Old 06-05-2011, 08:20 PM   #1
TR65
TR65's Avatar
A/C Air Conditioning install GEN IV Magnum VintageAir 1965 C10
I use my truck as a daily driver and it gets pretty hot in SC. My wife also asked me to put A/C in the truck (or else she wouldn’t be riding with me in the summer). So, I set about it.
I corresponded with CoolAir our board member that works for VinatgeAir and he recommended that I use the VintageAir GEN IV Magnum unit because of it’s superior electronic controls. VintageAir doesn’t make a GEN IV kit specifically for our trucks so I had to do a custom install based on their universal evaporator kit.
My truck has a LS2 drive-train from a 2005 SSR and I had the OE Sanden scroll compressor. It mounts low on the passenger side, out of sight so I wanted to maintain that. I also wanted to maintain the ECM control of the compressor. The ECM is set up to protect the compressor and to operate the fans to control the high side pressure, so the fans come on only when needed.
I also wanted to minimize the modifications to the truck, no dash chopping, excess hole drilling etc.
I couldn’t find a real detailed custom A/C install thread for our trucks to I decided to document what I did so it could maybe help someone else in the same boat.
The system works great to date. I would certainly recommend VintageAir.
TR
Here are the suppliers and part numbers for the major parts of the A/C install
Drier 4-1003 Aluminum O-ring Receiver Drier Nostalgic Air Parts www.nostalgicairparts.com
Condenser 54-1620 16X20 Superflow R-134A Condenser Nostalgic Air Parts www.nostalgicairparts.com
Heater control plate 38-5093 Cover-Heater Control LMC Truck www.lmctruck.com
Compressor Block GM Style offset raised face - 3/4" tall body - Offset Raised Face Compressor Blocks Doc's Blocks www.docsblocks.com
Miscelaneous small parts, fittings, hard line, o-rings MISC. Doc's Blocks www.docsblocks.com
Vacuum Pump H93-028 15600 6 CFM VAC Pump Johnstone Supply http://www.johnstonesupply.com
Aeroquip A/C Fittings and SS braided A/C hose Reusable A/C fittings and Hose Octane Auto Suply, Amazon, Doc's Blocks several suppliers used based on cost and availability
Pressure Transducer ACDelco 15-5742 Pressure Cycling Switch Amazon- AC-Direct AC-Direct.com
Evaporator Kit 671400-VUZ Gen IV Magnum Evap Kit Vintageair - Wheels of Time street rod parts http://wheels-of-time.com/
GEN IV Controls 491226-RVA Strmln 3 knob pnl kit vert blk anodz Vintageair - Wheels of Time street rod parts http://wheels-of-time.com/
Scroll Compressor Sanden TRSA09K OE on SSR
PAG oil Compressor oil for Sanden scroll compressor 8 oz 46 viscosity w/UV dye A/C Source http://www.acsource.com
Dash Vents 49058-VUQ Outlet Proline Rectangle Vintageair www.vintageair.com
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-05-2011, 08:21 PM   #2
TR65
TR65's Avatar
Re: A/C Air Conditioning install GEN IV Magnum VintageAir 1965 C10
More Pics
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:23 PM   #3
TR65
TR65's Avatar
More Pics #2
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:25 PM   #4
TR65
TR65's Avatar
More Pics #3
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:27 PM   #5
TR65
TR65's Avatar
More Pics #4
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:28 PM   #6
TR65
TR65's Avatar
More Pics #5
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:30 PM   #7
TR65
TR65's Avatar
More Pics #6
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:31 PM   #8
TR65
TR65's Avatar
More Pics #7
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:32 PM   #9
TR65
TR65's Avatar
More Pics #8
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:34 PM   #10
TR65
TR65's Avatar
More Pics #9
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:36 PM   #11
TR65
TR65's Avatar
More Pics #10
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:38 PM   #12
TR65
TR65's Avatar
More Pics #11
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:39 PM   #13
TR65
TR65's Avatar
More Pics #12
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:41 PM   #14
TR65
TR65's Avatar
More Pics #13
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:43 PM   #15
TR65
TR65's Avatar
More Pics #14
1965 C10 SWB Fleet
Two owner
Old 06-05-2011, 08:44 PM   #16
Max1775
Max1775's Avatar
Outstanding installation. Very clean! Nice truck as well.
Max1775 is offline   Reply With Quote
Old 06-05-2011, 10:50 PM   #17
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
awesome work....as always!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-06-2011, 12:58 AM   #18
Scottshotrods
Very detailed pics nice job
Justin
Scottshotrods is offline   Reply With Quote
Old 06-06-2011, 01:31 AM   #19
Chevyman680063
Chevyman680063's Avatar
Wow, you did a really nice job! Can you feel the air blowing on your face with the vents mounted below the dash? My '63 is my daily driver and last week it was around 100 every day. It felt like I was sitting in a dang sauna. My only means of cooling down are a $12 fan that plugs into the cigarette lighter.
1963 Chevrolet C10 Short Step
1968 Chevrolet C10 Short Step
Chevyman680063 is offline   Reply With Quote
Old 06-06-2011, 07:17 AM   #20
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Nice write up on your install.. Outstanding job!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-06-2011, 04:47 PM   #21
Heater63
Heater63's Avatar
Wow. Wow. Wow.
I Love You Man! I have just bought my evap unit and about to start the install as soon as I rehab from shoulder surgery. You will save me tons of time!!
292 + TKO500
Heater63 is offline   Reply With Quote
Old 06-06-2011, 09:35 PM   #22
TR65
TR65's Avatar
Thanks for the kind words men!!
I suffered in the heat last summer, it is nice riding in the cool.
TR
1965 C10 SWB Fleet
Two owner
Old 06-06-2011, 09:38 PM   #23
TR65
TR65's Avatar
Yea, it is NOT a dry heat. Well I was riding in it everyday last week and I didn't have to run the fan much past halfway to be comfortable. You can't blow it in your face but I don't like that anyway.
TR
1965 C10 SWB Fleet
Two owner
Old 06-07-2011, 03:25 AM   #24
acool66
That is very nice work, something to be proud of. Well done
acool66 is offline   Reply With Quote
Old 06-07-2011, 08:07 AM   #25
structures
structures's Avatar
Thank you very much for taking time to put this together TR. This is extremely valuable information. Hey thanks for posting in your other thread or I would have completely missed it!
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
