DND Trucks
![]() Join Date: Dec 1999
I saw a pair of 781 heads f/s in stock form. I've heard these heads have good air flow characteristics and compression comes in around 8.5-9.0
What has anyone heard about them good, bad, indifferent. LMK |
Re: 454 BBC 781 heads
One of the best 'bang for the buck' bbc heads offered.
Mild port work & a good valve job & they'll flow as much as high dollar aftermarket heads. I don't recall typical compression ratios but I believe the 781's on my RetroRod combined w/a forged flat-top yielded 9.5:1. It will mainly depend on deck height, if the heads have been milled/surfaced, & what pistons are used.
DND Trucks
Thanks SCOTI.
You ain't gonna be anywhere near 9.5:1 with flat tops and open chamber heads, period.
With 119cc chambers and 3cc valve reliefs with a decked block and .040 quench, you'll be at 8:1. It'll take a small dome to get you up to 9 or 9.5:1. With a good bit of port work, large valves, etc., you'll be as good as entry level aluminum heads, I've seen well done ones flow in the 340cfm range. They won't hold a candle to a good race head which are all well over 400cfm, but will be great for daily driver or mild racing. Don't get too tied up in big port work...stock valves with a good bowl blending and a bit of short turn work, good 3-angle valve job and some necked-down valves plus some small dome pistons will get you a very good head, capable of 600hp or so on a 454. Or forget the domes, go with a forged and studded bottom end and add forced induction, that's a perfect compression ratio for a hairdryer or huffer! |
a fool with no money
what they said...
I'm running 781's... larger valves, bowl blend, 3 angle, ports matched to intake runners, etc.. good heads stock... great heads if they are given to the right machine shop... but, as cheap as uluminum heads are now, for a few hundred more...
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
![]() Join Date: May 2009
Ditto...781's seem to perform well.
Post up links to aluminum heads that are "a few hundred more".
![]() Join Date: Apr 2009
#9 | |
The Brodix listed on the PBM site site are $950 each + shipping so $1800 minimum. That's a little more than purchasing & rebuilding some 781's. Go to Summit or Jegs & the typical price for standard, street use oval ports are around $850ea on up regardless of mfr.
I looked at the receipt for the machine work and parts on my 781’s, I have less than $900.00 for the pair (that’s not counting roller rockers). I did the bowl blending and cleaned up the runners to save a little money.
