Robert Olson Transport
![]() Join Date: Oct 2002
What did you get done th is week 9/19/11 edition
I was trying to get the new tilt column in but the lower shaft is wrong so im on a search for that as we speak. Friday night was the Keyport show and i went to that with a buddy and found some nice trucks.. ill post some up later
How about you all?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: What did you get done th is week 9/19/11 edition
We are getting ready for our fair this week so most of my time has been spent with the animals. We are trimming our 5 goats today for the show on Thursday morning. I did do something truck related this weekend though. I went to my bro-in-laws yesterday and we installed a set of 4.56's and a mini spool in his truck. The new solid roller 406 should like the new gears much better than the 3.07's we replaced. We were lucky. i reused the same pinion shim from the original gear and the contact pattern is perfect for a 69 series Richmond gear . I set it up at 20-25 inch pounds rotating force on the pinion since we replaced all the bearings . It has been a while since I set any gears up so it was fun. Lots of work but fun. We were able to get the backlash to right at .009 and the gear called for .010 so I left it there . It should work pretty good for him. I cant wait to see the difference . he is going to add fluid and break the gear in today. Back to the goat trimming .
Frank
Born and proudly residing in a Red State ! |
From
![]() To ![]() |
I worked 85 hours and found the time to drop my truck off to someone who has time to work on it. It could come back this week. :fingers crossed:
'76 C10 "BIG10" SWB 454/400 Mostly Stock. |
Old Heap Driver
Rained here all weekend so outside activities were a no go. Spent most of Saturday in the garage cleaning and putting things away.
My '50 is now in black primer and pretty much done. I'll post pictures when/if it ever stops raining. Took the Heap out today and showed her off to some childhood friends I hadn't seen in 40 years, had a nice time.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Got more of the wiring hidden under the hood and got the inner fender skin for the pass. side cut out and ready to mount.
I changed oil in burb and checked a spark plug. Looks perfict. Also changed wifes cars spark plugs in her malibu. Also went house shopping in the burb and washed him.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
Its starting to feeling a little like Fall in our part of the country. So I decided to install a new thermostat and flush the coolant in my truck.
Sometime in the next week or two, I need to check my front suspension. I am having a bouncy vibiration around 45 mph. I hope that it is just something simple, because I am not ready to redo/rebuild the entire suspension (have to wait on $$).
1984 C20, 454, 4 speed named "Gold Member" |
Took my old quadrajet off and put on my new Holley Street avenger 670 cfm. It all went pretty well, was adjusted correctly right out of the box.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD 1998 Trans am, mostly stock with magnaflow catback My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329 |
Old Heap Driver
I have that same carb on 2 of my trucks, love them. You're correct, right out of the box they were darn near perfect.
New front brakes on my crewcab. That went fairly easy, once the parts store got the correct calipers.
Turned out the passenger side flex hose was stopped up, though, and that's where things got ugly. At some point somebody cross-threaded the hard line into the flex hose where it passes through the frame, in addition to rounding off the flare nut. Took several hours and butchering both the line and the hose to get everything apart. And I haven't tried to do the driver's side yet. Hoping to round up some new hard line and get it back together this week. So much for a quick Saturday afternoon brake job. |
Got around to pulling my blown up 350. It broke a rod and busted the camshaft. I guess that would cause it not to run anymore.
Also started messing around with a 1977 350. 010 block, 4 bolt main. Put new rod bearings in it, got a Weiand aluminum intake and an Edelbrock 1407 carburetor. Also got the new motor installed today, along with a brand new clutch, and motor mounts.
![]() 305 ci | TH350 | NP208 | 60k miles |
Replaced a stripped out spindle, and busted shock.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Put new carpet in, but will have to remove it to have it painted. Also insulated the floor.
#15 |
I worked on a fellow board member's burb and the rest of the weekend took a CHL class with some friends. Today was the shooting proficiency portion. I passed the class, now to get all the paperwork together so I can get my license. My buddy that taught the class is Special Forces and really gave a great prospective on it all. The class was very informative, I'm glad I finally decided to take it.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
#16 |
Went 80 miles away to a swap meet and didn't find much of anything. I did get a great deal on a hose real for the shop.
Last night i'm glancing through craigslist and see a guy selling like new tires 235 /255/ 70 tires and 7 / 8 rallys like I want for the Burban until I can afford what I really want. Turns out they were 15min from where the swapmeet was so I drove 70 miles to go get them. ![]() Spent about 4 hours scraping and cleaning 34 years of grime and caked grease off a 454 from the truck I parted out. Finished up with Purple Power. That is by far the best cleaning product I have ever used. Don't look at the pan its not being reused. I wish I had taken a before pic but I forgot to. Picture it solid black with 1/8 to 1/4 thick muck covering it. ![]() |
#17 |
Slots go on anything!
I bought a used tire for my truck. It's a big step. It also led to 2 new ones.
1974 Jimmy- 5.3/4L80e/NP241 |
#18 |
Started working on putting electric window motors in my crew cab from doors. Woke up at 2pm from a long night before and then played xbox with some friends so it was a late start. Worked on it for an hour before I ended up going out to dinner and drinking a few to many and didn't want to mess something up. So it is sitting taken apart until tomorrow.
Current: 2012 Ford F-250 4x4 6.7 Powerstroke 1971 C-20 2wd 350/TH400 Former: 1979 C-20 2wd 350/TH400, 300+hp. Rattle can paint job 1982 K-30 454/700R4. 4in lift with 37" Goodyear MT/R's Lots of goodies - Trail clean up truck |
#19 |
Removed bumper horns
![]() Posted via Mobile Device |
#20 |
Getting Old; Going Broke
Sold my 79 K5, bought an 82 C10 to part out, sold my SWB frame (finally). Starting to make a dent in all the parts I have 'acquired' over the last few years. Surprised the wife is letting me buy new ones to part out, but she said it is a great hobby for me and it keeps me calm, and I make a few bucks.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
#21 |
How's it going, Randy? Haven't seen you in a while.
#22 |
#23 | |
Like Fernando said, "it's better to look good than to run good", or something like that.
#24 |
Got my new set of 10" rallys painted and new 295/50 BFG's mounted and bolted up on the rear of my '79 GMC. I gave the front rallys a fresh coat of paint early this morning, hoping to get them back on the truck by tomorrow.
#25 |
you get those rallies from summit? the 295's tucked in without touching the frame rails? I ask because I am thinking about going this route with mine.
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
