Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-22-2012, 06:45 PM   #1
BIGTEN
BIGTEN's Avatar
Scosche Stereo Wiring Connector
I just picked this up from wally world and wanted to know if any of you have used it. Its made by Scosche for 73-91 gm , its says "quickly connect factory wiring to your new stereo".
79 c10
BIGTEN is offline   Reply With Quote
Old 08-22-2012, 08:14 PM   #2
MadManAndrew
Re: Scosche Stereo Wiring Connector
Haven't used that specific one but I used the same product for 99-06's. If your truck has the stock stereo connector it'll plug right into that. You'll still have to wire it and the connector for the new stereo together but that's not hard. Did you have any questions?
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 08-22-2012, 08:40 PM   #3
BIGTEN
BIGTEN's Avatar
The stock stereo broke so will a aftermarket one fit the plug?
Old 08-23-2012, 12:07 AM   #4
MadManAndrew
If the truck has the stock stereo connector (which I would assume to be true since you're saying the stock radio broke) then yes, the product you bought will connect to the factory wiring. However, there's two styles of this product. One that has a plug on both ends, a plug 'n play of sorts, and one that has a pigtail on it that has to be soldered or crimp connected to the other plug that will come with your new radio. You most likely have the one that has to be connected to another plug.
Old 09-08-2012, 08:00 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Scosche makes some good connector. I have used them several times and have had good luck with them.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-13-2012, 04:47 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
79 c10
before you write off the stock radio bypass the plugs to test it
i've seen the plugs loosen and not connect
i bought one worked great used a newer stock radio 99 and wired to the 88 plugged right in
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 09-13-2012, 10:50 PM   #7
BIGTEN
BIGTEN's Avatar
Looked under the dash to find a plug in for the connector and found nothing. My dad had the truck before me and said the original owner screwed around with it and he had to jerry rig it to work.
Bought a jvc stereo and plugged it in after a long talk with dad to figure the wires out and success I'm back in business.
