. I have heard the Astro van had a hydro boost that is also a good candidate. I understand most any GM diesel truck or surburban had hydro boost.
This project is on my to-do list.
Captain fab makes a adapter bracket AS seen in this thread http://67-72chevytrucks.com/vboard/s....php?p=3671027
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 04-07-2011, 01:45 AM   #11
Captainfab
60-66 Nut
Wow that is a very nice looking camper.....very cool
We've not seen any of these on the forum in the past, but in the last week or so we have seen 2 now.
I know where there was one of these last year....I wonder if it's still there.....hmmmm.
Old 04-07-2011, 06:31 AM   #12
A.T. RockDriller
A.T. RockDriller's Avatar
here's mine....
answers are sure free.
it is worth the effort.....
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-07-2011, 08:40 AM   #13
duallyjams
duallyjams's Avatar
Are you upgrading to power steering also ? if you do make sure to use a oil cooler for the hydro set up.
James
IG duallyjams
Old 04-07-2011, 10:35 AM   #14
Joe Chasse
Joe Chasse's Avatar
Thanks for the pictures Les! Jams, I think mine has power steering and brakes all rolled into one system. I am guessing it will need a "tee" in the return line as someone mentioned earlier.
I did drive the 1976 Chevy C-30 donor rig in and it had power steering and brakes, but I don't remember removing a cooler other than the old trans cooler that was in front of the radiator...
Old 04-07-2011, 03:09 PM   #15
duallyjams
duallyjams's Avatar
I just know power steering by ti self is fine and hydro by it self is fine but when you put the two together it builds up a lot of heat. All the 1 tons that I've seen all have a cooler. It's just a tube that makes a loop with some fins,
James
IG duallyjams
Old 04-07-2011, 03:28 PM   #16
Clyde65
Clyde65's Avatar
sounds like good insurance JOE!
Clyde65
Rebuild of Clyde
support our troops!
Old 04-07-2011, 03:39 PM   #17
A.T. RockDriller
Joe....
To put it briefly....It aint to tough.
If you use the remote reservoir/fill like mine, you shouldn't need an auxiliary cooler.(but like Clyde & DJ state....cheap ins..)
Also I was ordering a seal kit for my pump and the parts jockey said that the Astro/Safari booster is different than the full-size set-up......dont know what.
The pump from any full-size van or motor-home will have the remote set-up and that's what I was lookin' for.....
As far as the return lines go, all hydro-boost pumps have an extra nipple for your brake return line. That way there are no plumbing issues to worry about.
The return from the p-steering box goes to one and the rtn. line from the brakes goes to the other. If it were me....which it was,.....I would use anti-abrasion cover wherever possible.....stuffs pretty inexpensive for the advantages it provides.
I had to fab my pump mounting brackets because I sure had trouble finding a fit for the 305 V-6. Other than that it was pretty simple.......used the same pressure lines from the doner............ and that's all she wrote.
Here's a couple pic's of the top-side.
Les Hunter
Old 04-07-2011, 05:15 PM   #18
71swb4x4
71swb4x4's Avatar
When I pulled my setup off the 75 it didn't have a cooler. It was a hydro/ps setup that we swapped right over.
Les the pulley on your PS pump is too small for your belt, your belt should sit in your pulley a bit more.
Mine was the same way, we swapped the pulley from my old pump and that fixed it.
I don't know if it will ever cause you problems, just thought I would point it out.
Old 04-07-2011, 06:20 PM   #19
Joe Chasse
Joe Chasse's Avatar
I HAD to have taken a pump off the 76 C-30 van chassis that I got all this stuff from, but da**ed if I can find it! Here is the MC I plan to use:
and HERE is the steering gear from a 78 C-30 pickup:
THIS is the pump/reservoir from the '65 power steering:
and THESE are two 'mystery pulleys', one from the '65 and one from the '76 C-30 van donor. Don't know right now which is which.
If there WAS a steering pump/tank on that old van chassis, it HAS to be out there somewhere...of course, maybe the pump from the old '65 would do?
Thanks SO MUCH, you guys are the most helpful bunch of gearheads I have ever met!
Joe
Old 04-07-2011, 07:36 PM   #20
Joe Chasse
Joe Chasse's Avatar
I spent this afternoon turning everything upside down out in the shop and can not find that pump from the donor truck. My only guess is that when I hauled scrap metal a couple weeks ago it got itself into the ferrous pile somehow and is long gone...The pump from the 65 ran a cute little hydraulic ram down on the tie rods, I wonder if it would work with this "modern" 1978 PS gearbox?
Old 04-08-2011, 02:50 PM   #21
A.T. RockDriller
Thanks Short-Wide.
I usually keep the rpm's under 7k or so ...so it hasn't caused me any grief so far.
I actually had to settle for the 5/8" belt for now....I'll eventually deal with it....just have to special order the right one someday.
I sure will do it though.
What do ya'll think of these hub-caps ....
They look pretty good in person compared to the wagon wheel rim look.
Les Hunter
Old 04-08-2011, 05:16 PM   #22
duallyjams
duallyjams's Avatar
1 ton step vans have a t in the return line and hence the cooler also. Ask ten people a question and you will get ten different answers.
James
IG duallyjams
Old 04-08-2011, 05:44 PM   #23
bubba327
bubba327's Avatar
So if the hydro vac pumps have two return ports, one for the return from the hydro vac and one returning from the power steering gearbox , And you wish to add a remote cooler, which line would you plumb it in??
The stock cooler went after the PS gearbox in the return line to the pump.
If the return line was tee'd ...I would put it after the Tee so all fluid could be cooled. If two separate returns are used only half of the returning fluid would be cooled.
Any ideas?? Or is this even a problem?? Which would get hotter?
Old 04-08-2011, 06:15 PM   #24
duallyjams
duallyjams's Avatar
The cooler goes in the return line from the gear box .
James
IG duallyjams
Old 04-08-2011, 06:21 PM   #25
duallyjams
duallyjams's Avatar
page 3 post 65 has a hydro boost diagram
James
IG duallyjams
hydro-vac, hydrovac
