Old 06-05-2011, 01:16 PM   #1
C-10 simplex
How to put in a fuel shutoff?
How would you go about putting in a fuel shutoff?
NOte: this is intended to be a security device on a carbed car.
C-10 simplex is offline   Reply With Quote
Old 06-05-2011, 02:05 PM   #2
Psycho71
Psycho71's Avatar
Re: How to put in a fuel shutoff?
Well, on a carbed vehicle the bowls on the carb will hold a certain amount of fuel, so the engine will still crank, it just won't go far w/o additional fuel. To install a shut off in the system, you'd need some type of solenoid in the fuel supply line, then have it wired toa switch of some kind to turn it on or off. But then if the solenoid ever fails, you will be stranded.
I suppose it could be done with a manual valve too. In this case all you'd need is the valve, and desired location along the fuel supply line somewhere. Then install it. I'd think a marine supplier would have a few options for the valve itself. Someone like West Marine maybe?
For security purposes, I'd put some kind of switch in the ignition circuit. Much easier, less expensive, and reliable. If HEI ignition, all you have to do is break the power supply to the ignition. Much more practical in my opinion.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 06-05-2011, 04:14 PM   #3
C-10 simplex
How?
Old 06-06-2011, 01:07 AM   #4
orbot
orbot's Avatar
plumbing for the shut off valve would be some work, is it a track truck??
you can cut the power to the HEI coil by adding a switch in line with the power wire heading to the coil, do you have a spark box in the truck? if so theres a wire you can ground through a switch and when ever its grounded the truck will never turn on
orbot is offline   Reply With Quote
Old 06-06-2011, 04:59 AM   #5
COBALT
COBALT's Avatar
That's what I was thinking. Just interrupt the 12v wire to the distributor in some hard-to see place, then run your switch to somewhere only you know about. For points one could interrupt the resister wire from the distributor to the coil.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-07-2011, 04:30 AM   #6
BigDan3131
BigDan3131's Avatar
Another option is a keyed battery disconnect killing all power or a level style switch.
BigDan3131 is offline   Reply With Quote
