Old 08-25-2011, 05:14 PM   #1
Jay290
Overheating
Ok here it is last week I was pulling my camper home in my 83 and water pump went south and blew a head gasket. Well I put new head gaskets on it and new water pump let it run for about 30 min. with the a.c. going before i drove it. Drove it for about 3 miles and the temp shot up to about 235-240. It has a 180 t-stat in it (new) What else can I try to get this temp prob fixed?
Jay290 is offline   Reply With Quote
Old 08-25-2011, 05:44 PM   #2
TIM86
TIM86's Avatar
Re: Overheating
Fan clutch (just had this go out on me), Radiator hose collapsing?
TIM86 is offline   Reply With Quote
Old 08-25-2011, 05:52 PM   #3
Jay290
Re: Overheating
Makes sense the faster the motor turns it starts cooling. I have not checked the hose to see if collapsing. I just let it run for about fifteen mins and it got up to 205 with the A.C. on just idling in the drive way.
Old 08-25-2011, 06:05 PM   #4
VegasBruce
VegasBruce's Avatar
Re: Overheating
New stat may be bad, did you test it first? Its a common problem.
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline   Reply With Quote
Old 08-25-2011, 06:25 PM   #5
Jay290
Re: Overheating
Really well I will pull it out and test it.
Old 08-25-2011, 06:26 PM   #6
Jay290
Re: Overheating
Now i looked at the heads real good and did not see any cracks, will that cause it to overheat?
Old 08-25-2011, 06:39 PM   #7
Hevy
Hevy's Avatar
Re: Overheating
Air in cooling system...
Hevy is offline   Reply With Quote
Old 08-25-2011, 11:08 PM   #8
67_SS396
Re: Overheating
I second that. It's probably due to an air bubble.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 08-25-2011, 11:11 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Overheating
I was thinking the same thing or that your new tstat is possibly bad. I would also check a the fan clutch out as well before you start pulling your hair out haha.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-26-2011, 02:56 PM   #10
Jay290
Re: Overheating
Ok pulled the t-stat out this morning and boiled it 180 it opened. Also flushed the radiator real good this morning. left the t-stat out for now untill I get the problem curred. Ok I got the temp down to about 210-215 with no t-stat. The fan still has resistance when you turn it by hand. Will being out of time cause it to run hot like this...I may have been a tooth off on the dist.
Old 08-26-2011, 03:21 PM   #11
TIM86
TIM86's Avatar
Re: Overheating
Don't trust the fan. My fan hhad plenty of resistance but the clutch was still bad.
Old 08-26-2011, 03:30 PM   #12
Jay290
Re: Overheating
Well I guess it wont hurt to put a new one on it.
Old 08-26-2011, 05:06 PM   #13
Jay290
Re: Overheating
Well I think its the clutch I stuck a thin peice of cardboard in it and it stoped so off to the parts house to cure the problem.
Old 08-27-2011, 12:19 AM   #14
tucsonjwt
Re: Overheating
For something as important as the fan clutch, I went with AC/Delco - but it was about $110. All the mechanics and A/C repairmen I talked with said to stick with AC/Delco and stay away from aftermarket due to quality issues.
tucsonjwt is offline   Reply With Quote
Old 08-27-2011, 12:37 AM   #15
67_SS396
Re: Overheating
Put the thermostat back in while you're at it.
RevLimit Offroad
Old 08-27-2011, 12:48 AM   #16
lilpoindexter
lilpoindexter's Avatar
Re: Overheating
I don't have a fan clutch in my '78 and it sounds like an airplane taking off when i drive it from the fan noise...but I don't want to risk a fan clutch screwing me like this.
lilpoindexter is offline   Reply With Quote
Old 08-27-2011, 10:01 AM   #17
Jay290
Re: Overheating
Yah I have to wait untill tuesday untill i get paid again so I will keep ya'll informed
Old 08-27-2011, 06:08 PM   #18
LONGHAIR
Re: Overheating
There is no point in putting up with that. The factory clutch fans can and will go hundreds of thousands of miles. There are far more reported "issues" with aftermarket flex-fans than with the stock stuff.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-27-2011, 08:50 PM   #19
lilpoindexter
Re: Overheating
Ok...I just looked up the Hayden fan clutch to fit my application...not sure if I'll get it from kragen or summit... It's gonna be nice to not sound like a bi wing airplane when I get on the freeway.
Old 08-28-2011, 02:57 AM   #20
67_SS396
Re: Overheating
I agree with longhair, unless you go to an electric fan, run the tried and true clutch fan. They are very reliable and efficient, compared to the alternatives.
RevLimit Offroad
Old 08-30-2011, 04:18 PM   #21
Jay290
Re: Overheating
Well put in a new clutch this morning and t-stat (180) sitting in the driveway it was about 195 got it out on the highway and it jumped to 230 after about 5 miles. So the only other thing I know is to put a new radiator in it. So $250 and it should be here at 4:30.
Old 08-30-2011, 04:35 PM   #22
Hevy
Hevy's Avatar
Re: Overheating
Are you positive you got all of the air out of the cooling system????
Old 08-30-2011, 05:04 PM   #23
partsstoreguy
Re: Overheating
I own a parts store and i can not count the number of times people come in thinking their can clutch or themostat is bad when it turns out it is just a air bubble.
partsstoreguy is offline   Reply With Quote
Old 08-30-2011, 08:26 PM   #24
rwhit57
rwhit57's Avatar
Re: Overheating
I think its still a head or gasket issue. if the radiator doesn't fix it, I hope it does, throw a can of Barsleak in it and see if cools down a little if it does you know then.
rwhit57 is offline   Reply With Quote
Old 08-30-2011, 09:42 PM   #25
LONGHAIR
Re: Overheating
Oh no, not that gunk, all it does is clog things up, making it worse. If you really suspect a gasket or block/head crack, there are tests that can show that (one way or the other).
In general, low speed overheating is an air-flow issue, and high speed overheating is a coolant flow issue. It takes a bit more digging to pin it down after that though.
The air-flow can be from blocked fins in the radiator, improper fan, poorly fitting shroud (or missing), etc.
The coolant flow problems include, blocked tubes in the radiator, rust/scale build-up inside the block/heads, air bubbles, kinked or collapsing hoses, etc.
