#251 |
Re: my 65 fleetside build
OH, I forgot to ask you if you fitted the door back on to check the gap where you removed the drip rail?? Im curious how that looks. Mine needs some attention bad, got to figure out what to do with my drip rails.
#252 |
flip the cab is coming along very nicely, i thought of doing the same with the seams, filling them in for a smooth look! i got a question for you too! are you using body filler over the epoxy or the other way around?? i've heard you can epoxy then use filler as long as its in the 7 day flush time! just wondering i'm thinking of buying a compressor this summer to paint my truck myself and to make some of this work go a lil faster!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#253 | |||
#254 |
came home today and blocked the back of the cab and roof today, hopefully i can do it again tomorrow. firewall is done, i am dying to spray the firewall and bottom of the cab....... must be patient, or at least thats what i keep telling myself
#255 |
Oh Yeah, That cab is looking good! Dont forget to snap a pic when you fit the door back. Where did you find that epoxy in a spray can? Have to order it online??
#256 |
1 thing at a time is progress.
Looks like an awesome job.
![]() Posted via Mobile Device
Alan
Philippians 2:14-16 |
#257 | |
thank alan, cant wait to see how your hood turns out, still have my fingers crossed. |
#258 |
heres a few pics from todays progress outside of cab should be ready for 600 and paint, now to the inside.
#259 |
a couple more
#260 |
Rollin' Old Skool
that's looking good!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#261 |
Oh Yeah, Those gaps dont look bad at all. I think im going to take my bad one off first and see how mine looks. Bad thing is I just flipped my cab back over today to put seam sealer in and do final blocking of the roof and final paint on the bottom of the cab. Are you going to paint your cab before you put it back on the frame??
#262 |
Wow, that is looking really good!! Awesome work on your rocker sir!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#263 | ||
thanks, i appreciate it.
#264 |
i went today and rounded up a 72 accelerator assembly and installed in my cab,doing away with the metal rod and going with a cable, special thanks to my brother for the donation. here is a few pics.
#265 |
ok, today i finished up some loose end and sanded the the inside of the cab, finished my kick panels and smoothed out the firewall where i had massaged it to clear my tall valve covers.then primed using the slick sand primer, man is that stuff thick.oh well heres a few more pics, the cab is almost ready for paint. now to get on the doors.
#266 |
a couple more
#267 |
![]() Join Date: Feb 2005
Looks real good
#268 |
Man that is looking fantastic!
Next month, the week of Valentines I am pulling a marathon in the garage. I am subletting my neighbors half of the garage, pulling that '85 Sierra in, and stripping it down. I mention this, because now I am going to look at the accelerator on it, and if it is a cable I will probably yank it too. That looks like a great idea on yours so of course I am going to have to see about copying it!! ![]()
#269 |
Your not wasting any time. Yes Slick Sand is thick as you well know by now.
Alan
#270 | |
I only have a 33gal Craftsman air compressor, and I am not sure if it is big enough to warrent the purchase of a spray gun. I am also thinking I have to order Slick Sand, I have not seen anything close to it in the autoparts shops around here. Or should I be calling paint stores like Sherwin Williams?
#271 | |||
thanks nobby, really appreciate the kind words
#272 |
Wow flips, Your cab looks great, You are flying on that thing, I see you having it ready for the charlotte auto fair show. lol. Did you mean you used a 2.5 tip in the spray gun. I have a gun with a 1.7 tip. That must be some thick stuff. I been using nason full fill sandable primer. Nice job, keep up the great work and keep the pics coming.
#273 | |
#274 | |
you can thin it down and it still works great, even thinned its thicker than most high build primers i have used(which isnt alot) just dont get it to thick or it will crack or so they tell me, alan would defintely know more about it than me. |
#275 |
came home today and blocked my dash and went over my rockers once more then re-primed. took my passenger side door apart and started stripping the paint to see how much fun i was going to have its not real bad very little rust but it has a nasty crease in it, heres a few pics.
