#76 | |
Re: Post your best budget mods! ($50 or less)
http://67-72chevytrucks.com/vboard/s...d.php?t=465003 Another cheap mod I like is putting a quartz clock in the dash in the open hole to the right of the steering column. I think I paid $5 for the clock out of an 80s Suburban. I grabbed the Sub's factory connector. The hole in the clear plastic is made with a heated nail. I learned the heated nail trick on this forum. That clock keeps really good time. I have less than $15 into it counting the plastic polish I used to remove the factory markings on the back of that spot in the bezel.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#77 |
Some where in the forum i saw wire mesh put under the opening in front of the windshield to prevent debris collecting in there.I bet it cost less than 50 to do.Does any body know how the mesh was held in place?
#78 |
Grandpa in the rustmobile...
I hot glued mine, epoxy would've worked better looking back
i just used old window screen. i'll try'n remember to get pics oneday
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#79 |
I love the wrench trick, I have a small trurn buckle on my ps set-up I hooked to the back to adjust the angle.
So far my best mod is in progress, the Tahoe's in the late 90's have a platic box under the hood with a lid on hinges. It is labeled storage for anything I guess. Quart of oil, tools, whatever so I took one from the junk yard and just repainted it and am getting ready to mount it under the hood to put in an extra quart of oil, some ps fluid and brake fluid. Last edited by ubtripn; 06-03-2011 at 08:46 AM. |
#80 |
bump to get some more great ideas and keep a great thread alive
#81 |
What?
Not really anything special, but taking a piece of rubber hose and capping it off with a spent 38 special cartridge case makes good vacuum plugs.
This one was meant to be temporary, but after 10+ years it kind of became permanent. ![]()
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 06-09-2011 at 08:30 PM. |
#82 | |
#83 |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#84 | |
VA72C10
#85 |
Subscribed
Eric "Target" Sherwood Professional Bullfighter For Hire God Bless and Gods Speed! TheCowBoyProtectionUnit@yahoo.com http://www.facebook.com/pages/Eric-T...59496227444241 |
#86 | |
Master Procrastinator
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#87 | |
Recalculating.....
Brian - (BBrendal) 1969 Chevy Camaro Z28 1972 Chevy Blazer CST 2004 GMC Yukon (The truck that pulls the car trailer) 1972 Chevy Blazer CST #2 (Finished and sold!) Blazer build link... http://s1213.photobucket.com/albums/...rendal/Blazer/ |
#88 | |
I DIG... I will be doing this.. Great idea.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
#89 |
Question on the tailgate mod.. What cables did you buy? are they all the same or did you buy a certain years cables? I might do that mod soon.
#90 |
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) Last edited by Primered_69; 06-10-2011 at 11:40 AM. |
#91 | |
#92 |
One of the best things I did to the old truck was make the plate thats above my radiator. I dropped a wrench one time and it went between the radiator and the radiator support and poked a hole into one of the tubes. The piece of aluminum was free, can of paint was a couple of bucks. It makes a great shelf to put qts. of oil and a filter on. I did snag the under hood light for free from my buddies wrecked mid 90s chevy truck.
#93 |
Champagne Taste on Beer Budget
Also subscribed.
Great tips guys!
Coming Soon: Project 1970 Country Truck |
#94 |
Went to a local swap meet scored a factory am stereo with the deluxe knobs and 90's center caps to go on my 72 6-lug rallye wheels for 50 bucks. The radio is mint and it works. Best 50 bucks spent so far.
#95 |
Old member
I picked these up while in a yard along with electric jug. Less than $50.00 in all of it and I get a complete windshield wash now.
The jug is on the drivers side fender now. Had to put the shooters in a boiling pot of water with vise grips to make them soft enough to confirm to the wiper arm.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#96 |
Coool!! It attaches to the wiper arm?..
#97 |
Old member
The plastic clips to them if the right amount of heat is applied. I used vise grips to hold them over night while it cooled off.
#98 | |
born to lose
Wow that looks great amigo!
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 ![]() '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 ![]() Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
#99 |
Headlight relays, ebrake "brake" light, dome light door pins, painting inside of cluster and adding LEDs are all on the top of my "mod" list.
My own? Add a ground circuit to the rear lights, paint the rear lamp buckets with rattle can chrome and replace the 1157's with 2057's. Adds alot of brightness and will make me feel better when the kids are criusin with me ! |
#100 |
headlight relays are definitely up there if you EVER drive at night
