#376 |
Re: Kabwe's aka Bam's build
#377 |
Certified Car Nut
Yeah I agree with you, it looked so unfinished with those factory spot welds showing and the metal lapped over each other. I thought it was just me who thought it was ugly.lol
#378 |
What did you have to do to switch from a 59 to 55 front clip?
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
#379 |
Certified Car Nut
You need the entire 55 front clip, fenders, inner fenders, radiator support, upper and lower grill supports, grill, and of course the hood.
#380 |
Do the fenders bolt right up to the cab?
#381 |
Certified Car Nut
#382 |
Thank you. I have alot of work ahead of me before I decide to do that but thought i would ask if it is a hard alteration.
#383 |
You will also need to trim about 3" off of the front of the frame rails. Front crossmember and radiator support are same, but the 58 fenders are longer which pushes the bumper and brackets out farther.
#384 |
Certified Car Nut
Mike just to clarity OrrieG is talking about the frame radiator mounts are the same (the part the radiator supports mounts to). Yes I forgot to mention you have to cut off the front of the frame. I still have my front pieces if you want me to measure how much I cut off.
#385 |
Certified Car Nut
This was my first time using this product, a buddy of mine told me to try it. I decided to try it on my dash to fill some minor imperfections. I could have used high build primer, but I wanted a reason to try this stuff. I sprayed great really smooth. I had to use a 2.2 tip that's how thick it is, but most of it will end up on the floor but man it's a great product. I liked it so much I did the roof also.
#386 |
Nice!
#387 |
The truck is looking good and thanks for turning me to that primer you are using by Southern Polyurethanes, Inc that stuff is gr8. I won't have to use it on everything just on the stuff I will have to take down to the bare metal. I'm gona get that Slick Sand as well. Think you can spare me some until I get my own?....can ya help a brother out?
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#388 |
![]() Join Date: Mar 2011
Cab is looking great, let us know how this stuff sands out.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#389 |
That looks very good!!! It looks like it did a very good job filling in the small imperfections. It looks like it did a really nice job around the third light.
#390 |
The cab is looking great Bam.
Are you just spraying it in your driveway? Kim |
#391 | |||
Certified Car Nut
![]() Kim its okay to shoot primer outside you have to block sand it level anyway. When it comes time to shoot color that's a different story.lol Last edited by Kabwe; 08-01-2011 at 02:40 AM. |
#392 | |
#393 | |
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#394 |
Thats great, i will really need some of that. your cab looks sweet. I am seriously thinking about changing some stuff on mine now.
#395 | |
Certified Car Nut
Oh no man I'm a long ways off. I have so much to do its ridiculous. Thanks man, and you are doing a great job on your truck also. Thanks buddy. |
#396 |
Kabwe, Truck is coming along great. I always used shopline filler primer and wonder if you had ever used that and if there is a difference between that and the slick sand. Is one better than the other? Keep up the great work.
Shannon |
#397 | |
Certified Car Nut
Like I said, I never used shopline, but I have used high build primer and slicksand has more build. I hope that helps |
#398 |
Kabwe, Thank you for the info. I will have to try the slicksand next time. Did you order it from somewhere or buy it locally?
Shannon |
#399 | |
Certified Car Nut
I mix 16 ounces with half a tube on harder. Please clean your gun between coats because this stuff sets up fast. I applied two wet coats cleaning my gun between each use. I used a 2.2 tip and it sprayed nice, but you can reduce it 15 percent with urethane reducer if you don't have a 2.2 tip. |
#400 |
Kabwe, Thank you. They are in PA and about a hour away. I was at there old place years ago but they moved. The price is really good . The Shopline is around $100 for everything. I will have to get some and try it.
Shannon |
