![]() Join Date: Jul 2002
I'm going to re-do my CST side panels in the rear....I'm going to use black naugahide...but what should I use for the back boards?
Wouldn't plywood be too thick for the holders on the top rail? Any ideas would be great! Thanks...... ![]() ![]()
Patch |
Blazerless:-(
I am going to use either thin gauge aluminum or steel. My hubby is a welder, so he thinks steel is better than anything else
aka Crusher, Crushergmc
Maybe a "wall of carpet" WOULD be coooool! I'm thinking Lime Green Shag
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
options
I used that fake wood wall board (woodpaneling) that is about an 1/8 of an inch thick. Easy to cut yet, still durable and doesn't fall apart when wet like the original cardboard did. Looks great and can't tell the difference when installed. If you want to see pics let me know.
Darrell... |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
What look are you going for?
If you frequantly haul stuff in the back an aluminium or sheet metal panel would work. If it's cosmetic only black vinyl(or what ever color you want)with a small amount of padding on the back side could be mounted to a 1/8"sheet of plywood( a replacement door panel would work.Used to reskin a house door.It's thin like that.) If you can find some factory ones(goodluck)that would be my choice.I know they reproduce them but they are about $400 bones. I got mine from a guy in B.C. for $125.00.A good deal I think! Here's mine ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
side panels
Hey BobbyK, you bought those from me a couple of years ago. They look good still!!!
Ya Darrell show some pics of that. I'm planning on doing the same thing with mine, but maybe use polyurathane and then that short nap carpet, like boat carpet. (Not astroturf)
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
Darrell,
ya man they do look great.Thanks again for the deal. The 1/8th inch board they have been mounted to has held up well.
I used masonite real thin and cheap $7 for a 4x8 sheet. Cut to fit loose to allow for thickness of the black material and matting from local fabric shop...cut holes for speakers. Found all the mounting holes with the masonite uncovered first. Used spray adhesive to mount material to board.
69 GMC 1 Ton Longhorn 37 Chevy Coupe |
Here they are installed...the red plug on top right is for the interior lights in the hardtop.
another shot...
Blazerless:-(
Those look real nice. Clean and tight! What did you use to cover the masonite? padding and vinyl? Looks great! I like a little bit of a custom look like that.
Back in the sticks
What are the side panels mounted to? My blaze didn't come with them, but I intend to add them at the end. I have two chrome strips that are about the length of the bed. Are these part of the side panels as well? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
The chrome strips you have are probably for the hold downs on the single wall top. The panels mount to little brackets welded onto the inner bedsides.
#15 |
Back in the sticks
Thats wierd. I have a double wall top. Of course everything about this blazer has been wierd. Why stop there! Guess it would be easy to fab up some mounts to mount the sides to. Thanks Gee emm! Can't wait to see the blaze. Its been sitting waiting patiently for me for 8 and a half months! Jeff
#16 |
Blazerless:-(
Red71Cheyenne- There are two diff. chrome strips. wide ones that hold down a singlewall top, and skinny ones that your side panels can slip into on the top. The panels mount to some brackets that are screwed to the middle of the bedsides. This picture shows the brackets there are 3 per side.
#17 |
Back in the sticks
Thanks for the pic. That makes it easy to understand. I will have to take a pic of the chrome strips and post them when I get home to see if they are the ones I want or something someone else needs. Thanks 70Blazin! Jeff.
#18 |
![]() Join Date: Dec 2002
The chrome strips that hold your panels are a longer version of the ones that hold in your door panels same design
