Old 05-05-2012, 10:58 PM   #26
VA72C10
VA72C10
VA72C10's Avatar
Re: SANFORD build thread
great build....subscribed...
Old 05-05-2012, 11:38 PM   #27
Captainfab
60-66 Nut
Nice fab work
What are the specs on those rear tires and wheels? The tires look to be good sized.
Old 05-06-2012, 02:06 AM   #28
C@rnut001
I love the look of your last truck! Your current build is looking great! Keep up the excellent work on it and thanks for giving us the updates.
C@rnut001 is offline   Reply With Quote
Old 05-06-2012, 08:42 AM   #29
jhrusk
Thanks guys,Capt. the rear tires are 285/70/15 silvertown and the wheels are 15x8.5,coulter I have been watcing your truck as well,good job.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 05-11-2012, 02:00 AM   #30
Dinos63
chevy only
Dinos63's Avatar
bump!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 05-11-2012, 08:05 AM   #31
lolife99
67-72 parts collector,…
lolife99's Avatar
Subscribing to this one.
Love everything,... especially the TTO wheels!
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 05-12-2012, 02:24 PM   #32
jhrusk
Just a quick update,I got the new wheels on the rear,also fininished the front control arms and was able to air up the front bags.I set the motor and trans in,I have some clearance issues with the rack but that is not surprising.I think I will get the cab installed then I can get the motor and trans mounts made.I also finished the rear panhard bar.I still have to get R & P attached to the spindles.I think once i get the engine mounts made I will start on the headers and exhaust.Thanks for looking.Name:  mr holder racecar 031.jpg
Name:  mr holder racecar 032.jpg
Name:  mr holder racecar 033.jpg
Name:  mr holder racecar 034.jpg
Old 05-12-2012, 02:35 PM   #33
Dinos63
chevy only
Dinos63's Avatar
Nailed the wheels,you do great work
Old 05-12-2012, 03:36 PM   #34
jhrusk
thanks
Old 05-12-2012, 03:59 PM   #35
hopped up
hopped up's Avatar
Awesome work! Look forward to seeing more
hopped up is offline   Reply With Quote
Old 05-15-2012, 10:20 PM   #36
fatgump
fatgump's Avatar
You get down to business. I look forward to watching your build.
fatgump is offline   Reply With Quote
Old 05-16-2012, 04:07 PM   #37
awbrown
Looks like you need the small balancer and a small pulley.... scot douglas had to do the same thing when he used a rack .. should be some pics here somewhere...
awbrown is offline   Reply With Quote
Old 05-16-2012, 04:10 PM   #38
1963c-10
1963c-10's Avatar
Awesome looking truck that you have and had.
1964 Short bed trailer
Old 05-16-2012, 04:16 PM   #39
jhrusk
Thanks guys,awbrown I saw in that build that he used the smaller balancer but i figure since I am building headers and exhaust any way I will just raise the engine a little and fit it where it fits best.Thanks for looking.
Old 05-16-2012, 07:40 PM   #40
dbomb53
dbomb53's Avatar
Nice Job...Is your rack power or manual? I'll be watching this one!
"I wanna be like Dino when I grow up"
dbomb53 is offline   Reply With Quote
Old 05-17-2012, 07:03 AM   #41
jhrusk
dbomb53 it is a mustangII or t-bird power rack from advance auto.It was around a$100 bucks.Your truck is cool as well,Thanks for looking.
Old 05-29-2012, 08:57 PM   #42
hardwaa
hardwaa's Avatar
Nice work! Keep it up!
Also are you making the headers ?...Fender-wells????
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 05-30-2012, 01:37 PM   #43
jhrusk
Updates coming soon,Hardwaa I thought I would build my headers but I have a set that I will make work,They will be under the truck and full exhaust with turndowns just in front of the rear bumper.Thanks.
Old 05-30-2012, 07:06 PM   #44
jhrusk
Got a few updates,pretty much have the rack finished except for the steering shaft,pics show the outer tie-rod ends.I will do final adjustments when I do the front end alignment.also got the motor and trans set where I want it and made a trans mount.Name:  mr holder racecar 033.jpg
Name:  mr holder racecar 041.jpg
Name:  mr holder racecar 035.jpg
Name:  mr holder racecar 036.jpg
Old 05-30-2012, 07:13 PM   #45
jhrusk
I had to move the engine to the front motor mount holes and raise it about 1 1/2 to clear the rack.I think I will modify the bottom of these headers so I can raise them where they wont hang lower than the frame rails.I usually have around 20 hours in building a set of mild steel headers,so I will clean these up and use them.Name:  mr holder racecar 040.jpg
Name:  mr holder racecar 037.jpg
Name:  mr holder racecar 038.jpg
Old 05-30-2012, 07:20 PM   #46
jhrusk
Here are a few pics of the cab on the truck,I did not get a pic before I took the front end off.My next task is to build the exhaust,mount lower rear bag mount and set the rear pinion angle.I will post more pics as I make progress.Thanks for looking.Name:  mr holder racecar 031.jpg
Name:  mr holder racecar 039.jpg
Name:  mr holder racecar 042.jpg
Old 06-01-2012, 11:35 AM   #47
Dinos63
chevy only
Dinos63's Avatar
Looks great!
Old 06-01-2012, 11:46 AM   #48
283 Man
283 Man's Avatar
Thumbs up Re: SANFORD build thread
Super sweet
283 the mighty small block
283 Man is offline   Reply With Quote
Old 06-01-2012, 12:00 PM   #49
lolife99
lolife99's Avatar
I love this truck!
I do have a question.
It appears your rack is offset to the drivers side.
Won't this affect bumpsteer?
(I'm no expert,.... I'm just trying to understand)
Maybe it's just an optical illusion,...
Keith
Old 06-01-2012, 01:29 PM   #50
scot 6 feet eleven
scot 6 feet eleven's Avatar
way cool!!!
1960 chevy 4.6 police interceptor chassis under this bad boy with 24 inch lexani's
scot 6 feet eleven is offline   Reply With Quote
