99 Classic Tahoe 2wd 4dr custom project
I few months ago i bought a 1999 2wd tahoe 4dr with 116,000 miles on it...Nice clean...but 100% stock..
It now has 118,000 miles on it..15 mpg average...not bad for a full size..suv.. I gave 1250 for it...was donated to the kidney foundation..100% of my money went there. to a great cause.. |
Re: 99 Classic Tahoe 2wd 4dr custom project
I then came across this deal...2000 2wd tahoe limited wrecked hard in the front end...with heavy front frame damage..
going to put all the limited stuff on the 99 i have... |
1st mod....wheels...next is the gibson exhaust and the ground efx...
Nice! looks like fun.
I have to drill out the 60 big rivets gm used to hold the lower side ground efx on...wow they didnt want those to come off...
![]() I would try and fix the 2000 but with salvage title and frame damage..its worth more in parts..Plus i am keeping the tahoe for alot of years ahead...so i will have extra engine/trans and rear..ect.. |
I am selling the limited leather seats in the 88-98 parts section...
I am not going to use them...i like my cloth seats in the 99 better... They are nice and hard to find seats.. I got the front clip off the 2000 today...will have more pics tomorrow motor/trans and rear are coming out next.. The 2000 also is the Police package Z56 option... driveshaft...is different,the rear brakes are 11 inch .. |
I put the z56 front sway bar on my truck and I could tell a difference if its not bent make sure you swap'em out.
i allways wanted a set of those wheels nice project
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
sway bar is fine...going on...I have the front clip off the limited and getting ready to pull the motor/trans out..
I will have more pics soon.. |
I have all the drivetrain out and off...I will be rolling out the 2000 out of the shop tomorrow...I will post pics then..
Then its time to do exhaust and ground efx..on the grey 99... I will post pics so you all can see how they were put on.. The police package on the limited includes 3/4 front brake calipers..that take a "370" pad instead of a "369" pad as the 1/2 does.. the rear has 11 inch drum brakes..borrowed from the suburban. GM should have put disc on the rear...come on a 2000 model with drum brakes...Its not 1970 anymore ![]() They will get upgraded later |
I put newer 16 inch tires on the limited wheels today..
got the limited rear bumper,trans,motor...,gas tank, rear end ready to come out today...and got it rolled outside...Pics tomorrow... almost ready to start putting the ground efx on...in a few days..I have some work to do...1st |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I cried when I saw that wrecked Limited. Did you know they came with 3:42's and posi (G80)? I am curious, does it say Z56 on the spid label? Put as much of the Limited Suspension on your DD Tahoe as you can because will love the way it handles. I know what I'm talking about as I've had this Z56 for 3 years and can't wait to drive it every summer.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Yes 3.42 posi...but its the gov-lock...thats coming out..and a 91-96 caprice/roadmaster posi unit going in...same spline..and its the auburn clutch type posi...I have one in my 94 truck..it.does awesome..
11 rear drums and rear swaybar... Z56 option..is there ...police brakes. (3/4) ton calipers..on 1/2 spindles.. 370 pads instead of a 369 pad.. Rear is going in the 99 soon...The little brakes on the rear suck for towing...gm should have went disc on there models long ago.. I tried the 2000 ecm in the 99 and it would not even start? Is this because of the vin in the ecm? I had 2 97 trucks here and swapped and it runs fine...? |
and i got the limited for less than they want for a used vortec 350 around here....
#15 |
This thing rocks I've never seen one before, with that cop suspension under it would be a blast to drive and it looks killer. If I got one I might do a color change. Maybe slap a supercharger under the hood. And the gmpp emissions legal 383.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
#16 |
I am going to go from the bottom body line down...black...leave the top grey..and put a stripe done on the piant line..and loose the mouldings ,and get a new front bumper from lmc..the cheapest i could find..with the air intake holes..and ,both black bumpers..and a black grille..
I put the sway bar on yesterday..and it does make a difference.. The limited was a 1 3/8 inch bar...the stock was 1 1/8 inch exhaust is next...then ground efx while its on the lift.. I should have named this thread "Project Battleship SS Tahoe" its battleship grey and its a battle out on the roads around here.... ![]() they cannot keep on there side on the centerline...on a 2 lane road.. |
#17 |
I got 4 new center caps for xmas..
#18 |
well i fixed the exhaust today,put on the ground efx..they take the big rivits like the window regs. do..
#19 |
and a few days ago..i put the limited out to rest for a while...without a power plant
![]() I will buy another one from the salvage sale and fix it wih the parts i have.. I can get an esclade..or a yukon...or a tahoe and fix one...light roll...2wd or 4x4...dont matter to me.. |
#20 |
whered you get the center caps at?
#21 |
The 2000 limited wheel center caps...I have a source for them...
![]() I can get a set of 4 for $150 or they are $50 each. $165 shipped for a set of 4 |
#22 |
are they the GM caps or Ronal caps?
#23 |
Edit: nevermind dude, i found out where you got them and in the mean time ive lost all respect for someone buying **** on ebay and trying to make money on the forums.
http://www.ebay.com/itm/140516243204 really man? I dont think ive seen anyone do this before esp on the forums, maybe craigslist.... |
