Old 09-02-2003, 09:29 PM   #1
orange71
Air bags with longer studs
I am having problems trying to bolt the rear air bags through the frame and the c-notch. It seems that the threads need to be about .25 inch longer. anyone know of any bags that have longer threads or what i can do to get these to work. By the way they are the firestones 2600's
Any help is always appreciated!!!
Chris
orange71 is offline   Reply With Quote
Old 09-02-2003, 09:49 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Pics here would be great!!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 09-02-2003, 10:15 PM   #3
SCOTI
SCOTI's Avatar
Do you have the bolt in style c-section? That's what I've got on the rear of my 68 & I didn't run into any problems. I used a nylon crush style nut on the studs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-03-2003, 10:48 AM   #4
Slammed67
Progress = 0%
Slammed67's Avatar
I have the some problem. I was only able to get about 1-1/2 turns on the nut. It's held so far but I don't like it. Here is my plan. I'm going to unbolt the c-notch and enlarge the holes in the frame to they are larger than the nuts. Then I'll bolt the c-notch back on and then will be able to thread the nuts on. The bag will then be attached only to the c-notch and the nuts will be recessed down in the frame. I'm pretty sure it wil work. Make sense??? I just need to make sure I make the holes large enough for a socket to fit through so I can tighten them down.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 09-03-2003, 01:08 PM   #5
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Buy slam bags, then you choose the length of the stud or bolt
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 09-03-2003, 02:47 PM   #6
fastbagged68
fastbagged68's Avatar
Nsane have you been in a truck with Slams in the rear? I was wondering if they are too stiff for the rears. I am running slams on my front. On just about all the cars we do now we run slams up front, but we have not used them in the rears yet.
fastbagged68 is offline   Reply With Quote
Old 09-03-2003, 06:42 PM   #7
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
I got em all around. However my truck has not seen the road yet for a test drive.
But the Slam bags seem to be the best constructed bag I have ever seen or used.
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 09-03-2003, 10:58 PM   #8
72MARIO
72MARIO's Avatar
Are the slam Bags what you sell in you kit ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-03-2003, 11:43 PM   #9
orange71
slammed 67 thanks for the idea i was thinking about the same thing but was not sure. also what type of shocks do you run all the way around with the bags. i am running shock relocators in the rear but i am not sure of what to do.
Chris
Old 09-03-2003, 11:59 PM   #10
Slammed67
Progress = 0%
Slammed67's Avatar
Chris, I'm running Bell Tech Nitro Drop shocks all around. I got them with my Early Classic 4x6 drop kit before I decided to go with bags. I've heard good and bad about them. I have nothing to compare them too, so I can't really say if I like them or not.
Old 09-04-2003, 10:49 AM   #11
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Yes for an upgrade of $150
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 09-04-2003, 12:38 PM   #12
Izzy
Trucker.
Izzy's Avatar
Slams should be fine for the rear of that beast. If it were something lighter like a mini truck I'd say stick with firestones.
Izzy is offline   Reply With Quote
Old 09-09-2003, 12:05 AM   #13
orange71
well i finally sucked it up and got the slam specialties RS-72 air bags. i then used 1" bolts and they bolt through everything perfectly. the bags were $100 a piece ( ouch!!) but in the end i think that it will be worth it. They are diffenently alot stiffer than the firestones but they look alot stronger!!
