Old 01-22-2012, 03:52 AM   #1
old crewcab
97 2wd tahoe tranny
I have a question in regards to replacing a tranny in a 97 2wd tahoe. will a 4l60e from a earlier model work ( 93-94 ) ? I have been told buy salvage yards this a 1 year specific (97) only. But I ask why and they just say its what computer relays to them. Does anyone have any input on this? It seems to me a truck, tahoe, or suburban 4l60 of most year would work. Any help would be greatly appreciated......thanks dave!!
old crewcab is offline   Reply With Quote
Old 01-22-2012, 11:55 AM   #2
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: 97 2wd tahoe tranny
i have a 97.. never heard of it being a 1 yr only.. when my trans went out, i had it rebuilt, did not go the salvage yard route...
tommie is offline   Reply With Quote
Old 01-22-2012, 12:20 PM   #3
Alderson95
i think ur right not about the 1year tranny tho. in 97 gm changed the bell housing design on 4l60e. instead of a halfmoon bell housing they went with a complete detachable bellhousing. i think when they did this it resulted in the trans being about 3in longer than before. because i sold a 2wd 4l60e to a guy with a 99new body style truck. it turned out the trans i sold him was to short for his truck. but he did have the new vortec 5.3lin the truck so im not sure if that would have made a difrence. thats just my 2cents.
Alderson95 is offline   Reply With Quote
Old 01-22-2012, 12:32 PM   #4
bwood
bwood's Avatar
I believe the the earilier 93-95 model will bolt up, but will not work with your electronics. If yours is not a two piece bell housing your selection my be limited to just 96 and the 97s like yours. Mine is a 98 with a two piece bell housing. I'm not 100%, but I bet member clinebarger can clarify, he is the man when it comes to transmissions.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 01-22-2012, 09:03 PM   #5
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
my 97 was not a 2 piece bell housing...
and this was the 1st rebuild
Old 01-23-2012, 12:11 AM   #6
texasfunk
texasfunk's Avatar
Hmm..my 99 tahoe isnt a 2-piece either..
texasfunk is offline   Reply With Quote
Old 01-25-2012, 05:25 PM   #7
old crewcab
Question Re: 97 2wd tahoe tranny
any one else have any more info on this subject? thanks dave
Old 01-25-2012, 06:34 PM   #8
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
i looked on one of the salvage parts listings i use for a 97 tahoe trans.... it only showed 1997 results... it normally shows the interchange between other years....
maybe it is a 97 only trans.... just never heard of this before...
Old 01-25-2012, 07:14 PM   #9
clinebarger
93 & 94 4L60Es are "NON-PWM" and will not work.
LS "300mm" 4L60Es will not work because of the converter spacing.
Your interchange will depend on what 4L60E you have....A 1 peice or a 2 peice case.
The reason for it listing the 97 as a 1 year only is because of the converter clutch friction material...Woven Carbon Fiber Clutch material that was only used on a 1 peice case 4L60E in 97.
The original 700R4 and 93-94 4l60E used an on/off type lockup. Meaning it was off or fully locked on.
In 95 they went to a PWM (pulse width modulated) lockup, which controls the aggressiveness of the apply and release of the torque converter clutch and allows a bit of slippage for a smoother feel.
In 97 GM went to a different strategy called electronically controlled capacity clutch.
In order for this strategy to work a new converter clutch lining had to be developed to withstand the slippage and heat generated. What GM came up with is a woven carbon fiber material that is very porous that allows fluid to flow though it for better heat transfer.
Using a older converter with a graphite composition lining will not work long.
clinebarger is offline   Reply With Quote
Old 01-25-2012, 07:40 PM   #10
clinebarger
Thats odd. The 2-peice case came out in 98, But GM could have been using up 1-peice cases I guess.
Old 01-25-2012, 11:41 PM   #11
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
some other things i found...
http://www.novak-adapt.com/knowledge/4l60e.htm
The key distinction of the Later 4L60-E (1997-2006) from the Early 4L60-E (1992-1997) or 4L60 (1990-1992) or 700R4 (1982-1989) is the six-bolt "hex" rear output or tailhousing / adapter pattern. The previous versions featured a four-bolt square bolt pattern at the adapter or tailhousing. Additionally, the removeable bellhousing is also another distinguishing feature.
Old 01-26-2012, 05:03 PM   #12
old crewcab
clinebarger, my trans has the one piece case, so if i used my converter with an older 4l60e (pre-97) would this combination work?
Old 01-26-2012, 07:19 PM   #13
clinebarger
Yes, You can use yours or a rebuilt 97 & up converter, It still limits you to 95-97 transmissions. If the trans you have is burnt-up/broke the converter needs to be rebuilt/replaced. & be sure to flush the cooler lines.
Old 01-26-2012, 10:19 PM   #14
old crewcab
just to clarify, only 95-97 tranny will work if i use 97 converter. or will 93-97 (4l60e with 1pc case) tranny work with a 97 converter? Sorry to keep asking but I have good deal on a older tranny, but do not want to install if it will not work. Thanks...Dave!
Old 01-26-2012, 10:50 PM   #15
clinebarger
A 93/94 will not work, They do not have a PWM solenoid.
Old 01-27-2012, 04:41 PM   #16
old crewcab
thanks for all of the info!! dave
Old 02-19-2012, 11:08 AM   #17
old crewcab
hey clinbarger (or others) found a doner truck '96 1/2ton 4l60e. if i am correct,this tranny will work? you say 97 converter... is it a stand alone piece (at the parts stores) or do i need to ask for something specific? also, how long do you estimate the '96 converter would run if i used the one thats in the doner truck? thanks!!!
Old 02-19-2012, 03:37 PM   #18
old crewcab
any info?
Old 02-19-2012, 06:40 PM   #19
clinebarger
I whouldnt risk running the converter, But if both the codes on the converters are the same....Go ahead, But I highly doubt they will be.
If you run the wrong converter.....The lock-up clutch plate will burn up.
You can have your 97 converter rebuilt. Or buy one. The actual name is Torque Converter.
Old 02-19-2012, 09:02 PM   #20
old crewcab
clinebarger, the reason for all of the questions is that this tranny and torque converter was put in about a couple of years ago, but there are not a lot of miles on it. that being said i am wondering if i got hosed on my purchase. with all of the info i have been gathering (mostly from you-thanks) it sounds like all the characteristics of wrong components. now, after all of that, will a 95,96,97 4l60e with a new 97 torque converter do the trick? If I go to the parts houses there should only be one listing for the converter (97 only) ?
Old 02-19-2012, 10:17 PM   #21
clinebarger
Match the code on the converter that "originally" came on your truck!
Yes you can run those year transmissions.
Old 02-19-2012, 10:42 PM   #22
old crewcab
no original converter to match numbers with. so parts house converter for '97 hopefully will do the trick?? thanks
