Old 11-28-2010, 05:32 PM   #1
lha1992
lha1992's Avatar
Reverse lights do not work?
Well, one of the problems I've been needing to fix on my truck is that the reverse backup lights do not work. I checked the bulbs and there okay and everything. What else should I look at to make them work again?
Oh, and the truck is a '89 silverado C1500 with a 700R4 tranny.
lha1992 is offline   Reply With Quote
Old 11-28-2010, 05:44 PM   #2
1badgmc
1badgmc's Avatar
Re: Reverse lights do not work?
When I bought my '91 way back in '96 the reverse lights didn't work. I never bothered to fix them. Now I don't even have reverse lights at all.
Old 11-29-2010, 12:27 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My left b/u light "sometimes" on me. Sometimes it works and sometimes it doesn't. I think it has to do with the "circuit board" in the taillight ass'y, but I'm not going to lose any sleep over it right now.
Member Nr. 2770
Old 11-29-2010, 04:37 AM   #4
bucannon
Salty Sailor
bucannon's Avatar
mine dont work unless i hold the shifter up just a tiny bit while its in reverse, my assumption is a worn out switch in the column. probably the same issue your facing. have somebody stand behind it while you move the shifter slightly while its in reverse and see if the lights come on
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 11-29-2010, 01:24 PM   #5
chrismcc2011
i have the same problem in my 90 chevy. it sucks at night and cant see anything behind you.
1964-1966 chevy swb not sure on year yet.
1972 swb (dads truck for now)
1990 shortbed stepside.
chrismcc2011 is offline   Reply With Quote
Old 11-29-2010, 02:09 PM   #6
RLTW375
Same here on the 94 I just got. But I haven't tried anything yet, trying bulbs and fuses today. But this goes along with no dome light parking brake light on no power locks ect.... I've got some work ahead of me.
72 CST Blazer 4x4 (Revival in progress)
http://67-72chevytrucks.com/vboard/s...d.php?t=430968
RLTW375 is offline   Reply With Quote
Old 10-07-2011, 02:24 PM   #7
Ricky78045
Ricky78045's Avatar
I have that same issue with my 88, if I don't tap up it won't read it, I'd like to fix it but I don know for sure what it is
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road...
1988 Chevrolet Silverado Single Cab, Short bed, 350, 5.7L: daily driver/on a budget restoration
Ricky78045 is offline   Reply With Quote
Old 12-06-2011, 10:20 PM   #8
Ricky78045
Ricky78045's Avatar
update for me: i fixed my issue it was the circuit boards they were kinda toasty and looked a bit like a short went on there...
Old 12-10-2011, 06:45 PM   #9
89chevsj
error 404
89chevsj's Avatar
mine is a bad switch. not sure where it is but I've noticed that when the spring that pulls the shift lever forward is going out the switch won't work properly.
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
Old 12-11-2011, 10:05 AM   #10
dishow
dishow's Avatar
mine is the same way.hit and miss. changed the switch,still the same.its hooked up to a toggle switch now.they have to work for inspection here.
90 Chevy 454 ss
Old 12-11-2011, 03:25 PM   #11
Ricky78045
Ricky78045's Avatar
the backup light switch is at the base of the column close to the pedals, its a white one. before i would have to tap up on the shifter after putting it in reverse to make the lights turn on, i put the truck in bulb test and popped it in reverse and adjusted the backup switch. thats what happend to me, might be something that could help one of you.
Old 12-11-2011, 04:04 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Update for me, too. My circuit board on the left side was afflicted. Where the backup light plugged in (OEM board) the contacts had gotten hot and melted down into the plastic. The replacement board, from O'Reilly's, has a different socket and I like it better than the GM part. Don't like $25, but that's okay.
Member Nr. 2770
Old 12-12-2011, 12:16 PM   #13
tattoed71
tattoed71's Avatar
mine was the po took the bed off to put a new pump and forgot to hook up the ground wire
tattoed71 is offline   Reply With Quote
Old 12-12-2011, 12:27 PM   #14
Bardahl
Its on the column unless you have a manual transmission, then its located on the shift linkage/ transmission somehow/somewhere, i got lucky on my 2 68s it was one thing I really didn`t think to check and they work on both trucks??, one is a 3 speed on the column and the other is a auto.
Bardahl is offline   Reply With Quote
Old 12-12-2011, 02:53 PM   #15
mountie
mountie's Avatar
On the '88 and up, so many years, there was a GM technical service bulletin to change out the tail light socket assy with the newer style plug-in. Funny.... my old style socket melted back in '91 and they replaced only the one side, making me buy 2 different styles bulbs. The melting happened if the brake light stayed on too long.
I may be wrong, but, the reverse back-up light switch actuator(wire/plug) is on the driver's side transmission and the reverse switch adjustment is on the column?
I need to put "a little English" on my shifter also, to turn on the back-up lights.
mountie is offline   Reply With Quote
