#251 |
Member of the longbed union.
Re: Daverods 52
Iron Duke is the name of the motor 2.5L.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#252 |
Re: Daverods 52
nothing happen this weekend? I got a thread for the dime.
#253 |
SSN 706
Re: Daverods 52
Weekend not over yet.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-24-2011 at 10:19 AM. |
#254 |
SSN 706
Re: Daverods 52
Filled a bunch of holes. Welded a bunch of cracks in my fenders. Stripped one front fender and painted it to look like the other old one. Turned out better than I hoped. Not done yet.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-24-2011 at 11:22 PM. |
#255 |
Re: Daverods 52
Love the trucks. all of them
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#256 |
SSN 706
Re: Daverods 52
Got my bags and cups. Have no idea what the brackets/otherthings are for?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-26-2011 at 10:41 PM. |
#257 |
SSN 706
Re: Daverods 52
Thanks Jeff.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-26-2011 at 11:16 PM. |
#258 |
Daring to be Different
Re: Daverods 52
They are for relocating your shocks. But on our suspension you might not need them. It would depend on how much your going to drop it.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 04-27-2011 at 10:12 AM. |
#259 |
SSN 706
Re: Daverods 52
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-27-2011 at 02:58 PM. |
#260 |
Re: Daverods 52
the original shocks were inside the springs.
obviously they dont fit there when you put airsprings in their place. so the shock is relocated to the outside edge of the control arm. the long part goes onto the frame and the top of the shock bolts to it. im not postitive on the "wingnut wings", but they look kinda like the lower shock mount with bushings. i wouldnt be surprised if they fit inside the stock lower arm for bracing... you wouldnt use them in that case.. you also wouldnt use the lower cups. as far as the shock mounts, I would look carefully at both the shock clearing the frame under travel, and the tire clearing the shock when turned at lock. if you're running larger wheels, you may want to recess the shock into the frame slightly so you dont lose turning clearance. |
#261 |
Re: Daverods 52
On these trucks the shocks are mounted outside of the springs.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 04-27-2011 at 03:39 PM. |
#262 |
Re: Daverods 52
Wrong crossmember Dennis, that's for a c10. remember he's using a s10.
#263 |
Re: Daverods 52
oddly enough though, where the shock meets the LCA on that pic is very similar to how you would be mounting it to the S10 arm.
#264 |
Re: Daverods 52
Duh, Sorry I stand corrected.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#265 |
SSN 706
Re: Daverods 52
It's OK we know, your old.
#266 |
SSN 706
Re: Daverods 52
I'm thinking the wing nut things might weld on to the arms.
#267 |
Re: Daverods 52
yeah it might just weld to it. what I've seen some people do is either bolt the stud or weld it to the lca.
You still not get your rear kit yet? I've been messing with my rear bars, but I'm need to know where the bag sits on yours. About to update pics of my truck.
#268 |
Re: Daverods 52
I used to drill a hole in the lower arm, and weld a plate to reinforce where the bolt goes through. Even if the special shock bolt is welded in, it will crack the metal on the arm around the bolt.
![]() BTW Thanks Dave. Why are you being so nice??? What do you want?? ![]()
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 04-27-2011 at 09:34 PM. |
#269 |
SSN 706
Re: Daverods 52
#270 |
Re: Daverods 52
I don't claim to know it all. I'm still learning myself. But will alway share what I think I know. ![]() Posted via Mobile Device
#271 |
1 thing at a time is progress.
Re: Daverods 52
How much time do you get to work on your trucks every week? Your rockin'!
Alan
Philippians 2:14-16 |
#272 |
SSN 706
Re: Daverods 52
Couple hours a day, 4 to 6 on the weekends. I run into a lot of dead ends and stuff that I'm not sure about so I jump around a lot.
#273 |
Re: Daverods 52
I need to get on a regular schedule.
#274 |
SSN 706
Re: Daverods 52
I heard this stuff works wonders.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-28-2011 at 10:07 AM. |
#275 |
Re: Daverods 52
I don't need that yet. My poop comes out just fine, thank you.
