Old 09-10-2011, 06:03 PM   #1
Roman
Drive shaft question - help!
Hi folks! Can someone be so kind to tell me what is the drive shaft lenght from center of ujoint to center ujoint for 67-72 short bed? Is it a two piece or one piece? I shortened the chasis of my long bed p/u (came with two piece) now I'm trying to resolve the drive shaft issue...thanks!
http://share.shutterfly.com/share/re...ZtGbVw3bN2LDAA
Roman is offline   Reply With Quote
Old 09-10-2011, 06:47 PM   #2
Lee H
Lee H's Avatar
Re: Drive shaft question - help!
59.5 on my 72 C10 SB, two piece shaft.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-10-2011, 10:18 PM   #3
Roman
Many thanks! I thought I was going to be able to use a drive shaft from a short bed truck. I ended up with a 56", I need to custom cut and balance.
Old 09-10-2011, 11:14 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
you NEED to measure your truck. All of the different engine mounts and swapping them from side to side will put the engine in different places then different trans lenths. Some swbs had one piece shafts and some had 2 piece shafts. I want to say mine is 59" center to center.
we usually want a tailshaft to center measurement.
brad_man_72 is offline   Reply With Quote
driveshaft
