Old 11-08-2011, 06:53 PM   #176
darkhorse970
darkhorse970's Avatar
Re: Post Pics of your Static Drops!!
Originally Posted by blue64c20 View Post
That truck looks sweeet, what kind of wheels are you running on it?
Wheel Vintiques Smoothies, chrome outers with black centers. I have 2 different sets of hub caps for them.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 11-08-2011, 09:39 PM   #177
65Gregg
65Gregg's Avatar
Originally Posted by J.Cagle View Post
Did you have to notch the frame? id like to add blocks to mine but i dont want to have to notch right now.
I haven't put in a notch (yet), I am considering one of the Porterbuilt bolt in C notch though. As with all of Nate's products it appears to be outstanding. I'm only going to do so in an effort to gain more load carrying ability. Probably will add some helper bags so i can tow my boat.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 11-08-2011, 10:55 PM   #178
J.Cagle
J.Cagle's Avatar
Hmm. cant decide what to do. I have factory overloads on my truck that are nice but sure arent usable once lowered....
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline   Reply With Quote
Old 11-14-2011, 12:08 AM   #179
badriand
badriand's Avatar
2.5" drop spindles w/3" drop coils in front. 5" coils w/2inch blocks on back.
badriand is offline   Reply With Quote
Old 11-14-2011, 11:47 PM   #180
ApacheWillard
ApacheWillard's Avatar
Hey badriand...
You just have coils and shocks on the back, or a cnotch too? What about panhard bar or shock relocators? I'm about to buy a 3/5 spring and shock kit and am wondering if I will be ok in the back with just that, thanks!
ApacheWillard is offline   Reply With Quote
Old 11-15-2011, 10:40 AM   #181
badriand
badriand's Avatar
Oops for to add ApacheWillard. Yea i have a C-notch on back and a shorter panhard bar. No shock relocators. I did a notch with 5" coils on back and had tons of clearance ( at that time really didn't need notch). Now that i have added 2 inch blocks with the 5 inch coils i need the notch. Can't say for sure if you need notch or not (you can always add later or just take coils off and drop truck down and see what kind of clearance you have without notch.
Old 11-17-2011, 10:13 AM   #182
ApacheWillard
Hey what size tires you running by the way???
Old 11-17-2011, 11:20 AM   #183
tazattitude
tazattitude's Avatar
I also did mine 5" and 7"
front- 3" springs-2" spindles
rear--5" springs-2" block (slightly shaved and angled for pinion)
I C-notched the frame along with an adjustable panhard bar.
The top of the rear is actually closer to the bed wood than the rear to the C-notch. I have about 3" from the rear to the wood. No problems though
20" wheels all the way around
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 11-17-2011, 01:16 PM   #184
blue64c20
Sweet thanks for the info!
blue64c20 is offline   Reply With Quote
Old 11-18-2011, 01:26 AM   #185
badriand
badriand's Avatar
hey what size tires you running by the way???
215/75 r15
Old 11-18-2011, 12:17 PM   #186
badriand
badriand's Avatar
Here is a shot without caps on. Looks better maybe.
Old 11-18-2011, 08:42 PM   #187
stealth_weapons
here's mine front has POL tubular UCA/LCA, 2.5" drop spindles, CPP 3" drop springs. the rear just has CPP 4"drop springs
the Stealth Weapons 63 project, all comments, advice, and critiques welcome!
http://67-72chevytrucks.com/vboard/s...d.php?t=438235
stealth_weapons is offline   Reply With Quote
Old 11-18-2011, 09:38 PM   #188
Slow Build
Slow Build's Avatar
Is it just the angle that the picture was taken or is the bottom of the LCA pretty close to the ground? It looks like it's lower than the bottom of the rim.
Also what size tires are you running? Looks good.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-18-2011, 09:59 PM   #189
stealth_weapons
the LCA is without a doubt lower than the rim
here are a few more for reference
Old 01-08-2012, 08:50 PM   #190
farmtrucks
farmtrucks's Avatar
Originally Posted by XtechX View Post
Your set up is what I was thinking of doing or something like 1 1/2 cut coil in the front and a 4 inch in the back. (Yours looks perfect by the way)! But my question is.. Did you do any c notching or use any shorter shocks or shock relocators when you did yours?
Sorry it took so long for response...... no c notching. use regular 87 shocks in front, trimmed half the bump stop off. it will sometimes bottom out in a hard dip in the road... used stock rear shocks...
farmtrucks is offline   Reply With Quote
Old 01-14-2012, 12:42 AM   #191
AllenKarber
3" drop CPP Springs in the front,6 inch drop ECE coils in the rear.
AllenKarber is offline   Reply With Quote
Old 01-14-2012, 01:36 AM   #192
blackmopar
.............., 2.5" drop spindles, CPP 3" drop springs. the rear just has CPP 4"drop springs
love that rake Stealth! Ive got a 64 lwb that has 4" cpp springs in rear now and Im about to do the 2.5 spindles and 3" springs up front - Im hoping it comes out close to your stance!!
haha sweet! how much more (or did) the POL arms drop you? looks like how the lower arm 'cup' sits it would drop your shock height right?
blackmopar is offline   Reply With Quote
Old 04-14-2012, 06:40 AM   #193
robber grin
Can you tell me about notching the 62 frame? I've got to do it yet... thanks.
Last edited by robber grin; 04-14-2012 at 06:44 AM. Reason: added my year to the question
robber grin is offline   Reply With Quote
Old 04-30-2012, 09:01 PM   #194
big_rig
New to the forum and thought I'd learn about posting pictures. This is my work in progress/daily driver when theres not 6 feet of snow blowing around way up here. It's only lowered a little but I figure that counts for something.
big_rig is offline   Reply With Quote
Old 05-01-2012, 07:32 AM   #195
Fastest32
Fastest32's Avatar
I see alot of people on here with six lugs who say they are using drop spindles. What spindles are you using, and did you have to change to disc brake set up? What rotors are you using if so?
Fastest32 is offline   Reply With Quote
Old 05-01-2012, 08:49 AM   #196
robber grin
On my 62 C10 I'm going to use BELL 2 1/2" drop Spindles and McGaughy's 6 lug rotors on a 78 'burb clip with 3" drop coils.
The aftermarket drop spindles that you see are set up for HD brake using the 1 1/4" rotors vs the LD 1" rotors.
So if you buy the drop spindles you can run stock HD 1 1/4" 5 lug rotors or aftermarket 6 lug rotors...
OR you could run the 6 lug rotor on a stock HD spindle if you don't want the drop.
I'm unaware of a LD brake rotor option that would allow you to run 6 lug wheels...
Let us know what you come up with and PICS are always fun too!
Old 05-01-2012, 10:23 AM   #197
Fastest32
Fastest32's Avatar
I have a whole set up off of a 79 but wasnt sure about the rotors. I have a set of five lug rallies from my old truck but wasnt sure If I could just swap out rear axles to make the rear five lug. Im not really ready to do the whole front end swap yet either. I posted a pic of my truck on the other thread thats exactly like this one but Ill go ahead and post one here too. I cut 1 1/2 off of the front coils and used jeep springs in the rear. It rides really nice but I havent tried hauling much in it yet. I have a set of those overload air bags I can install if its too weak.
Old 06-11-2012, 08:00 AM   #198
66clow
66clow's Avatar
ccp drop springs, notched in rear
66clow is offline   Reply With Quote
Old 06-11-2012, 09:44 AM   #199
Fastest32
Fastest32's Avatar
that thing looks awesome.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 06-11-2012, 10:21 AM   #200
NCD1966
NCD1966's Avatar
cut 1.5 coils up front off of stock spring; rear has 1998 jeep grand cherokee rear coils with 1 coil cut and 1-5/8" lowering blocks (they were 2" blocks)
rides smooth and handles great for a cheap drop
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
