02-13-2012, 02:00 AM | #26 |
Re: Best tow hitch
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
02-13-2012, 02:03 AM | #27 |
Re: Best tow hitch
I do need a set of rear sport bumper brackets for a longbed fleetside 2wd coil spring setup before I do a write up on the install though so i get the proper measurement on where to drill the holes in the framerail.
04-28-2012, 01:02 PM | #28 |
Re: Best tow hitch
Any update on the install?
04-28-2012, 02:30 PM | #29 |
Registered Cruiser
Re: Best tow hitch
I built my own hidden hitch for about twenty bucks.
I intend to live forever. So far, so good. |
08-21-2012, 10:46 PM | #30 |
Re: Best tow hitch
Finally got it installed! It is the perfect height with my Class IV adjustable receiver.
08-21-2012, 10:59 PM | #31 |
Re: Best tow hitch
Good point
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-22-2012, 12:26 AM | #32 |
Re: Best tow hitch
Curt,Reese and Cyquent are some good hitches also.They should have any hitch for our trucks.How ever you have to now go with a 73-86 hitch to get one to fit.
Guys please don't pull nothing bigger than a 20' trailer behind a 1/2 ton on the interstate at interstate speeds. I have seen my share of bad wrecks. No lites,trailer not loaded rite,you name it.I always say 24'-30' should go on 3/4 ton and any thing larger on 1 ton.Call me crazy if you like but I want to be safe and the one's around me. It would kill me to hurt someones family if stupidity on my part. I have 10 years in the camper and towing industry also.Amongst a few other things. |
08-22-2012, 12:39 AM | #33 | |
Re: Best tow hitch
I couldn't agree with you more! I get the heaviest duty accessories I can for the equipment that I have, not so I can max out it's capacity but so that the loads I do pull are better managed.
03-27-2013, 12:56 AM | #34 | |
Re: Best tow hitch
03-27-2013, 02:51 AM | #35 |
Re: Best tow hitch
03-27-2013, 05:48 AM | #36 |
Re: Best tow hitch
sub'd
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
03-27-2013, 09:46 AM | #37 |
Re: Best tow hitch
So both the curt and ECE are hidden behind the license plate? does anyone have a link for the ECE hitch?
03-27-2013, 07:10 PM | #38 |
Re: Best tow hitch
02-02-2014, 04:11 PM | #39 |
Re: Best tow hitch
ok, so all this talk of hitches and not a mention of anyone bagged! I want a hitch that is hidden and doesn't drag on the ground! Is anyone else wondering the same as me?? Any help? i saw awhile back that CPP had one but I can't find it
02-02-2014, 04:27 PM | #40 |
Re: Best tow hitch
02-02-2014, 06:16 PM | #41 |
Re: Best tow hitch
Here's mine. Draw Tight
Figure out what you want--then figure out what you are willing to give up to get it. |
02-04-2014, 12:49 AM | #42 |
Re: Best tow hitch
I was looking for the same thing and could not find anything off the shelf. So I designed and fabricated this.....
02-04-2014, 12:05 PM | #43 |
Re: Best tow hitch
Much better! Lol. I will have a rear bumper so I'm not 100% how,or if, I would fab my own... I did find the one on CPP website. Thanks for that help
02-11-2014, 09:36 AM | #44 |
Re: Best tow hitch
Mine is bagged...and fully dropped it does not drag
02-11-2014, 01:46 PM | #45 |
Re: Best tow hitch
The hidden hitches behind the license plate would get me a ticket here as the plate would not be visible when the receiver is in
02-13-2014, 12:22 AM | #46 | |
Re: Best tow hitch
_______________________________________________ A project can be finished, but a car is never done. 1967 chevy K10 step 2002 chevy Impala Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308 |
02-15-2014, 06:36 AM | #47 |
Re: Best tow hitch
If you use a flip bracket then the plate flips up flat and sits on the receiver and is still considered visible and mounted correctly.
07-30-2014, 09:47 PM | #48 |
Re: Best tow hitch
I know this is old but I see your still active here. I notice you had to remove your plate bracket to mount your hitch. Im running into the same issue. Im pretty aggravated about this.
07-31-2014, 12:26 AM | #49 |
Re: Best tow hitch
At the point I took that picture, I had not installed my plate or bracket yet. to take the bracket off I believe it is 4 bolts... pretty simple in my mind... Also you will have to trim it to allow the receiver to come out, then with a flip up bracket installed in the upside down from OEM design the license plate will be bent around the receiver the last 3/16" and will be visible and legal. To install this hitch you will be drilling 4-6 holes depending on how you line your hitch up under the rear of the frame.
07-31-2014, 12:31 AM | #50 | |
Re: Best tow hitch
