Old 06-19-2011, 04:34 PM   #101
oklahomaduner
oklahomaduner's Avatar
Re: '66 GMC BBW w/351E and Factory Buckets
I just put gas in it. I was hoping I didnt have to line it at that point but my tank was pretty dang bad.
1966 GMC Extended cab 1 1/4 ton 4x4
My build thread
1958 Chevy 1 ton dually flatbed
My Dad's build thread
1966 GMC Custom Trim Big Back Window W/351e
My Time-Killing Project Truck
1966 (Not So) All Original Chevy Custom Trim Suburban
My Dad's Time-Killing Project Truck
oklahomaduner is offline   Reply With Quote
Old 06-20-2011, 12:15 AM   #102
67chevy1series
67chevy1series's Avatar
its holding up on ya? no more rusting has ocured?
67chevy1series is offline   Reply With Quote
Old 06-20-2011, 01:00 AM   #103
RockTonka
RockTonka's Avatar
After the initial muratic acid cleaning (and rinsing/drying), we put gas in and still had rust issues...no coating yet.
We then elected for the Hirsch kit and recleaned and coated the tank and are still on the first tank since then with no probs...so far.
The new 10 bolt rearend is narrow at 61" WMS to WMS, but having 0 miles on it makes up for it's "short" comings.... We were thinking that a set of 10x15 ralleys and some 31x12.50x15s would work nicely...just have to find them now. In the meantime, the 2" spacers work well with the 8x15" ralleys and 235/75R-15s.
New spring pads, u-bolts, plates, and u-joints for the old driveshaft and the rearend was a bolt-in job...even the old brakelines fit with no modifications.
We did pull the bottom three leaves out of the stock 9 leaf pack, dropped it a bit and seems to ride nice...we're considering cutting a portion of a coil off the front too.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 06-20-2011, 01:05 AM   #104
RockTonka
RockTonka's Avatar
Few more pics of before and after spacers...
My build thread
Old 06-20-2011, 01:14 AM   #105
67chevy1series
thanks for the info i need to do this with mine
Old 06-21-2011, 12:12 AM   #106
Captainfab
60-66 Nut
So does that Colorado rear end have the 6 x 5.5 wheel bolt pattern?
Old 06-21-2011, 01:23 AM   #107
oklahomaduner
If you have any questions when you do it feel free to ask bud!
Yes it does, a lot the guys told me that you can physically see the difference in size of bolt pattern between a full sized rear and the colorado rear. But i felt like being stubborn and trying one of my wheels onto to it, and sure enough it fit perfectly, it also fit the full sized rear.
My build thread
Old 06-22-2011, 01:12 AM   #108
Captainfab
60-66 Nut
Cool! Thanks for verifying that. Do you have any other info on that rear end such as ring gear size, axle splines, etc?
Old 06-22-2011, 04:53 PM   #109
creep
Registered Loser
creep's Avatar
Very cool! I had the Holley on my V6 and it ran great.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-24-2011, 02:46 AM   #110
RockTonka
RockTonka's Avatar
Nope, we didn't pull anything other than the cover for inspection and some baby blue paint
Yea, that and the HEI really woke it up, the 3.42s have it spinning pretty good around 70, but it'll still jump out for passing...we're going to drop a little tach on it for monitoring though.
We dropped it off a local upholstery shop for new padding and carpet before adding new pedals, door sills, and kick panel covers. We are gonna try and get the seat redone as close to stock as possible in the next few weeks.
Few pics of where its at now...
My build thread
Old 06-24-2011, 11:06 AM   #111
wc63
wc63's Avatar
i want to hear it. the exhaust looks nice. i ended doin mine the same way only i cut angles since i dont have a bender. i had flowmasters and switched to glasspacks. i like those better. but it sounded nice with the flowmasters at idle. i have a 305 v6 tho. you guys are doing great. i guess it helps to have some help. keep it up.
wc63 is offline   Reply With Quote
Old 02-02-2012, 10:24 PM   #112
C@rnut001
Nice truck...do you have any updates on it? I think it is great that you saved it and are making it nice again.
C@rnut001 is offline   Reply With Quote
Old 02-18-2012, 11:21 AM   #113
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Subscribed! Love it!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-19-2012, 12:58 PM   #114
Joemomma1
Joemomma1's Avatar
Whats the status on the new seat covers?
Joemomma1 is offline   Reply With Quote
Old 03-12-2012, 11:52 PM   #115
RockTonka
RockTonka's Avatar
We had parked this for a bit because of heavy leaks from the power steering valve, hoses, and ram.
We investigated options for both replacing those components and rebuilding them before deciding to go the less expensive route of rebuilding them.
My son chased down rebuild kits for both the valve and ram for just a few bucks...not many parts involved.
We had all new hoses built and then disassembled, cleaned, and rebuilt the valve and cylinder.
We reinstalled everything this past weekend and put a few miles cruising around town...perfect steering and NO leaks
BTW - Haven't done anything with the seats...yet.
My build thread
Old 04-08-2012, 11:43 PM   #116
oklahomaduner
Well, I was going to get some pinstriping done on the truck for my birthday, but as I was driving her to the car wash, she died. After losing power and feeling really sluggish I let off of the gas and it just quietly died while cruising at about 50. I coast to a stop and try to start it, nothing. I figured the alternator had finally given up so we tow her home, replace the alt. with a spare one we had, charged it up, and tried it again. Nothing. The starter was trying but the motor wouldn't turn. So I tried to turn the crank with a ratchet and a 18" cheater... It won't budge at all!! So the truck is back in the back yard with a frozen motor until we can look into what's going on...
My build thread
Old 04-09-2012, 10:17 AM   #117
jbclassix
Junk Yartist
jbclassix's Avatar
C'mon man! 351's are everywhere! Just go down to your local autoparts store and pick up a long block! I'm sure they have one sitting on the shelf in the back of the store.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-09-2012, 12:12 PM   #118
nbrfd007
nbrfd007's Avatar
Hate to here this!
nbrfd007 is offline   Reply With Quote
Old 04-09-2012, 05:23 PM   #119
Hopefully it is something not too major and you can get it back going again without too much expense.
Old 04-10-2012, 12:16 PM   #120
Corts60
Just here to tinker
Corts60's Avatar
Sorry to hear about the motor freezing up.
Old 04-10-2012, 01:24 PM   #121
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
I sure hope you keep your GMC ...GMC and keep the V6.. that is, if is indeed seized up.
Just way too many GMC's with SBC's in them.. (IMHO)
Of course it's your ride to do as you wish.
The guys on the V6 website normally will do pretty much anything they can to help you keep it a V6.
I know I regret getting rid of my original V6.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 04-12-2012, 02:19 PM   #122
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
cool build! love them old GMC'S!
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 06-06-2012, 05:16 AM   #123
MikeS.
MikeS.'s Avatar
Hey guys, we need some updates here too. We need to know more about that motor problem.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 06-06-2012, 06:39 AM   #124
63burban4x4
63burban4x4's Avatar
I missed this thread earlier, till it returned to the top. Just a passing note, my first pickup (bought in 1972) was a '67 Chevy "CST", had the same bucket seats, I think the vinyl was a bit different....but I might be just thinking that 'cause they were red. 40 years fades (some) memories! I knew at the time they were extremly rare, I only knew of one other truck that had 'em. I have NEVER seen a 60 -66 with those!
63burban4x4 is offline   Reply With Quote
Old 07-08-2012, 06:30 PM   #125
oklahomaduner
I guess I must have unsubscribed from my thread.. Anyways, this truck is going to be sitting for a little while since everything else is starting to come together on our other builds. But we are going to do everything we can to put this truck back to stock. But yes, that v-6 isnt going anywhere. haha
My build thread
