Old 08-08-2011, 09:51 PM   #1
chase1873
chase1873's Avatar
Need a little bit of front end advise please.
heres my question.. I plan to reuse the stock A-arms just blast them and repaint them, what is the best route to take in regards to the bushings??? they seem fine. Should I get new bushings, new shaft and bushings, or just clean them up and put them back in??? I'm on a tight budget, so if I can avoid taking them to a machine shop i will... any help is appreciated.
also, on the passenger side there is a bracket that is riveted to the crossmember. This bracket connects the upper A-arm the the crossmember and the frame. It's has been structurally compromised from rust and I want to replace it... not sure what it is call or where i can find one...
Mike
1970 C10 swb step side... needs everything.
chase1873 is offline   Reply With Quote
Old 08-08-2011, 09:58 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Need a little bit of front end advise please.
If its a budget build and they look good then the probably are and don't need to be replaced. Pics would be great. As far as the bracket is concerned I don't think there is a "real" term for it. So make one up...Upper A-arm support bracket? You should be able to find a usable one in a junk yard. You didn't mention what truck you had so I don't know how hard it would be to find one.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-08-2011, 11:23 PM   #3
chase1873
chase1873's Avatar
here are some pictures, the truck is a 1970 C10 2wd.
I appreciate your time
Mike
Old 08-08-2011, 11:25 PM   #4
BMERDOC
BMERDOC's Avatar
Pics didn't come through.
Nick Carter
Old 08-08-2011, 11:27 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
If the bushing are original they are 40+ years old. I am thinking they are due for a replacement.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-08-2011, 11:28 PM   #6
chase1873
chase1873's Avatar
retry
Mike
Old 08-08-2011, 11:30 PM   #7
BMERDOC
BMERDOC's Avatar
Dang! The bushings look better than the arms!! I'd sandblast those arms and see what you have left. You may need the whole thing!! Looks like it may have had the bushings replaced at one time or another. Looks like Mass. winters haven't been kind to those arms. In the end they should be useable but see how pitted they are after cleaning.
Nick Carter
Old 08-08-2011, 11:40 PM   #8
chase1873
chase1873's Avatar
Mass is correct, I live 20 miles north of Boston. I bought the truck from a fellow in NH.... I know I went north instead of south to find my truck my compass clearly needs to be re-calibrated.
Mike
Old 08-08-2011, 11:41 PM   #9
chase1873
chase1873's Avatar
Anyone on the bracket??
Mike
Old 08-09-2011, 12:02 AM   #10
SCOTI
SCOTI's Avatar
Like mentioned, there's no specific immediate name for that part of the x-member. It's job is to locate the upper a-arms & secure the x-member to the frame @ the sides of the rails. I would call it the upper a-arm crossmember bracket.
They are riveted & they can be removed w/another set bolted into place (GRADE-8 hardware w/lock-nuts minimum).
Can you get another pic of the opposite side of that a-arm (take a pic from the top side)?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-09-2011, 12:15 AM   #11
chase1873
chase1873's Avatar
more pictures coming in the morning, us east coast fellows need some sleep.
Mike
a-arms, control arms, front suspension.
