my new to me 1986 chevy sub
i just picked up a 1986 chevy suburban with a 6.2 diesel in it with 182,000 miles on it. im the fourth owner the woman i got it from said her grandfather bought it new in 86 an ordered the heavy duty tow package on it with a posi track rear. pretty clean if i have to say so myself.
![]() ![]() ![]() ![]() an here is a pic of it after i put my cowl hood onit curtousy of top bananna parts fit great by the way ![]() |
Garage wrench
Re: my new to me 1986 chevy sub
Nice rig! What are the plans for it?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Drop spindles an bags a small 4 inch notch in rear an flip axel over top of springs an bag the rear like justpball done his. Also plan to get a set of 18x8 streeter wheels for the front an a set of 20x10s for the rear
Posted via Mobile Device |
gonna follow your build...nice Burb
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
Ok update Im planning to pick up a set of 18x9 boss 304 wheels next weekend. So that will be another step closer also i have put my 12" subs in an a 1500watt amp an lighting cap
Posted via Mobile Device Last edited by csa daddy; 07-07-2012 at 02:36 PM. |
thanks everyone whos following here is a update pic for 3" spindles in a little rubbing on the rallies at full lock an had to move brake lines to clear the spindles
pic of where i want it to sit when done thanks to justpball
![]() an here is a pic of the wheels im getting ![]() |
First car show today for the burb will try to pus pics this evening if anyone is interested
yeah yeah yeah...
K it's just a small show so dont get to excited
Posted via Mobile Device Last edited by csa daddy; 07-07-2012 at 04:41 PM. |
What size are those wheels?
18" need to find a couple 20x10s for the back
Posted via Mobile Device Last edited by csa daddy; 07-07-2012 at 06:23 PM. |
car show pics
#15 |
I Will put up some more tomorrow home computer acting stupid an froze up so No more pics tonite
#16 |
nice!
#18 |
Chevys Kick A$$
Cool looking burb looks super clean. Sounds like a fun project cant wait to see it when its done
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#19 |
If I turbo it I will proably just swap a 6.5 in it but that will only come after the 6.2 dies. I dOnt need to fly up the highway so the 6.2 does all I need it to plus it gets great fuel mileage. So why mess with it.
#20 | |
1. Biggest bang for the buck will be a free flow exhaust. The stock setup is very restrictive. A super single 3" works well. Or if you want a mean sounding setup, go with dual 2.5" / H-pipe and some old fashioned Thrush / Walker glasspack mufflers. 2. J code air handler (intake manifold). This air handler has no EGR. Or if you want to save some money, you can simply chip out the EGR pedestal. 3. BHAF (Big Honkin Air Filter). Basically, stack 2 air filters on top of each other. Of course to take advantage of all of this, you'll need to turn up the injection pump.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#21 |
Exhaust plans are to build one of the exhaust adapters by a dr lee swagger from over on the diesel forum an run 3" from 2.5 adapters back with proably flowmasters not sure if it's a j code or c code motor had t checked yet. I got a 6" k&n filter I could put on but would have would have to make a top for the filter. I do plan to install some hot glow plugs eventually
#22 | |
1/2 ton Suburbans would have come stock with a C code motor. K&N's are OK as long as you don't drive down dusty roads. They don't tend to filter out the dust as well as a paper element filter. Bypass that glow plug controller with a push button before it causes you grief. But make sure you select the right glow plugs that can handle extended glow plug times. I'm using AC Delco 60G but there might be something preferable right now.
#23 |
I forget which ones exactly but I think they are Keith something an my old motor which was a 1/2 ton 4x4 an had a j code motor an the one my dad had which is now in my 91 sub is also a j code motor an like I said just had t checked the numbers to see about this motor. Never real had problems with factory controller but how would you do that
#24 | |
If you do this, you want glow plugs that won't burn up with extended time. Glow plug controllers are expensive and when they do go out, you're pretty much stuck.
#25 |
Right I will have to check into it am maybe get a spare to carry with me. So far I have replaced several of the fuel return lines on the motor an the brake line an caliper Was wondering about turning up the injector pump but have never messed with one so
