72ChevyStep
![]() Join Date: Jun 2009
C-10/K-10/K-20 Restored Cab
What is a 1968 Restored HIgh Bump Cab with title worth?
Without Title? |
VA72C10
![]() Join Date: Mar 2008
Re: C-10/K-10/K-20 Restored Cab
How's the header area, dash, around the window, cab corners, and especially the mounts?
Is that welded repair only or fiberglass/bondo on the driver's side? All that plays into the value. If it's a K truck is the correct # frame with it? That makes a big difference to...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#3 | |
72ChevyStep
What's restored on it? I need a better description and/or pictures. If that's a patch at the driver side floor by the kick panel,then that's repaired,not restored. Restored would be a new floor pan,seam to seam,so you couldn't tell anything was fixed. Restored means put back "as original". Even a properly repaired cab is worth decent money. It sure beats one that's rusted out. But a buyer wants to know they are paying for something that will hold up and be a better option than repairing what they have. Values are all over the place from $500-up. In the end,no matter if it needs repaired,been repaired,or is thoroughly restored,what I find determines what it's worth is based on a complete and honest description. Not everyone can appreciate the work and/or expense saved by buying a bolt-on cab.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-28-2012 at 11:14 AM. Reason: Had to add some "L"s |
