Old 07-16-2011, 11:33 PM   #251
68 TT
Still plays with trucks
68 TT's Avatar
Re: Bolt in steering rack
Great product. Thank you very much for putting the money and effort into producing it.
I have run rod ends on the street for years in trailing arms, panhard bars, A-arms & Cal-Trac bars. The best thing you can do is put on a set of grease seals even with a teflon or kevlar lined rod end that doesn't need greased. It will keep the water & road grime out of the rod end and make them last longer.
I have used this product and liked them.
http://www.sealsit.com/rodend.asp
Pretty inexpensive too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-17-2011, 06:41 PM   #252
76stepside
76stepside's Avatar
Thanks for the reply Rob... hope you had a good time, cant wait to get my rack!!
8.1l 496 4l80e
76stepside is offline   Reply With Quote
Old 07-18-2011, 03:35 PM   #253
chapster
chapster's Avatar
Rob,
Can you please give an opinion on your R & P fitting with Porterbuilt lower control arms and swaybar.
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 07-18-2011, 03:57 PM   #254
robnolimit
robnolimit's Avatar
The arm is OK, I'm not sure about the sway bar. Our rack kit puts the tie rod end under the spindle, so you may need to call Nateon this one.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 07-18-2011, 08:03 PM   #255
SCOTI
SCOTI's Avatar
I've been looking for these. I knew they were made, but for the life of me I haven't been able to locate the source.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-20-2011, 02:17 PM   #256
Slammed50
What kind of rack is used? How available are replacement parts such as inner tre's and boots? Looks like a great addition, definitely getting the wheels turning...
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 07-20-2011, 03:37 PM   #257
robnolimit
robnolimit's Avatar
It is a US manufactured rack. No problems with replacement parts or service parts. The Tie rod ends are available all over. So long term maintanance is a non issue. thanks for the interest.
Old 07-20-2011, 04:53 PM   #258
68 TT
68 TT's Avatar
They make a boot that goes over the whole rod end too but I have never used them.
They seal even better and protect the whole thing, not just the bearing area.
http://www.sealsit.com/rodendboots.asp
Old 07-26-2011, 03:28 PM   #259
robnolimit
robnolimit's Avatar
UPDATE Well, we're a bit behing schedule, but we are making good progress. We decided to make a change to the rack mounting, using a machined billit mount instead of a strap clamp. Thats the goos news, the bad news is we have to make them, and have a urathane isolator custom made. Thats the bad news. The isolators will take another two weeks, we just got a first article sample, and it's good, so now we just have to wait. The best part is, we aren't going to raise the price because of this. We did it for safety, and to make the install easier. So, if you have one on order, be patient, give it a few more weeks. Thanks.
Old 07-29-2011, 08:38 PM   #260
rob32472
Rob, what led to the change? Did an issue present in one of the test trucks?
rob32472 is offline   Reply With Quote
Old 07-30-2011, 04:30 PM   #261
robnolimit
robnolimit's Avatar
Not really. We just got back from a 20 road trip back to Des Moines and Columbus, and we stopped in at 19 shops. I always look to see what tools are being used, and how things are done at shops when we stop in. The first thing I always notice is the instructions, mostly still folded up in the box. Another thing that got my attention was the popularity of 3/8 drive air impacts, and battery/electric impacts. Now, I have these tools, but I don't use them a whole lot on assembly. So, all the way home I thought about this. The strap clamps on the rack are to be torqued to 40 in/lbs. (not very much), and if over torqued, can compress the slide bushing in the rack. The more I thought about it, the more that the posibility of a problem seamed too high. So, I wanted to solve the problem, before there was one. None of the test trucks have had an issue, but we were schooled by our rack builder on the internal workings of these racks, and what we could, and could not do. This seams to be the right thing to do. Steering performance is the same, but the posibilty of any problems is reduced. We think thats worth a few weeks lead time.
Old 07-30-2011, 07:38 PM   #262
68 TT
68 TT's Avatar
Good idea to make it more fool proof. It will be worth the little extra wait to get a better designed clamping system that will prevent accidental damage to the rack.
Old 08-27-2011, 11:00 AM   #263
76 stepside
Hows the progress coming on the racks Rob?
76 stepside is offline   Reply With Quote
Old 08-27-2011, 11:03 AM   #264
76stepside
76stepside's Avatar
8.1l 496 4l80e
Old 08-28-2011, 06:41 PM   #265
robnolimit
robnolimit's Avatar
We are waiting on the last puzzle piece, the rubber isolator for the billit clamp. We are expecting these this coming week. Had to have them made. We have 25 kits ready to go as soon as the isolators show up.
Old 08-28-2011, 07:18 PM   #266
76stepside
76stepside's Avatar
Excellent cant wait I feel like a little kid waiting for christmas!
8.1l 496 4l80e
Old 10-11-2011, 12:29 PM   #267
Custom 68
Custom 68's Avatar
alright all you guys that purchased let us know how this upgrade is. I still want to move to the rack and pinion but budget has been tight. Let us know your initial thoughts from the driving standpoint.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-11-2011, 11:06 PM   #268
rt hubbard
so Rob hows the progress comming on the racks i have one preordered looking forward to getting it an by the way i receved the panhand bar fit well but had to cut a spacer for to fill the gab between the c-notch an frame. i have a cnc lazar so the spacer was no problem but something you might concider for all the bolt on guys.
rt hubbard is offline   Reply With Quote
Old 10-12-2011, 03:38 PM   #269
robnolimit
robnolimit's Avatar
DON'T SHOOT !!!! I know I'm behind on shipping these out. We are really trying to send them out 100%, so that everyone is really happy. No limit has a reputation of sending out 'poor' instructions, I know it, so we're just finishing up the final details. We are including fitting specs, pressure specs, bolt torque specs, warrantee service info, ...... . It's all in the details.
Old 10-12-2011, 03:41 PM   #270
robnolimit
robnolimit's Avatar
??? Hmm, the kit should inclue a 3/16 spacer already. It should have been in the hardware pack. I just checked the bin, and all the hardware kits we have are complete. Sorry if yours was not. let me know if you need anything. Thanks for the order. Glad to know everything fitted up good with the panhard rod.
Old 10-26-2011, 09:27 PM   #271
dnd1978
dnd1978's Avatar
Rob,
any updates on the kits
Dillon
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 10-28-2011, 01:43 PM   #272
robnolimit
robnolimit's Avatar
FINALY We are boxing today, shipping today and monday. Thanks for waiting. BTW, introductory pricing is now over. Congrats to those who got a great deal.
Old 10-28-2011, 03:23 PM   #273
gringoloco
A guy with a truck
gringoloco's Avatar
Yay and boo. Ready to hear some feedback on the kits from members, but sorry I missed out on the deal...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is online now   Reply With Quote
Old 10-28-2011, 05:45 PM   #274
SBTork
Garage wrench
SBTork's Avatar
x2
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 10-28-2011, 06:33 PM   #275
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
x3
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
