Old 04-13-2011, 06:37 PM   #1
1966Stepside
1966Stepside's Avatar
5.3l engine knock
My truck has been popping Bank 2 Knock Sensor codes for the last week or so. I get them reset and it comes back the next day. Was going to just replace the sensors, but wanted to upload a video and see if I actually have any engine knock. I hear some noise, but I'm thinking it could just be valvetrain and not true knock. Please take a listen on this video and tell me what you think.
1966Stepside is offline   Reply With Quote
Old 04-14-2011, 12:57 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 5.3l engine knock
I can't hear anything bad(But I have been told I need a hearing aid)...Those sensors do go out more than others due to their location and water getting to them.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-23-2011, 05:44 PM   #3
1966Stepside
Ok, I swapped both of the knock sensors and drove it for about 5-600 miles. Then the codes have started popping again. I had recently replaced the spark plugs with NGK's, so I pulled them and put factories back in. Codes have reappeared after that swap. There doesn't appear to be any real knock, and the codes don't pop immediately they take at least 70-100 miles of driving before they come back. Can anyone suggest anything else to look at?
Old 04-23-2011, 08:54 PM   #4
clinebarger
Whats the code number?
clinebarger is offline   Reply With Quote
Old 04-23-2011, 09:06 PM   #5
1966Stepside
0332 low input voltage bank 2
Old 04-23-2011, 09:21 PM   #6
1966Stepside
Also, thought I'd toss this out there. My truck is running cutoff exhaust after the cats. When I let off the gas quickly (like passing someone) I get several pops from ( I assume) air being pulled back through the exhaust. The codes don't seem to pop when I'm getting that noise, but I thought it might be relevant
Also, mu bank 2 sensor was just nasty with mud and rust. I took 3 blue shop towels and cleaned it out the best I could. Couldn't vacuum sine I did it with the intake on.
Old 04-23-2011, 09:42 PM   #7
clinebarger
The "cut off exhaust" is causing your problem. Put a exhaust system on it!
Old 04-23-2011, 09:48 PM   #8
1966Stepside
It was like that when I got it, sadly. You think that's it? I drove it for a month or so after I got it, but I could see how the engine would see that as knock if it makes it all the way back to the block.
Old 04-23-2011, 10:05 PM   #9
clinebarger
You need a exhaust system anyway. I never thought of it as "optional"
Old 04-23-2011, 10:16 PM   #10
1966Stepside
It isn't as loud as you'd imagine. If it isnt causing these sensors to pop errors I really don't think I'd put one on
Old 04-23-2011, 10:25 PM   #11
clinebarger
In your video it sounds like a tractor.
Old 04-23-2011, 10:33 PM   #12
1966Stepside
That's all under hood noise. You can't hear the exhaust note in the vid cause it's pretty quiet. The cats seem to do a fair job of killing the sound. I'm really only concerned with the knock sensor issue, not how the truck sounds
Old 04-23-2011, 10:59 PM   #13
hayhauler71
hayhauler71's Avatar
disconnect the 2 pin connector on the top of the intake for the knock sensors [blue wires] ohm each wire to ground should have 93k to 107k ohms if not in spec remove the intake and check the wiring to the sensors or possibly water down in the holes where the sensors are. gm technical service bulletin 02-06-04-023a
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-23-2011, 11:02 PM   #14
usmcchevy
usmcchevy's Avatar
Build thread
LSx Swap FAQ index
Old 04-23-2011, 11:03 PM   #15
1966Stepside
I was planning on trying to do this tomorrow, but I didn't know where to check the wires at. I am afraid that the wiring harness is bad, is there a way to differentiate between bad harness and bad sensor?
Old 04-23-2011, 11:05 PM   #16
1966Stepside
The full code is p0332 knock sensor 2 circuit low input (bank2)
Sorry, probably bad abbreviation on my part
Old 04-23-2011, 11:09 PM   #17
1966Stepside
Also thanks for the help all. I got my hands full on my project truck, don't wanna be wasting time wrenching on my daily!
Old 04-23-2011, 11:16 PM   #18
hayhauler71
if the ohm test fails the intake has to come off any way. then you can test the harness and the sensors
Fuzzy
Old 04-24-2011, 01:32 AM   #19
5150.4.67
Could be harmless piston slap as well............at least concerning noise.
5150.4.67 is offline   Reply With Quote
Old 04-25-2011, 04:19 AM   #20
60ratrod
yes, i do
60ratrod's Avatar
not to hijack this thread, but are 5.3s prone to piston slap? i think my tahoe has a case of it, goes away after either a couple minutes of warm-up idle or about a 1/16th of a mile. and the motor has to be dead cold for it to happen
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 04-25-2011, 08:51 AM   #21
usmcchevy
usmcchevy's Avatar
5.3s and 6.0s are pretty prone to cold start knock. They just knock for the first min or two in the morning. In 03 they started putting a coating on the piston side skirts to help.
Build thread
LSx Swap FAQ index
Old 05-07-2011, 04:36 PM   #22
1966Stepside
Well, I disconnected the battery and let it set for a bit.... that clears the ECM completely I suppose because it also idled a bit funny for a second trying to figure itself out after I restarted it. That cleared the light of course, and I drove it for a couple weeks before the light came back on. But this time it stayed on for only about 30 min and then went back off.... so far hasn't come back after that. Keeping my fingers crossed.
Old 05-07-2011, 05:01 PM   #23
Josh
He's got mean nasty FANGS!
Josh's Avatar
You most likely need both knock sensors and probably a knock sensor harness. If it is setting a code there is a problem that isn't going to just "go away". Those trucks tend to get water in the knock sensor bores and it causes corrosion on/in the sensors and connectors. I have done more of them than I can even count for the exact code and every single one of them was due to water in the knock sensor hole....
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 05-07-2011, 09:08 PM   #24
1966Stepside
Yeah, I know about the water problems so I already replaced the sensors.
