Re: Plumbing the fuel
I picked up a kit from jegs using an external pump. And yes the tank has already been moved to the bed. The reason i considered still using the jegs regulator is that its set for a pressure gauge an also reduces the hose size from #8 to a #6 which i figure will make it easier to plumb into the throttle body inlet
Posted via Mobile Device |
Tags |
fuel, motor |
