Old 07-23-2012, 07:48 PM   #1
W.I.P.72
W.I.P.72's Avatar
Semi-Idiot needs help!!!!!
Ok, so I know there are a few threads on this, but I need it broken down dumby style for me. I want to convert to disc brakes all the way around and also to 5 lugs.
I found a front kit that looks good.
http://www.azproperformance.com/McGa...148-63151.html
And the matching rear.
http://www.azproperformance.com/McGa...202-64203.html
And I know I need the master & booster and the adjustable proportioning valve.
But my question is, will those kits actually convert my truck to five lug, or are those just built for a five lug set up. Also, what else will i need to complete this job?
Thanks for all the help.
OKLAHOMA MEMBER MEET JUNE 15, MIDWEST CITY OK.http://67-72chevytrucks.com/vboard/s...d.php?t=559886
72 C-20 Stepside - Work In Progress
W.I.P.72 is offline   Reply With Quote
Old 07-23-2012, 08:01 PM   #2
Scottshotrods
Re: Semi-Idiot needs help!!!!!
You will need to buy 5 lug axles for your rearend on your truck.We have these instock from Cpp they are a direct bolt in for a 12 bolt rear.We have firewall mount master booster kits instock that will be a direct bolt in to your truck.These will have a prop valve with it to.
Justin
(805)485-0382
Scottshotrods is offline   Reply With Quote
Old 07-23-2012, 08:08 PM   #3
W.I.P.72
W.I.P.72's Avatar
what about the front, what will i need for that?
Old 07-23-2012, 08:13 PM   #4
W.I.P.72
W.I.P.72's Avatar
And what if I keep it 6 lug, that might just be a better idea... not sure why everyone says to go with 5 instead of 6, is it just rim selection?
Old 07-23-2012, 08:36 PM   #5
Scottshotrods
You can keep your 6 lug wheels if you would like to.We have complete front and rear disc brake kits for your truck.Alot of people change to 5 lug for more of a wheel selection.If you have your wheels you want to run.You can keep the 6 lug and we
have direct bolt on kits for your truck.
You will need
front disc brake kit for your truck
master booster for your firewall
rear disc brake kit for your truck
If you would like to get some prices you can e-mail us at scotts@scottshotrods.com
Old 07-26-2012, 07:53 PM   #6
W.I.P.72
W.I.P.72's Avatar
is it hard to just do a front disc conversion and leave the back drums? How does that work?
