#4201 |
Re: How about some pics of 73-91 crew cabs
that is one good looking truck, think you can show some interior shots?
2001 Tahoe 1978 K30 |
#4202 |
#4203 | ||
Thank you!
#4204 |
Nice truck. How did you lower the seats?
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
#4205 |
The driver's side is power so the mounting brackets where very tall so I just cut out desired amount and rewelded them. Only tricky part was I had one mounting point drop down because the floor as we all know is not flat. On the passenger side the seat has two sliding mechanisms one slides the whole seat up and out of the way for passenger entrance to the back and the other is the front back adjustment. I simply drilled the rivets out and took out the whole sliding mechanism for the passenger entrance to the back one and then cut the feet off the front back one and rewelded in there desired location..All in all it was very simply just a little time consuming and a lot of measurements..
#4206 |
#4207 |
hey guys , I'm stuck on what transfercase to swap into my 90 crew. I have a 90 cummins with a 47rh transmission. what have you guys used for this swap?
#4208 |
dodge 241, from a 89-93 will bolt to the trans, and have pass drop, as well as fixed yoke. thats what I ran in my crewcab when it was auto, before I went to the stickshift.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#4209 |
Update: Lots of new parts
Most noticably the wheel and tires Rear axle with 4.56 gears, detroit locker, rear disk brakes, braided hoses with AN fittings, relocated shock mounts, welded tubes Front axle with 4.56 gears, dropped pitman arm, dropped draglink, rebuilt steering gear box, borgeson steering u-joint, sway bar disconnects Made a rear bumper and threw a winch on the front New exhaust, ORD steer box brace, tuned up and ready to roll Engine is next! ![]()
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! |
#4210 |
Resident of Here
Sweet! Very nice!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#4211 |
Went to Tampa Fl and picked up this bed and 2 bench seats. Going to run this bed til dad gets around to stretching the fenders on my original bed.
Ready to roll out to a car show next weekend-
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project. 96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq 05 VW Passat TDI - 38mpg @75mph ![]() 07 Bandit 1250S - Two wheeled fun! Click here to see my FQuick Garage! |
#4212 |
6>8 Plugless........
![]() Join Date: Sep 2007
You mean NP205? Dodge didn't go to the 241's until 94, and they are LH drop.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#4213 |
Leedog, your truck looks cool! Man those tires look like wide bicycle tires on those wheels!
#4214 | |
![]() and some current pics of my crewcab! ![]() ![]()
#4215 |
Ok, you're right, in the gassers they did. Your truck is looking good! I like that much better!
#4216 |
Thanks, its SLOWLY getting back together. I miss driving it real bad, but its getting alot of new stuff, and things fixed better so its going to be much better this time around.
#4217 |
![]() Last edited by GMC5.9cummins; 05-19-2012 at 12:20 AM. |
#4218 | |
Very nice!! What lift and tire size? Posted via Mobile Device
#4219 | |
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#4220 |
Very nice GMC!
#4221 |
Thanks man! they are 265/35's "extra Load". you can run up to 150PSI in those tires, crazy. i run 50. The inners are E Load 16's. Should be able to haul anything i want. Got the stuff for a 6/8 drop, just waiting on Dad to get time at the shop to fool with my bed. Next year- it is gonna get air ride.
#4222 |
Puppy- Truck looks awesom! Especially like the pic from the front. intimidating ride. The Bumpers with the fairleads are cool.
![]() GMC5.9cummins- Truck is just full of bad ass. ![]()
#4223 |
Nice! Grip Spurs on it? Have any pics of your traction bar setup?
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban ![]() |
#4224 |
#4225 |
looks to me like 6" inch lift and 36" goodyear military tires
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s ![]() |
Tags |
crew, crew cab, square body, squarebody, squarebody.net |
