how hard would it be to put a '77 front clip on a '86 cab??
Re: '77 front clip on '86 cab
bolts on
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
I know a 76 works on an 84..... It works
will everything bolt on with modifying anything?
You'll need to modify the wiper posts, as well as where the hood hinge goes into the cab. It's not as easy as it sounds. Your wiper posts will need to be 73-80 because of the way the cowl is connected to the hood on those years.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
The easiest way I have found to put the 70's fenders on to an 80's truck, is to drill all the spot welds out of the bracket that bolts to the cab. After you have the brackets off of both sets of fenders, cut the front end off of the brackets that you took off of the 80's fenders and weld them up to the 70's fenders. Then you have to get everything bolted up, remove the rivets from the front body mounts and relocate them. The wipers will need to be replaced as mentioned.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Happy to be here
![]() Join Date: Mar 2000
I have never done this swap, so I can't be 100% sure but I see some information that doesn't conform to everything I have ever read about this swap.
You do not need to modify "where the hood hinge goes into the cab" as the 77 hinges bolt to the fenders. You do not need to modify the wiper stands, you need to swap the 77 stands when you swap the entire front clip. You do not need to remove the rivets from the front body mounts and relocate them if you swap the early bushings along with the entire front clip. Did I miss any?
![]() Join Date: Apr 2009
Hmm... Ive got a perfect 77 clip that could go on the 88 ccdrw, and it needs paint anyway. You know whats wrong with board? You guys give me to many d@mn ideas.
![]() Posted via Mobile Device |
Laid back freak
1980 chevy c10 step side restomod, ![]() 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). |
Tags |
'77, '86, cab, front clip |
