odd dash lighting issue
Does the dash wiring somehow get power via the same harness as the radio? About a week ago I pulled the old AM radio and didnt drive it or start it since then. Now, I have no dash lights and the temp gauge and alt gauge dont work. Nor does the fuel gauge. Im hoping its simply because I dont have the radio hooked up. Also, the turn signal indicators in the dash stay on now but will flash when I use the signal. I dont have a diagram to go through and verify, thanks for any help
Re: odd dash lighting issue
Make sure the harness is still plugged into the bezel (left side of speedo). I pulled my radio to get to the heater controls and jostled mine loose. Lost most of my dash lights and gauges.
Beyond that, I got nothin'.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
78K & 79C Jimmys
they do all run from one ground (less then a foot from the cluster plug)
and the grey for the radio/heater light is run the same as the cluster dimmer if you look back threw my 78 jimmy it will show you more
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
It does sound like a ground issue.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
thanks for the help fellas, got a better idea now
Winner Winner Chicken Dinner
Thanks motornut and silver eagle
You guys were right, one lone wire just behind the left A/C vent the ground had simply separated from the terminal that bolts to the E-brake bracket. Turn lights on, dash stop working, touch wire to terminal it jumps back to life. |
