03-24-2012, 10:57 PM | #276 |
Re: Crash's 72 K10
Started off Saturday by getting the lower rocker area ready for the rocker.
Then I patched all of the rust spots I found sandblasting yesterday.. Then I did the cutout for the high hump.. Finally this evening I cut the firewall out of the old cab to put in the new.. I need this to keep the foot brake… My lovely wife and I took a mid-afternoon boat ride.. We found a friend.. 3 ½ ft. cotton mouth.. I decide to kill it, due to the little kids running around the marina…
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
03-24-2012, 11:01 PM | #277 | |
Re: Crash's 72 K10
Thanks.. I feel like I am getting close.. I need to start getting ready for primer and bondo.... Once again, thanks for the support..
03-24-2012, 11:04 PM | #278 | |
Re: Crash's 72 K10
Thanks.. Yes it seems like I have been working on this cab for a couple of years.. The mechanical and electrical stuff comes so easy for me.. this rust repair seems so foreign... I am looking forward to getting started on my doors.. Good luck with your build..
03-25-2012, 12:15 AM | #279 |
Still Learning
Re: Crash's 72 K10
Very nice work Mark! You have come a long ways in a short time on this cab, especially only getting to work weekends on it. I can only imagine you would be painting it if you had in your garage at home. Nice looking viper you found there.
I hope you are finding me some fish.... |
03-26-2012, 12:34 PM | #280 |
Re: Crash's 72 K10
Sunday I got to spend a few hours on the cab.. I started off by sandblasting the patch I cut out of the old cab. While I was at it I sandblasted the parking park and main brake supports..
Then I welded in the patch.. This will allow me to use the footbrake instead of the hand brake. I am thinking of using the piece I cutout on the other side to balance out the firewall. I would need to patch a hole or two, but it has the right shape and the correct lip.. Next weekend I will start patching the firewall...
03-26-2012, 12:38 PM | #281 | |
Re: Crash's 72 K10
Thanks Mike.. Not sure where I would be if I had access to it everyday.. Sometimes I think it is a good thing for it to be a couple of hours away.. Speaking of paint and primer.. When are you going to start on yours? I hated to kill the snake.. he really wasn't hurting anyone.. yet anyway.. But when I seen that little girl playing a few feet away, I really did not have a choice.
03-26-2012, 12:46 PM | #282 |
VA72C10
Re: Crash's 72 K10
Nice work! I really think it makes the engine bay that much nicer when the firewall is balanced like you're considering.
Looking for a 67-72 swb or blazer project in or around VA. |
03-26-2012, 01:05 PM | #283 |
GEARHEAD
Re: Crash's 72 K10
Good idea on the passenger side of the firewall. Do it.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
03-26-2012, 01:52 PM | #284 |
Re: Crash's 72 K10
Looking better with every post man.
~Jon Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=516056 |
03-26-2012, 04:11 PM | #285 |
Still Learning
Re: Crash's 72 K10
Good job on the e-brake patch. I really like the idea of moving the left over to the pass. side. Just like you to be planning
03-28-2012, 10:39 AM | #286 |
Re: Crash's 72 K10
What did you end up doing about the extra wires on your Range selector switch? Also I have extra wire on my TAC, which I beleive are for the cruise control. Should I leave them in the harness to set up cruise later? Or are aftermarket cruise systems like the one dakota digital has stand alone as well? Just having some brain farts. I think I have been staring at this harness to long!
Jason |
03-28-2012, 10:57 AM | #287 | |
Re: Crash's 72 K10
BeefyLoeDirt, I did not use the extra wires in the range selector switch. I kept the extra wires off of the TAC - They are for the cruise.. and I plan to use them.. It is easy to have a few brain farts dealing with the wiring harness.. lol...
03-31-2012, 11:33 PM | #288 |
Re: Crash's 72 K10
Firewall work…
Tomorrow, I might install the new tank…
03-31-2012, 11:41 PM | #289 | |
Re: Crash's 72 K10
Thanks to all of you.. I hope to drive this #$@%thing someday ;-)
03-31-2012, 11:43 PM | #290 |
Still Learning
Re: Crash's 72 K10
You knocked the firewall out quick! That tank looks great too.
Posted via Mobile Device |
03-31-2012, 11:48 PM | #291 | |
Re: Crash's 72 K10
Not finished with the firewall yet.. Still have to finish welding it, and then I have tons of grinding and sanding to do.. Hopefully I can get that done tomorrow.. I need to figure out what to do about seats and get that fab up soon... Hope you are having a great weekend..
03-31-2012, 11:55 PM | #292 |
Re: Crash's 72 K10
Firewall looks awesome, I like the job you did on capping the wire gutter like mike's, I'm going to have to do that on mine also. and the patch for the passenger side to match the curve too, great idea to re-use that piece. You are knocking it out like a pro but faster Man those Boyd tanks are super fine, high quality pieces! I almost dont want to cover mine up because it is so nice looking. Awesome quality and excellent aluminum welding for sure! Later
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
04-01-2012, 06:48 PM | #293 |
Re: Crash's 72 K10
Finished welding and grinding the firewall today.. I still have some more work to do on it.. but it is good for now.
Templates I created.. Mounted the new Boyd’s gas tank. I mounted it on top of the lower frame rail instead of underneath. I guess I need to lose some weight.. When I was on my back lower the almost full gas tank the welds on the creeper snapped. I guess I need to start posting in the for sale area… I have lots of stuff I need to move…
04-01-2012, 06:51 PM | #294 |
Re: Crash's 72 K10
That is looking great!
04-01-2012, 07:06 PM | #295 |
Still Learning
Re: Crash's 72 K10
Very nice work on the firewall Mark. I wish I had your stick-to-itative energy. I would have finished my truck along time ago.
04-01-2012, 08:00 PM | #296 |
Re: Crash's 72 K10
Have installed a few rear tanks but that is by far the nicest one I have seen so far.
04-01-2012, 08:07 PM | #297 |
Re: Crash's 72 K10
04-01-2012, 08:11 PM | #298 | |
Re: Crash's 72 K10
Thanks Mike.. It’s all about priorities.. You have lots of things going on that I don’t.. My progress will slow this summer.. it was awesome today at the lake.. I should have been on the water..
04-01-2012, 08:12 PM | #299 | |
Re: Crash's 72 K10
Thanks Mudman.. They do a great job on the tanks..
04-09-2012, 01:47 PM | #300 |
Re: Crash's 72 K10
Not a lot of work done this weekend.. My daughter turned 15, so we spent some time hanging out, and eating…
I did pick up a set of seats for mockup (Thanks to Tanner at B&R Auto salvage in Tulsa – Great people to work with). Not sure if I will keep these, I like the style and the bowtie emblem in the middle of the seats. The leather is nice except for the driver’s side bottom, and the cloth inserts are dirty.. I will clean them up and see what I think. The seats are powered and they work very well. I wanted to mount the seats utilizing the front seat mounting location (The raised area that the original seats mounted to). In addition, I wanted to reinforce the mounting system due to the integrated seatbelts. I was more concerned with the rear mounting system than the front. The front is naturally reinforced due to the nature of the raised area. The rear is flat with no natural support. I did use the orignal rear mounting location for two bolts on each side of the truck. In addition I was able to tie the mounts to the floor support system in two places. The area under the floor will be reinforced with plates and strapping. I will post those pictures next week after I have welded them in. I also finished the install of the fuel lines for the new gas tank. Last, but not least, the vintage air system arrived. I have not opened the boxes yet, but I will next week to fab up the mounting system for it. Not sure about the seats. I love the way the feel and look, expect for the headrest. I don’t really like the headrest in the back window look, but they are what they are, and they are safer in a rear end collision (if the floor mounts hold ).
