11-17-2011, 11:30 PM | #26 |
Truck and auto performance nut
Re: drill and tap head for temp sender?
Just tap the head. The size the metric hole is vs a 1/8 NPT sensor (I think that's it?) is very little.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-18-2011, 12:38 PM | #27 |
The temp sensors in 67-72s are 1/2 inch NPT and is much bigger than the threaded metric hole in the LS heads
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
11-18-2011, 04:13 PM | #28 |
oops....my mistake. I thought we were talking about an LS head and aftermarket sensor. my temp gauge is an autometer and not the OEM.
continue on!
11-20-2011, 02:05 AM | #29 |
LSX addict
i didnt have any trouble getting it done with the engine in the truck. (A/C stuff is out right now tho). but i just drilled it out and used a ratcheting wrench to tap it. worked great.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] |
11-20-2011, 12:55 PM | #30 | |
11-27-2011, 09:39 AM | #31 | |
did you drill and tap the head or turn down and tap sender -- I'm wanting to use my stock gauge on a 68.
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
11-27-2011, 10:01 PM | #32 |
I purchased 323092 and bolted it on. Have not tested or used it yet though.
11-30-2011, 12:03 PM | #33 |
I've drilled and tapped the head on 3 or 4 swaps, it isn't hard if you have the correct size drill bit for the tap, and yes, it's a BIG bit. I start with smaller bits and work my way up, putting grease on the bits and tap to catch the shavings. This is a factory '72 sensor in my current 5.3 swap.
Posted via Mobile Device |
11-30-2011, 05:34 PM | #34 | |
I think now that my engine is in I'll just tap the block plug. I just need to find a 23/32" bit. |
11-30-2011, 05:38 PM | #35 |
12-01-2011, 02:31 PM | #36 | |
12-01-2011, 02:58 PM | #37 |
I did and the Ohms are way off - so it will not read right.
12-03-2011, 01:04 AM | #38 |
12-04-2013, 12:48 PM | #39 |
For the old school sbc some aftermarket intakes have 1/2" npt on the intake near waterneck.
72 GMC Sierra 02 Trans Am Firehawk 91 Firebird Formula 350 06 TBSS (RIP Wife T Boned at intersection ) 04 Tahoe 6" Lift 97 AWD Astro Work Vehicle/Beater |
12-04-2013, 12:56 PM | #40 |
Many of the short waterpumps also have 1/2" npt port on top. I would think this spot would work as well. Haven't tried it so don't quote me on that one. I would think the one on the side of the wp would read the suction side of wp and wouldn't be accurate for engine temp., although it might be handy to know what the outlet temp of the radiator is.
12-04-2013, 12:58 PM | #41 |
Yea, old thread I know. Just needed this type of info and thought I would add to it.
12-04-2013, 07:14 PM | #42 | |
I think you will find there is not enough "meat" on the small 13mm end of the sensor, BUT you will find what you always want to know what is inside !!!
12-06-2013, 08:50 PM | #43 |
Don't know if this will help for the original post which was about a 91 gauge cluster, if u get a sender from a 99 firebird it has 3 wire terminals, u can get a pigtail too, the plugs are realllllllyyyy easy to take apart, jus hook the two factory wires in the same spot then use the third for your temp gauge, no adaptors or machining required and the ohms are the same, I did that on mine and it matches the computer reasons exactly and we have measured it with a infered gauge and is right on, hope this helps. Also that sender will fit on either head.
Dan G Lift it, fat chicks cant jump! 83 Chevy shortbed 4x4: 6.0 ls powered 97 Chevy 3/4 ton ex cab 454: work horse 00 Chevy camaro: daily driver 83 Chevy 3/4 ton: dads old rig |
12-06-2013, 08:52 PM | #44 |
The sender has to be from a firebird, they were the only ones that had the 3 wire setup!
12-07-2013, 01:27 PM | #45 |
I picked up an M12 x 1.5 die, and a 3/8 factory sender, put the sender probe section in my drill with a file in my vise, spun it until it was the size I needed. then hit it with the dye, worked out great. Pictures here http://carburetorssuck.com/index.php...ulletin&blog=8
12-07-2013, 01:29 PM | #46 |
I have the three wire sender, so you are saying it matches the ohm range of the 81-91 square body temp gauge?
